View Full Version : 17x9.5 fronts on a 69 nova
Conrad283
01-20-2011, 02:35 PM
So I got my wheels today (ZR1 replicas), and they're barely touching the steering arm. They're also hitting the UCA.
Is this something that can be fixed with spacers?
I may have an out because the wheel company listed the wheels as brand new, unopened, and as they would come from the company. Well, not even close. Only one wheel was brand new, two had been mounted with tires, and the last wheel ... It said "OUT OF ROUND" on it. I mean, how can you send that to a customer ... Oh well. I'm waiting for them to call me back. /rant.
Wondering if spacers would help.
Nessumsar
01-20-2011, 02:44 PM
You can make those wheels work just fine. I had 17x9s with 4.5" BS and 255s; they came very close to the steering arm, but did not rub on the UCA or frame. They did however rub on the outer fender lip, right where the middle inner-fender mounting bolt is. I just removed the mounting bolt and it is a pretty friendly surface. I believe those wheels need a 1" spacer IIRC.
ssmike
01-20-2011, 02:46 PM
Sounds like you need my Wayne Due subframe! (its gonna be for sale!)
Conrad283
01-20-2011, 03:28 PM
I do need it, but I can't afford it
Thanks for the info Jon
Nessumsar
01-20-2011, 03:38 PM
https://www.pro-touring.com/showthread.php?75325-looking-for-3rd-gen-nova-on-zo6-c6-wheels
ssmike
01-20-2011, 06:37 PM
For a fellow Nova guy, I can do payments!
johnny68
01-20-2011, 08:07 PM
woo woo woo hang on a minute mike whats the deal with your car why you selling the front end
john
Conrad283
01-20-2011, 09:20 PM
https://static1.pt-content.com/images/pt/2011/01/orly-1.gif
LS1NOVA
01-27-2011, 10:34 AM
An 8" is as wide as you can go with a stock subframe and still maintain a low ride height. If you want the ride height stock or higher than they may fit but look like a 4X4.
Nessumsar
01-27-2011, 10:51 AM
I beg to differ.
Apogee
01-27-2011, 12:08 PM
I'll agree with Nate that 8" is as wide as you can easily go without having to tweak anything else, but I've seen 10 inch wide wheels under first-gen F-body and 68-74 X-body applications, so where there's a will, there's a way. You just can't be scared to do some cutting, welding and custom fabrication to make it happen...and you might need to 3-point that turn into a parking space, but no worries, it's about the journey, right?
Tobin
KORE3
