View Full Version : What is the point of Fender Braces
rfalker1
02-13-2011, 01:45 PM
was looking at getting a pair of fender braces from hotchkis, but wanted to know peoples opinion before i buy them
rfalker1
02-13-2011, 04:02 PM
nevermnd, i bought them
JRouche
02-13-2011, 05:28 PM
Ok, so now that you bought them tell us. Whats your opinion? Any help? Did they increase the performance or are they show pieces.
Yeah, I know. You just bought them, haven't installed them yet. But when you do please give your opinions after driving with them for the other folks benny. Might make a nice product review, good or not, still great info. JR
rfalker1
02-15-2011, 04:20 AM
Sure, sure, but I am not sure it will be quite accurate, because I am doing a total suspension overhaul from frame connectors to drop spring, shocks control arms and sway bars and even tie rod sleeves. But I think they will be more for show, and because my engine bay is being completely cleaned then I want finish the deal with those.
Steve Chryssos
02-16-2011, 04:06 AM
Fender braces are not designed to help handling. Their purpose is to keep your sheetmetal in alignment. Without them, the nose of your car can move around causing door to fender gaps to change and other issues. Picture the nose of your car as a three dimensional cube, then grab the top and bottom of the cube and twist in opposite directions.
garickman
02-16-2011, 06:57 AM
Just out of curiosity, why does it seem like only f-body cars have fender braces? Why don't larger cars have them like A bodies?
critter
02-16-2011, 07:03 AM
I'm guessing it's a full frame VS subframe deal.
ZuperZport
02-16-2011, 07:17 AM
I just got the awesome Twist Machine Fender Braces (Core Support Bars) installed in my Camaro.
These things are a work of art!
Not only super sharp looking but will also keep the sheetmetal in place under stress.
You guys got to get a set of these from Twist Machine.
www.twistmachine.com
Superior Quality. Tremendous Value. Class all the way!
https://static1.pt-content.com/images/pt/2011/02/IMG00028201102140821-1.jpg
jpdeuce
02-16-2011, 08:22 AM
Why do Camaros have them and Novas that have the same set up do not?
LowBuckX
02-16-2011, 10:25 AM
dunno butI put them on my 72 and they made a big dif in hood?fender shake while driving. I have no Inner wheel wells
MonzaRacer
02-16-2011, 12:16 PM
The actual use was to shore up the sheet metal rigidity of the Fcar when beat on. As it they got in way some racers removed them and found other things acting up. Turns out the engineers arent so stupid. by triangulating the sheet metal and stiffening up the radsupport bushings actually tie the dog house and subframe to the body structure.
Also conducive to handling are rear compartment braces that tie into the firewall.
This was a surprise to me, but my friend had a car that had been road raced with that type as well as fender braces. he had them in trunk, After we reinstalled doghouse, the car felt kind of floppy, installed the fender braces, big difference (it already has poly bushings for rad support) we installed the rear fender/firewall tie back in and whoa, BIG difference.
Its all structure and all triangulating to the car,,,and heck if they look good go for it!
Hotchkis
02-17-2011, 06:40 PM
Hi Rfalker1,
Thanks for buying the Hotchkis Fender Braces.
Once you've installed them, you’ll probably feel a difference, but the reasoning behind their development is to tie the front sheetmetal together by triangulating the front fenders to the radiator support. This adds much needed rigidity to the car, without a lot of added weight.
Twentyover
02-17-2011, 07:35 PM
.....Also conducive to handling are rear compartment braces that tie into the firewall.
Having some trouble visualizing what you're describing.How do the rear compartment braces tie into the firewall? Through the pass compartment? You can see my confusoion.
zbugger
02-17-2011, 09:46 PM
The rear firewall. That panel behind the back seat. Something like this works well on 2nd gens too.
The Stickman
02-18-2011, 07:57 AM
My B-body wagon has them.
Randy67
02-18-2011, 10:35 AM
They help on A-bodies as well. My 73 Monte Carlo had them, looked just like the 2nd gen F-body ones.
DarkoNova
02-18-2011, 11:24 AM
So basically, every car other than Novas had them. Thanks, GM!
MarkM66
02-18-2011, 06:12 PM
Well no. All early A bodies (the ones anyone cares about :wink: ) didn't have them.
Like you said, all Nova's. etc.
I had a '68 Camaro that didn't have them, I then installed them and never could tell a difference. But it was just a driver.
rfalker1
02-24-2011, 08:31 AM
Wow thanks for all the input, I had been away recently and couldn't respond but i feel as if I have just went to school, and learned all about triangles progressing further with my mechanical engineering degree. Lol But seriously thank you, it does make a lot sense that they would help eliminate front end sheet medal vibration, which would allow for a smoother ride. I shall post plenty of pictures whenever I get them installed!!!!! after I drop this 383 in of course
