View Full Version : Looking for 700r4
spacepirate
02-03-2011, 08:48 PM
Hey guys,
I know some of you have swap to bigger and better things but I was hoping someone has a 700r4 lying around. Looking to hook it up to a 350 sbc.
Kamikaze Sy
02-04-2011, 10:37 AM
Where are you located?
I have a 700R4 but would probably want to have it gone through for any performance applications
It came out of a running GM TBI truck.
I'm located in Northern California.
spacepirate
02-04-2011, 11:03 AM
Yeah, I'm kinda looking for a good to go set up but thanks.
Kamikaze Sy
02-04-2011, 02:16 PM
No Problem, Good Luck!
tazzz25906112
02-04-2011, 07:08 PM
I have a professionally built 700R4 that is one season old (2,000ish miles I'd guess,, biggest trip was Toronto to Wisconsin Face off event and then local driving only ) in a street 1970 383ci Z28 clone with a good/brand name converter (so I was told by the Trans shop I can find out) that works great for street driving..... I'm changing the car over to a new 5 speed Keisler RS600 because I'm not into an auto on the street for daily driving,,,, it's just not my bag...
I initially did the car with an auto thinking my youngest son couldn't drive standard,,,,, boy did he surprise me when he hoped in one of my other cars and starting driving a standard like he'd been doing it for years right off the hop.... $1,500 cash firm for the transmission and converter (will not separate) delivered to the El Toro field in California while I'm out at the event.....
spacepirate
02-06-2011, 08:25 PM
That's a bit too much. I can do very close to that brand new but thanks for the offer.
chariotss
02-20-2011, 10:54 AM
have a nice 700R4 out of a 86 Iroc. Was on a tuned port motor
vette427-sbc
02-20-2011, 10:57 PM
where are you located? I have a worked over 700 for sale:
700r4 Trans...Professional rebuild by Ziggy's Transmissions in NJ less than 15,000 ago. Rebuild included:
New seals, gaskets, teflon and o-rings
New filter
Hardened Transgo pump rings
New .471 boost valve & sleeve
Raybestos Pro Series 2-4 band
Rabestos Heavy Duty 3--4 Z-Pak
Shift Kit
Hydraulic lock-up
Corvette servo
Corvette governor
Hardened sun shell
020 Valve & sleeve
New BW rear roller set
Heavy Duty 2500 stall speed converter
Complete bolt in set-up includes
168 tooth flexplate (came off of a 1pc rear seal block)
trans/converter dust cover
tv cable
TCI custom tv cable brackets for correct cable operation with a Holley carb
dipstick and tube
Hurst ratchet shifter complete with cable, hardware, handle, ball and console
yoke for a 700r4
finned aluminum tube style trans cooler
trans cooler hard lines for a tri-five chevy
**Yoke and custom tv cable carb bracket are not pictured.
This set-up has less than 15,000 miles on it.
https://static1.pt-content.com/images/pt/2011/02/700r4parts-1.jpg
spacepirate
02-22-2011, 04:35 PM
I actually found one. Thanks.
steinepstein
02-22-2011, 07:26 PM
I have one, never ran, with all the best stuff, including the beast shell. I'll let it go for a good price if you are looking for other options.
Jon
