View Full Version : Straight pitman arm 600 box, is there one?
dontlifttoshift
01-19-2011, 08:02 AM
Looking for a straight pitman arm for a 600 series steering box preferably without a rod end in it. A 6" center to center length would be great but I can make just about anything work. Does something like this exist or do I get to make one?
It looked like an early chevelle would work but from what I can tell they have a bend in it. Also found a 65 - 70 impala arm but it has a kink in it if look at it from the top.
Donny
dontlifttoshift
01-19-2011, 10:23 AM
Never mind, the 65-70 impala power steering pitman arm is straight when installed on the box it has a kink in it to clear something on the impala frame.. It has a slight bend in it upward but it will be fine. The best part....it has the correct taper and is the right size to accept a standard early ford tie rod end. It should work out quite well.
