View Full Version : SBC, related accessories & Centerforce T56 flywheel
ed1le
02-04-2011, 07:23 AM
SOLD-355 – 010 casting, 2-bolt main
Hypereutectic Flat tops, Powerhouse remanufactured small valve heads
Crane cam
Crane Blazer 1.5 roller rockers
Edelbrock RPM intake
Noisy Gear Drive
Edelbrock 2-piece aluminum timing cover
7qt deep sump oil pan & hi-volume oil pump
Billet tall valve covers & water neck
New stock long water pump
Under 500 miles on engine. My buddy built this a few years ago for his daily driver but sold the car before installing it. It was installed in his brothers truck for break-in and driven locally a few times but that was it. I bought it off him and installed it in my Skylark but never fired it. Buying an LT1 so it needs to go. I have kept it oiled and turned it over by hand regularly to keep it lubed. Don't recall cam specs but in the 220/.460 range I believe. I do know he was shooting for 300hp & 375ft lb and is very meticulous w/ his builds. asking $600-SOLD
https://static1.pt-content.com/images/pt/2011/02/101_1946-1.jpg
https://static1.pt-content.com/images/pt/2011/02/101_1947-1.jpg
(old edelbrocks on it now were just to make sure the good ones didn't get scratched when installing)
https://static1.pt-content.com/images/pt/2011/02/DSC02396-1.jpg
Centerforce flywheel, #CTF-700107 for t56/2-piece sbc
Bought w/ approx. 8K miles (I believe from someone on here or LS1tech.com), I had it resurfaced, hasn't been used since. Retails for $410, asking $300
https://static1.pt-content.com/images/pt/2011/02/101_1950-1.jpg
Summit 600 carburetor - New, installed but never run. Still have box & everything that goes with it (cost $260). (ProComp billet spring/cable bracket & Spectre dual feed fuel line w/ gauge are sold) asking $225
https://static1.pt-content.com/images/pt/2011/02/101_1944-1.jpg https://static1.pt-content.com/images/pt/2011/02/101_1945-1.jpg https://static1.pt-content.com/images/pt/2011/02/101_1949-1.jpg
SOLD-Summit 100 amp 1-wire alternator, powder coated black w/ Summit billet brackets - New, alt was $80 & brackets were $40, asking $80-SOLD
https://static1.pt-content.com/images/pt/2011/02/101_1941-1.jpg
-SOLD-Type II P/S pump w/ reservoir w/ brackets & aluminum pulley - pump is new, brackets & pulley have some nicks but probably from sitting around, bracket missing a couple bolts as well but nothing you couldn't get from a hardware store. Pump alone retails for $150 and Summit has bracket for $110 bought last month from someone on LateralG.net for $150, for use w/ long pump, asking $150-SOLD
https://static1.pt-content.com/images/pt/2011/02/101_1936-1.jpg
SOLD Summit Billet water pump (single groove-$36 retail) and Crank (double groove- $50 retail) pulleys - new, asking $50 SOLD
https://static1.pt-content.com/images/pt/2011/02/101_1942-1.jpg
SOLD-Summit billet water pump (double groove-$50 retail) and Crank (triple groove-$53 retail) pulleys –new, asking $50-SOLD
https://static1.pt-content.com/images/pt/2011/02/101_1937-1.jpg
SOLD-Jegs mechanical fuel pump (80gph) - new, installed on engine but never run, cost $50, asking $30-SOLD
https://static1.pt-content.com/images/pt/2011/02/101_1939-1.jpg
SOLD-Procomp HEI w/ coil & cap - new, cost around $100, asking $75-SOLD
https://static1.pt-content.com/images/pt/2011/02/101_1951-1.jpg
Will post pics of everything tonight. Prices DON'T include shipping. Thanks.
ed1le
02-04-2011, 01:47 PM
Updated w/ pictures. Additional pics available upon request.
L8869
02-04-2011, 01:56 PM
PM sent
ed1le
02-04-2011, 02:12 PM
PM replied
69projectKAOS
02-04-2011, 02:21 PM
pm sent
ed1le
02-04-2011, 02:41 PM
PM replied
67Malibu
02-04-2011, 06:09 PM
PM sent
wellmaintained
02-05-2011, 08:03 AM
Payment sent
ed1le
02-05-2011, 02:14 PM
Received, thanks! Will ship first thing Monday.
ed1le
02-06-2011, 07:59 PM
Carb & Flywheel still available. Everything else is sold.
ed1le
02-07-2011, 11:04 AM
flywheel sold...only carb left
