View Full Version : holly dominator efi
Nothingface5384
01-14-2011, 02:35 PM
Ok, Since I never installed my powerjection and came across the article on the main page.
What would you actually need to fully convert a carbed BOP engine?
holly dominator efi ECU 554-114
universal multi point main harness? 558-104
a throttle body
weld fuel rails and injector bungs onto intake
8 injectors
injector harness 558-200 or 558-204
ignition harness 558-303
plus fuel system(pump/filters,fpr,lines,gauge)
options lcd screen for tuning
am I missing anything?
MrForce
01-14-2011, 06:13 PM
Are you planning to go sequential? Crank trigger and/or sync distributor....
Rob
Nothingface5384
01-14-2011, 06:44 PM
I was planning on using a mallory magnetic pickup disturbutor with an msd 6al 2 digisal programmable box with the powerjection tbi..but this seems to do the same thing with less clutter and actual does it better and more tunability
suggestions?
sequentioanl injection would be nice
Nothingface5384
01-14-2011, 07:20 PM
the boost and methenal plugin will prove to be really useful too..
so with that list and plans for sequentional multi point injection, amd I missing anything?
ps. if this thing could manage to control a 6l80e later down the line, that's be the tits! retro engine with new age 6speed auto :-)
68Formula
01-14-2011, 08:07 PM
Assuming the throttlebody includes an IAC and TPS, and speed desnity (not MAF) you also need the following sensors:
Intake Air Temperature (IAT)
Manifold Air Temperature (MAT)
Coolant Temperature Sensor
Crank Sensor,
MAP Sensor
You'll also need some kind of relay setup to run the pump.
Nothingface5384
01-14-2011, 09:43 PM
ok, sounds good, the pump I have is a fuelab
its need a pwm signal to control the "fuel on demand"v otherwise i'd have to rig up a high/low swithch and do it manualy
So with what i have listed and what you added would be practicaly everything?
Nothingface5384
01-16-2011, 10:20 AM
bump!
andrewb70
01-16-2011, 10:32 AM
Get in touch with Dennis Moore.
http://www.mooreracecraft.com/fuelinjection.html
He has been involved with the new Holley EFI system since it's inception. He can help you sort through all of the hardware that you will need.
Nothingface5384
01-18-2011, 03:41 PM
Thanks andrew, I just shot him an email now!
I dont think the price will be much more then the powerjection i bought, so i can just sell that at a lil bit of a loss and get this for more presise tunning/reliability
