View Full Version : Richmond 5 Speed
Pzary3233
01-11-2011, 02:36 PM
I've got an extra Richmond 5 speed that I no longer need. I bought it when I thought that I was going to need a new transmission. The previous owner said it shifted well. The gear oil that came out of it looked good, no chunks. It shifts well into each gear on the bench. Currently just resides in a project that I would have to cut the floorboard out of to make it work, so I need an internally shifted transmission.
Also included in the sale is a Hurst competiton plus shifter and Centerforce 26 spline clutch.
Gear ratos: 3.28, 2.13, 1.57, 1.24, 1.00
GM input shaft 26 spline
Asking 1700.00 Shipped.
I will trade for a TKO, TR-3500, Tko-500 or TKO-600 GM Application
Glock 18
02-17-2011, 05:59 PM
Do you still have the Richmond transmission for sale?
Pzary3233
02-17-2011, 06:02 PM
Yes, I do, give me a call 850-294-1841
DVRacer
03-05-2011, 09:25 AM
Can you tell me if you sold your 5 speed trans ???? Thanks.
Dave
Pzary3233
03-05-2011, 09:50 AM
Still have it! If you are interested give me a call.
Ishmael
03-05-2011, 10:07 AM
What did it come out of? Would it work in a first gen without too much surgury?
Pzary3233
03-05-2011, 11:05 AM
It is currently mocked up in a first gen Firebird, you'll need a crossmember and to fab up a shifter offset via David Pozzi's site to use it with a console. But It's a seemless conversion really.
maxxer442
04-17-2011, 11:28 AM
Do you still have the richmond 5 for sale? Would it be an easy sway into my 69 442?
Pzary3233
04-17-2011, 05:36 PM
Yes, just swapped it into my 68 to make sure everything was 100%.
You'll need to fabricate a crossmember and get a bop bell housing.
Otherwise it is bolt in without a console. You'll have to get creative to get it to work with a console.
knger
04-17-2011, 07:35 PM
i have a saginaw on my pontiac 400 will this work with the same bell housing/clutch assembly, granted the splines are prob dif
maxxer442
04-18-2011, 04:23 AM
Sounds good. I'm sending you a PM!
Pzary3233
04-18-2011, 08:44 AM
It will work with the bellhousing, you'll just need to swap clutches.
knger
04-18-2011, 09:06 PM
do you know what its rated for? im pushing a few ponies
