View Full Version : GM A-body power steering kits, Suggestions? CPP?
Nicks67GTO
01-13-2011, 05:49 PM
What do you GM A body guys run for power steering boxes? Does anyone on here have experience with CPP's 500 box power steering kits? Heres an ebay link to it.
http://cgi.ebay.com/ebaymotors/1964-67-CHEVELLE-500-STEERING-BOX-KIT-MODERN-RACK-FEEL-/290308592107?pt=Vintage_Car_Truck_Parts_Accessorie s&hash=item4397bd91eb#ht_2076wt_939
I currently have an old saginaw manual steering box on my 67' GTO and I need to have power steering. Im looking for a reasonably priced, all inclusive kit that will work well with my current factory stock suspension and also work well with a performance suspension upgrade in the future. Any suggestions? Is the CPP kit any good? Is there a good alternative for a better price?
wmhjr
01-13-2011, 09:01 PM
Lee. Lee. Lee.
jocko124
01-13-2011, 10:03 PM
Lee. Lee. Lee.
Seconded. Just installed one on my Cutlass. Have not had a chance to use it yet!
HWYSTR
01-14-2011, 09:27 AM
Lee boxes are very good, though others do compare. Haven't used the CPP boxes, but have used the AGR and the Flaming River billet 'rack' box. I say the rack box if you can swing it, but there's nothing 'wrong' with the AGR.
Nicks67GTO
01-14-2011, 10:39 AM
how much do these lee boxes usually run?
Brad1970
01-14-2011, 10:55 AM
Lee boxes about $545 when I called em summer of 2010 (if I remember correctly), plus $90 for the rag joint. SC&C also can get'em for ya, you may have a longer delay going thru them than ordering direct. I know this cause I asked SC&C about how long shipping would take & I asked LEE how long shipping would take.
PT Goat
01-14-2011, 01:36 PM
I got a brand new AGR box for about $265 shipped a few years back and no complaints at all.
cheaper option but not as nice. Use a grand Cherokee box and a rag joint from an 80's chevy truck. you get a 12:1 ratio 2.5 turns lock to lock and it does not limit turning radius like some of the other stock boxes. You will also need o ring to flare adapters for the steering box.
Nicks67GTO
01-15-2011, 04:22 AM
Really? what year Grand Cherokee? does it bolt in or require a bunch of fab work?? Do you have more details?
Completely bolt in. You need a pitman arm from a power steering chevelle or other a body. It bolts directly to the frame in place of the original. The original power steering box has a radius of 43 degrees and 43 min The Cherokee boxes are all 43 degrees and 45 min
year Code
1992.5 -1993 AL or BT
1994 AL, BT, or PD
1995 JH
1996 KD
1997-98 WK or BT
Steering couplers
1977 thru 1982 Chevrolet and GMC C/K (2 wheel and 4 wheel drive) Pickup Trucks
1977 and 1978 Camaro, Firebird, and Nova
1979 Nova
1983 thru 1986 Chevrolet and GMC C (2 wheel drive only) Pickup Trucks
You will also need fitting adapters
Lee Manufacturing sells small aluminum inserts that can be press fitted into steering gears with metric pressure and return ports. You then can use the original hoses with the 11/16-18 UNS and 5/8-18 UNF nuts and 45 degree flared ends. Since the metric and conventional threads are very close to each other you will find that the 5/8 nut screws very easily into the 16mm port, the 11/16 nut may need a little persuasion but it also will screw into the 18mm port. The face of the Lee insert is cut at a 45 degree angle, so the old hoses will seal against it. There are two different inserts (#40620 – pressure) and (#40630 – return) and he sells them at a reasonable price.
Lee Manufacturing
11661 Pendelton St.
Sun Valley, CA 91352
818-768-0371 (talk to Tom Lee or his wife)
All my info was taken from here http://jimshea.corvettefaq.com/?page_id=5
MonzaRacer
01-21-2011, 04:17 AM
Lee Manufacturing 818-768-0371, bar none the best box for the cash and AGR and other have nothing equal to it, buy once and be ready for fun. I am going to have my Monza box done and my Caprice too.
ed1le
01-21-2011, 05:52 AM
year Code
1994 AL, BT, or PD
1995 JH
1996 KD
1997-98 WK or BT
Steering couplers
1979 Nova
Lee Manufacturing
11661 Pendelton St.
This is the route I'm taking...thanks for posting all the part #'s!
Glad I could help, it is the way I am going also. I just don't have the funds for a $600 steering box. That is money I can spend elsewhere on the car. You should read all of Jim's FAQ before you do it. I was mistaken the Cherokee boxes are 12.7:1 not 12:1. Still better than stock. There are other boxes that will work as well, a few from some years of caprice and a couple other sources.
Red SS
03-14-2011, 10:23 PM
Ditto for the Lee Mfg stuff. I have the full monte (sorry) in my 64 Chevelle convt. & it works great. More $ perhaps but all new stuff & the tech support is the best. They supply Nascar too, so I'm told. Look them up & give them a call, very nice people!
HWYSTR
03-15-2011, 03:42 AM
What's sub-par with the AGR boxes? Curious in what ways the Lee boxes are that much better?
Has anyone tried the replacement type II pumps? I hear they bolt right up, and even firebirdcentral.com lists them as direct replacements?
http://www.firebirdcentral.com/product_p/pow-333.htm
FULMNTE
03-15-2011, 06:00 AM
I bought a brand new GM fast ratio steering box from www.cvsteering.com
Very happy with it, but in hindsight I would probably have saved more money to go with a Lee box...
HWYSTR
03-15-2011, 06:11 AM
The cvsteering box was more than the Lee? You paid more than $600?
