View Full Version : Something dosent seem right? (Trunk lid)
phasemaster1
02-14-2011, 08:15 PM
This is on my 1967 GTO. Trunk is on minus weatherstripping and little bumpers. The drivers side dead even with top of quarter. Passenger side lid is about 5/16 lower? Is this normal when weatherstripping and bumpers arent installed? Dont remember if it was off before been off for years.
https://static1.pt-content.com/images/pt/2011/02/Trunklid1-1.jpg
https://static1.pt-content.com/images/pt/2011/02/trunklid2-1.jpg
67 ls1 vert
02-14-2011, 09:17 PM
you'll need to install the weather striping to make sure.
If that doesn't get you where you need you can install a few shims between the trunk lid and hinge to bump it up.
Good luck.
phasemaster1
02-15-2011, 05:58 PM
Ordered the weather stripping!Thanks
Jon Clough
02-22-2011, 08:55 PM
you might have to bend the trunk back into shape, I am not thinking the weatherstripping will put that much pressure on it.
wmhjr
02-22-2011, 09:14 PM
On my 66, without bumpers or weatherstripping the trunk lid was perfectly even on both sides.
Jim Nilsen
02-23-2011, 06:33 PM
Align the the edges of the trunk lid to the qtr panel and other areas then make sure the weather strip fits and adjust the channel and then go back and make sure the trunk lid is still lined up. Don't glue the weather strip in on the trial test and you should be able to reuse it and glue it where needed when you do the final install.
It should line up perfect before paint and you can do it with a good dollie and a hammer.
phasemaster1
02-24-2011, 06:35 PM
Thats what I was affraid of.... Does any body have a picture how the weather stripping is supposed to go in. Not sure I have it in right.
phasemaster1
01-02-2015, 06:12 PM
Took a 3lb hammer a 2x4 and negotiation skills but happy with results.
