nitetrain4590
01-12-2011, 01:48 AM
Hoping some savvy guys can help me out with this one. This is my SBC 355 for my 69 Chevelle that Im about to build up.
436864368743688
I noticed a good amount of material taken out at the base of my 8th cylinder. I am making an assumption that the material was taken out for clearance of the 6.000 H-Beam Rods, but looking closer, there looks like there might be a hairline crack coming off of the notch. Regardless, the notch and crack are below the stroke line and don't come close to where the pistons travel. So here are my questions:
1. Is this a typical area to clearance for a 350, with a 3.48 stroke and 6" H-beam rods?
2. If this turns out to be a crack after magnafluxing it, can machine shops repair this damage or is it a crazy expense?
3. Could the crack have been caused by an improperly balanced rotating assembly?
4. Lastly, from anyones experience, what kind of power can I expect to get out of this engine with the following stuff:
010 Casting 350 block, 4 bolt mains, bored .030 over
Probe Forged pistons -4cc (10.4:1)
Eagle H Beam 6.000 rods
Scat Cast 9000 series Crank 3.48" stroke
World Products Sportsman II 200 cc Iron Heads with 64cc Chambers as cast
Comp Roller Rockers with Stainless Valves (2.02/1.6)
Haven't picked a cam yet, probably a Comp XE280ish...HR
Edelbrock RPM Air-Gap Intake
Either a Holley 750 or EZ-EFI system
Thanks for any help.
436864368743688
