View Full Version : New from chicago (Roy)
scemeca
02-15-2011, 08:43 PM
I have been posting in the wrong part of the forum so a little about what i am been doing i have been putting a ls1 and a 4l60e also doing a four wheel disc conversion into my 1971 chevelle it seems to be more of a restoration than a conversion no really big rust spots or holes just alot of service rust and a **** load of dirt nothing a wire wheel and a mask can not take care of here are a couple of pics.
scemeca
02-15-2011, 09:17 PM
I am still learning how to use this site sorry but it says i have used all my storage for pics so i had to delete some from my other thread if there is a way to get more storage i am all ears thanks here is a couple more pics
scemeca
02-15-2011, 09:25 PM
I have removed the tank and the rear end i wired wheeled and put 2 coats of lizard skin on the bottom of the trunk i hope this will take some noise from the fuel pump! i even got my son to do some work lol!
scemeca
02-15-2011, 09:40 PM
Well i got the tank and fuel line installed and also the rear end it has been a fun process i have been working on the car for the last couple of days after work and have got alot done!
scemeca
02-15-2011, 10:09 PM
To bring me up to date on my project i have got the motor in the car i had a problem with the tierod end hitting my oil pan i put a 1/8 plate under the motor mount and lifted the engine just enough to clear it should be fine! next is the wiring!!!!
FULMNTE
02-16-2011, 12:37 PM
Welcome neighbor, nice project!
scemeca
02-20-2011, 06:11 PM
I got all my stuff in,my wiring harness ,computer alt. pwr steering ac,from s&p the kit was pretty easy to install all detailed instructions i need to find out which fan set up to use not really sure yet i have been reading the forum and every body is running something different any suggestions:idea: Next to do on my list is to reinstall the front end!!
CruizinKev
02-20-2011, 10:08 PM
good looking project! :twothumbs
scemeca
02-21-2011, 08:11 PM
Toadman
02-22-2011, 07:31 AM
Looks Goooood! I dig that color gold.
I'm about at the same place in my LS swap into my Camaro. You should come out to the INR autocross this summer & help me beat up on some Miatas!! http://www.inr-scca.org/
scemeca
02-23-2011, 07:18 PM
Sounds like a plan!!
scemeca
02-27-2011, 05:15 PM
Well i am getting close still need to do a few loose ends yet i have a couple more wires left i am working in a 2 1/2 garage so i need to get the car on the ground so i can get to the drivers side better here is a couple of pics to show what i have done!
strtcar
02-28-2011, 07:51 PM
Looking good, what part of chicago you from?
scemeca
02-28-2011, 09:55 PM
I am in the the bucktown area north&damen
killer67
02-28-2011, 09:58 PM
I like where it's headed
scemeca
03-07-2011, 07:06 AM
Well i got it running this weekend i have having a problem with the ignition power to the fuse box I tried using a relay with direct power from the battery and it still would not start right i put the ignition wire straight to the battrey and it will start has any one had this problem I am using s&p harness and my computer is from a 98 camaro???:banghead:
scemeca
03-09-2011, 06:32 AM
I called s&p those guys know there stuff they told me the problem it was fixed in 5 minutes wow!! i need to bleed my brakes and put my wheels back on time to take it out!:6gears:
