Removed user as requested
01-17-2011, 02:00 PM
Hi
Just some feedback from you guys so i have something to keep in mind...
Between a 68-70 RoadRunner and a 68-70 Charger if all being equal in terms of traction, power, chasis setup etc... the only difference being the rear window of the charger having the tunnel problem unless its converted into a charger 500 rear vs the roadrunner which doesnt have the sail panel problem (though the sail panel to me looks good), which one (or how much difference) would there be in top end speed around a circuit and which would be more stable at higher speeds and which would just simply run better and put power to the ground better?
I know this seems like a way out there idea with possibly no real straight forward answer (maybe there is I dont know).
In Short, which would run a circuit better and would the charger need the 500 conversion rear window to be equal or better to the RR or are these 2 pretty much the same with or without the 500 rear on the charger.
If I didn't like the RR I wouldn't be asking this. Also I found down here the RR to be more rare than the chargers so I am kinda thinking "if the RR is overall better than I would sell the charger I got and go with a RR" if they are the same, my childhood memories lean towards the charger so I dunno.
Would any of you know the difference in weight between the 2 or are they pretty much the same weight?
