View Full Version : can a rotomaster turbo turbine housing be switched with another make?
alfatwin
01-09-2011, 01:43 PM
So, I have a rotomaster turbo a/r 60 comp, .58 turbine. my question for any rotomaster experts is, can you use a garrett turbine housing on a rotomaster without modifications? Finding info on RM turbo casting numbers (these are old) has been somewhat of a challenge, to put it lightly. I wish to match the one I have with another for my sbc to keep the costs down. any help would be appreciated, thanks.:cheers:
keibar
06-09-2011, 12:38 PM
Yes Rotormaster can be interchangerbl with Garrett parts. If you have a Rotormaster part number for the turbo or the part you are looking for. Give them to me and i will do a cross referance to Garrett for you and give you the Garrett equvilent part number.:twothumbs
You mentioned that you have A/R 60 comp and .58 turbine A/R this combonation is normaly a T04B Model.
alfatwin
09-04-2011, 07:35 AM
104295 on the compressor. 04301 on the turbine. can only find a 7 on the bearing case... sorry about the long delay, been a little busy with the brake and steering setup.... thanks in advance- august
