4086D9
01-24-2011, 10:43 AM
For sale...perfect shape...maybe 2000 miles on it total.
GM 2 bolt 400
Scat 9000 crank
Scat I-Beam 5.7 rods/ARP bolts
Probe Forged pistons..-15cc dished
AFR 195 heads...68cc....10 to 1 comp ratio
Comp XS274S solid flat tappet
1.6 comp pro magnum roller rockers
Comp cromoly pushrods
Port matched Vic Jr intake
Holley 750 3310...rear metering block conversion and quick change sec housing
billet water neck
GM performance valve covers...tig welded breather stands
Aluminum HV water pump
billet pulleys
Carter 172 mech fuel pump
billet alt bracket...no alt
billet ps bracket...no ps pump
MSD wires..no dizzy
energy poly motor mounts
Moroso 7 qrt kickout pan
billet dip stick
Shortblock was built by Smedding performance in Sacramento,ca. This set up runs perfect and is super streetable. Goes 11.8's at 115+ with a tight converter and 3.50 gears! Why am I selling?? I have the itch to try a BBC!
I will take $3500 FIRM...no low ballers. Local pick up only in Stockton,ca. Still in car!
209-609-4133.
__________________
GM 2 bolt 400
Scat 9000 crank
billet water neck
billet pulleys
MSD wires..no dizzy
billet dip stick
209-609-4133.
__________________
