dadto2jays
01-18-2011, 11:06 AM
good luck with your sale!!!!!
SixD7
01-18-2011, 01:37 PM
Tried sending a couple PM's but not sure if they went thru, they don't show up in "sent" messages so let me know if you did or didn't get them.
dadto2jays
01-18-2011, 03:53 PM
I received both of them.. I pm you back some info and left you a voice mail...
skeeters65
01-18-2011, 07:47 PM
What is that spare tire from??
Maxxam
01-19-2011, 12:09 PM
It looks like a late model GTO spare.
Aloha, very nice car
sent you a PM
Denny
SixD7
01-19-2011, 07:34 PM
Just sent you a few emails with pics.
Skeeter.....Maxxam is right it's a late model GTO with the jack, lug wrench kit from the same model.
SixD7
01-24-2011, 10:13 AM
Bitter sweet feeling but the car is SOLD!!
CKBG69
03-02-2013, 07:42 PM
is car sold?
Sold!
1969 Camaro Tastefully Restored To Be An Awesome Driver With Fuel Injected LS1, Six Speed Manual Transmission, Air Conditioning, Power Windows, New Interior, Upgraded Suspension and much more!
Engine:
LS1 with 5 pin MAF, T56 Six Speed, less than 12,000 miles on engine & trans
Computer reprogrammed for emissions delete and mild performance tune
New fuel injectors with higher flowing screens & bench tested
March pulley serpentine belt system
Drop down intake to pull cold air from below radiator.
New long tube ceramic-coated headers
2 ½” Exhaust with Magna Flow Mufflers turned down in front of rear axle
New fuel tank with pump inside tank
New large aluminum radiator with dual electric fans
Wiring & hoses routed through fender walls to clean up engine compartment
New clutch & slave cylinder
Street & Performance engine harness
American Wire vehicle harness
Battery has high quality welding cable to trunk…better than battery cable
Vintage Air Gen IV A/C & heat that works awesome
New wiper motor with wipers that work
Suspension:
Currie 12 bolt posi with 4:11’s
Hotchkis TVS-Total Vehicle Suspension including springs, sub-frame connectors, front & rear sway bars
SC&C stage 2 suspension kit with SPC adjustable upper control arms, tall upper ball joints
Varishock adjustable shocks
CPP tubular lower control arms
Global West solid sub-frame mounts
Rack & pinion power steering
4-wheel disc brakes, drilled in front, parking brake that works, all new brake lines
17x11 rear wheels, 275 width tires, 17x8 front wheels, 245 width front tires.
Body:
DSE mini tubs
DSE electric hideaway head light motors & doors
New front fenders, bumpers, trim, vinyl, felt, weather stripping
New front floor pans & rear quarters, new emblems
New front core support & rear tail section
Firewall partially smoothed
New front & rear spoilers, new cowl hood, new front valance
New door handles, new mirrors
New head & taillights, side marker lights, blinkers, dash & gauge lights
Dakota digital taillights, blinkers can be set for sequential or solid
Paint looks really good 5’ away but does have flaws, great for a driver or local shows
New vinyl top
Undercarriage is very clean-not a rotisserie restoration
Engine compartment in gloss black, very clean & tidy with color matched LS1 coil covers
All locks; doors, trunk, glove box & ignition are keyed the same
New billet aluminum fender braces
New billet aluminum hood hinges
New billet aluminum trunk hinges
Interior:
Interior has been completely coated with Quiet Car Coating then FatMat was applied on interior….this helped tremendously on cutting down heat and road noise
New Electric Life power windows front & rear
New door handles
New carpet, new correct door panels for power windows.
New upholstered and finished trunk with hidden Optima battery
New gauges, all gauges work including clock in dash
New seat foam in front & rear seats
New Houndstooth seat covers front & rear, fronts are buckets with head rests
Rear seat was corrected to fit for minitubs
New dash pad, pillar pads, visors, sail panels & headliner
New kick panels that block off the original vent holes for quieter, tighter ride
New center console with working gauges
New 3-point seat belts
New tilt column
CD player and speakers
17” GTO Spare tire with jack, lug wrench & wheel chocks
Misc:
Arizona Box A title showing 74,000 original miles, I cannot confirm this is accurate but noteworthy that title says it is.
Basically everything on the car is new, it is an awesome driver and gets attention wherever it is.
Well over $65k invested in this car. I’ll sell for $38,000
I might be interested in these trades; a nice running Nova, SWB-C10, 911, M3 or 335i.
Video: http://www.youtube.com/watch?v=l20PhksuN7k
