View Full Version : How to disassemble this Delphi connector?
Mkelcy
02-12-2011, 03:24 PM
I need to take this thing apart to run my drive by wire cable though the firewall. Any hints. I've been using a pick in the small hole to no effect.
https://static1.pt-content.com/images/pt/2011/02/connectorsmall-1.jpg
brans72
02-12-2011, 03:28 PM
you have to get the purple cover off first but do not destroy it and then you can see then locks you need to lift to remove wires.
Mkelcy
02-12-2011, 03:30 PM
Thanks, that did it.
brans72
02-12-2011, 04:25 PM
I don't anwser alot of things on here due to me not feeling 100% confident but I have delt with them before so Figured I would lend a hand! Glad it worked out for you. Tip for you alot of connectors either have that or a lock that is made in to the connector that you have to release before you can get to internal lock to release wire. Brandon
Mkelcy
02-12-2011, 05:20 PM
Do you know what Delphi series that connector is? I may need to shorten the cable and, if I do, I'll need to get some of the terminals.
As for not answering unless you're certain, that's a terrific quality to have.
CarlC
02-12-2011, 05:38 PM
That looks like a Delphi GT280. I have some terminals, both male and female, and the crimping tool. It's the same type of terminal that's used for the fuel modules. If you're in no big rush I should have most everything ready for your tank in 3-4 weeks so when you come out we can take care of both.
Mkelcy
02-12-2011, 05:45 PM
That would be great. Thanks.
64duece
02-16-2011, 05:04 AM
Thats a GT150 commonly used on dbw pedal assemblies. It also uses the smaller seals not the standard ones for GT150.
CarlC
02-16-2011, 10:02 PM
Thanks Dennis! It's kinda hard to gauge the size.
EFI69Cam
02-19-2011, 12:39 PM
eficonnection.com has all of these connectors and terminals. Here's this one http://www.eficonnection.com/eficonnection/ConnectorDetails.aspx?ItemId=523
His prices are a bit steep, but since he has the fitment info for each connector on the page it makes the extra worth it.
