View Full Version : English Wheel Build
ccm399
01-19-2011, 07:25 PM
Hi all,
I posted a couple pics of the E-Wheel I have been working on and Aronhk_md mentioned I should post some pics over here for you guys to check out.
So here you go!
I did not take very many pics the first day so these are a little far into the project.
The Frame:
https://static1.pt-content.com/images/pt/2011/01/DSC_1186sm-1.jpg
Another angle:
https://static1.pt-content.com/images/pt/2011/01/DSC_1187sm-1.jpg
On the bench locating the lower anvil holder:
https://static1.pt-content.com/images/pt/2011/01/DSC_1190sm-1.jpg
Upper Anvil Holder:
https://static1.pt-content.com/images/pt/2011/01/DSC_1191sm-1.jpg
Upper Anvil Axle I machined up:
https://static1.pt-content.com/images/pt/2011/01/DSC_1192sm-1.jpg
ccm399
01-19-2011, 07:29 PM
Upper holder assembled:
https://static1.pt-content.com/images/pt/2011/01/DSC_1193sm-1.jpg
Location the lower holder for final welding:
https://static1.pt-content.com/images/pt/2011/01/DSC_1200-1.jpg
More location going on:
https://static1.pt-content.com/images/pt/2011/01/DSC_1199-1.jpg
Almost finished product:
https://static1.pt-content.com/images/pt/2011/01/DSC_1201-1.jpg
Broken down for some etching primer:
https://static1.pt-content.com/images/pt/2011/01/DSC_1207-1.jpg
And finally some metal I shaped with her:
https://static1.pt-content.com/images/pt/2011/01/DSC_1205-1.jpg
One more:
https://static1.pt-content.com/images/pt/2011/01/DSC_1203-1.jpg
aronhk_md
01-19-2011, 07:44 PM
Welcome Chris!......I think its very cool and hope the guys here think so too. :D
parsonsj
01-19-2011, 08:09 PM
Lovely work!
ccm399
01-20-2011, 03:48 AM
Thanks guys. I can't wait to post some pics of actual panels I worked with it.
Chris
craigs73
03-14-2011, 10:09 AM
thats neat where did you get the wheels? did you put it on its own stand and what do you think the total cost
ccm399
03-15-2011, 08:22 AM
Howdy,
I got the anvils form HF. Would NOT suggest going that route to anyone though. I spent the better part of an afternoon standing in front of a crank grinder at Medina Mountain Motors grinding the wheels round and polishing them. I would go with Hoosier anvil if I were to do this again. I may end up with a set of their lowers before this is all done.... we'll see.
As for costs:
Steel 135.36
Hardware 14.80 My bolt selection isn't what it used to be!
Axle and Adjuster Material 9.00
Upper Anvil 41.54
Lower Anvils 95.85
Total 296.55
This is a "benchtop" model and the legs shown in the pics are the ones I am currently using. I may build some floor mount legs for it soon though. I don't have a ton of room in the ol' garage so the wheel is mounted to a bench in my basement. I'll have to post of some additional pics sometime. It still need final painting but it is all "finished".
Chris
ccm399
03-15-2011, 08:26 AM
Oh, I almost forgot, I spent another $40-50 on Bearings for the HF upper wheel (I told you I would not recommend these...) and the torrington needle bearing setup for the upper adjuster.
So total would be closer to $350 all said and done.
67blacklist
03-23-2011, 05:04 PM
looks a lot nicer that many of the "hobbyist" models I've seen for sale. Quick question, can you adjust pressure on the fly so to speak or do you have to stop and adjust it with wrenches every time?
ccm399
03-24-2011, 05:15 AM
Hi there,
I really need to snap a couple pics of it all finish assembled. I made a hand wheel for the adjuster so yes I can adjust it on the fly. It's pretty stout, the main frame is 3x5x.250. She is NOT light by any means. I doubt I could lift it up onto the bench all assembled without help. Good thing it comes apart pretty quickly.
I'll get some additional pics asap.
Chris
67blacklist
03-24-2011, 08:37 AM
thanks, a couple details on the tensioner would be awesome too if you don't mind, I've been looking for a simple and robust way of handling that.
ccm399
03-24-2011, 09:50 AM
No problem,
I used 4x4x.250 tubing for the outer shell and 2x2x.250 for the quill. Inside there are four 1/4 thick plates of steel with 1/4 UHMW plastic glued to them. Two are 1 7/8" wide and 9" long and the other two are 3 /2" wide and 9" long. I welded 4 small tabs to the outer housing to hold the two thinner plates in the adjuster.
I used 1" all thread for the adjuster itself. I welded a nut into the 2x2 quill and then welded another nut to the all thread (red loctite probably would suffice). After that I simply drilled a 1" hole in the upper plate and welded it to the housing. Then all you have to do it adjust the allen bolts that are threaded into the outer housing. This design is VERY robust and there is NO slop what so ever. I cannot take credit for the design though as I found the info over on all metal shaping. They are a very helpful bunch over there and anything you would like to know about building an E-Wheel is over there. http://www.allmetalshaping.com/forumdisplay.php?f=29 you will probably have to create an account to see much though. Not to worry it is free.
Chris
