View Full Version : Power steering pump for rack n pinion
jarquiette
02-14-2011, 06:18 AM
I need to know if a standard OEM power steering pump will work with my newly installed rack and pinion steering. This is a 68 camaro. I will most likely replace the pump ( cosmetic reasons ) but want to make sure I get the correct pump. Also, I will replace the stock lines with steel braded lines. Does anyone know the proper size fittings for the rack? I believe the supply side is smaller than the return side. Is it AN or pipe threads? I got rack from TCI -not sure of the brand.
TheJDMan
02-15-2011, 07:32 PM
I would contact TCI and ask them what pump they recommend.
Jim Nilsen
03-05-2011, 10:07 AM
Get the right pump or you will have problems. You have to know the rpm range and pulley ratios you are going to run to make the right decisions and a stock pump may not be up to the task or proper functionality.
