View Full Version : 69 camaro project Ga Heat Wave
gasfumes
01-10-2011, 08:06 PM
Project Heat Wave from middle ga trying to pull this rebuild off in the ga heat. Home build in a two car garage. Pictures before wreck are below. Now i can go protouring since i have to tear car apart. Car was rolled once has damage to Qtr panels, roof, hood, and front fender.
LaMaR-
01-10-2011, 08:10 PM
Good luck on the build cant wait to see updates
gasfumes
01-10-2011, 09:43 PM
Here are a couple pictures of Qtrs panel and roof skin off the car. Also going back with dse mini tubs, new trunk pan, floor pan and firewall.
gasfumes
01-11-2011, 05:44 PM
Here is picture of trunk pan and tail panel removed.
19,69camaro
01-11-2011, 08:57 PM
Well at least there isnt anymore expanda-foam in the quarters. Good luck on your project. Any hints on powertrain or suspension
cobraguy65
01-12-2011, 05:31 AM
Looked like a sweet ride before the accident. Nice project, should be even better when done.
gasfumes
01-12-2011, 03:19 PM
Thanks guys for comments car looked okay it was a 20 footer looked better from a little distance.
Parts that i have so far are
Ls2 engine from 06 corvette
t56 trans from 06 gto
S&P engine plates
dse mini tubs
stainless work header
Parts that I needs are
oil pan, wiring harness, fuel tank, suspension up grades, and brake up grades
Z06vet
01-12-2011, 04:14 PM
Damn you blew that thing apart! Love watching these metal work threads, since I am clueless. Looks pretty clean on the inside. Looking forward to watching your build. Scott
protouring70
01-12-2011, 04:19 PM
WOW, looks like you have your hands full!! Good luck with build!
gasfumes
01-12-2011, 06:52 PM
Here are a few pics of car after the wreck which was rolled once.
,43711,43712,
gasfumes
01-12-2011, 07:17 PM
Pics of trunk pan and dse mini tubs installed
gasfumes
01-17-2011, 10:17 AM
Has any one used gmpp wiring harness thats can give response how it all worked out?
gasfumes
04-25-2011, 04:30 PM
Update finally finished sheet metal both qtrs panels, tail panel,roof, floor pan, trunk pan, firewall,and dse mini tubs
463784637746376
gasfumes
04-28-2011, 06:40 PM
Ordered a few parts
* mgw shifter
* tremec offset shifter adapter for t56
* gmpp wiring harness kit for ls2
* subframe made by Scott Mock
rfalker1
05-01-2011, 11:47 AM
loved the ride before the wreck!!!, good luck on finishing it strong
gasfumes
10-31-2011, 07:52 PM
Subframe frome Scott Mock very pleased with the quality
gasfumes
10-31-2011, 07:57 PM
Installed the c5 upper and lower control arms
gasfumes
10-31-2011, 08:04 PM
Subframe
85coupe50
10-31-2011, 08:08 PM
Great looking subframe. Looks like you have had your hands full since the wreck. Coming right along though.
CruizinKev
11-01-2011, 04:14 AM
oh yeah good work so far! :twothumbs
1968CamaroSS_Sam
11-01-2011, 11:41 AM
Car looked great. Now looks like it will perform as well as it looks. Great job so far.
gasfumes
11-01-2011, 03:09 PM
Wheels by Forgeline 19 * 10 fronts 285/30/19 tires nitto
19 * 12 rear 345 /25/20 tires nitto
gasfumes
11-01-2011, 03:13 PM
Engine : Ls2
Trans : T56
Forgeline Wheels
gasfumes
11-02-2011, 08:20 AM
Ricks Vaporworx tank on the way.
joeko23
11-02-2011, 10:30 AM
Nice progress
gasfumes
11-21-2011, 02:01 PM
vaporworx tank looks awesome will post pics in couple days
