View Full Version : Water pump spacers for L92 with VVT
scherp69
02-22-2011, 03:36 PM
I know that Mast Motorsports has some water pump spacers so that an aftermarket serpentine kit and car water pump can be used, but they are not cheap. If I remember correctly they want $300 (or more) for a set. I found a set on Ebay for $75, but would rather buy from someone on the forum. Does anyone offer these spacers? Thanks.
Ron.in.SoCal
03-03-2011, 05:42 PM
Hey Mike - I believe Kevin O of V8Tv did a segment on making his own. Seemed to work prefect. I'll see if I can find it...
daytonayellaz
03-11-2011, 05:37 PM
Hey Mike..... let me check on the Mast spacers for you, Im a Mast dealer now and may be able to help.
scherp69
03-11-2011, 07:21 PM
Thanks Travis. I was going to call you when I get closer to pulling the trigger on the m90 performance package. Probably won't be a couple months still, but will give you a shout when closer. I think Mast wanted 2 or 3 hundred for the pair.
Samckitt
03-12-2011, 04:39 AM
Subscribing cause I want to see what is found too.
Samckitt
03-12-2011, 04:45 AM
Have you checked ebay?
http://www.google.com/search?q=l92+water+pump+spacer&hl=en&client=firefox-a&hs=AI4&sa=X&rls=org.mozilla:en-US:official&prmd=ivns&source=univ&tbs=shop:1&tbo=u&ei=nWl7TduDMea50QHj4-jTAw&oi=product_result_group&ct=image&resnum=3&ved=0CCsQzAMwAg&biw=1472&bih=803
http://compare.ebay.com/like/140514501044?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&rvr_id=217260393766&crlp=1_263602_309572&UA=%3F*F%3F&GUID=aa187a7c12e0a47a27031b83fe79245f&itemid=140514501044&ff4=263602_309572
scherp69
03-12-2011, 09:58 AM
Thanks Scott. I had checked Ebay. Like my original post said though, I was hoping that someone on the forum might sell them or make them so I could support a local vendor instead of Ebay. If I can't find ones that are close to the Ebay cost (I can't remember how much the Mast ones were), I might consider getting those ones. Thanks again for the link though.
BossaNova
03-12-2011, 11:18 AM
Good question, Mike!
Samckitt
03-13-2011, 06:47 PM
Sorry Mike, Somehow I skipped over the "Found one on Ebay" part.
scherp69
03-14-2011, 07:35 AM
No worries at all Scott. I'm sure the links were useful for someone reading this thread.
