View Full Version : Valspar
tb8125
12-22-2010, 03:21 PM
Has anyone ever use this VALSPAR refinishing I have some epoxy primer/sealer..... is it any good
Jim Nilsen
12-22-2010, 04:50 PM
Valspar makes all of the house of color base products for them last I heard still. You can't beat Valspar products when it comes to coatings.
what is it you are using it on?
tb8125
12-22-2010, 08:16 PM
I have a 81 trans am that I want to do the bodywork then epoxy primer... I stripped the car to bare metal.... I never used this before and want to know if this is the way to go... Should I use this on bare metal after the bodywork has been completed...also can I spray another type primer to like a high build (to block and sand)......
elitecustombody
12-22-2010, 09:04 PM
I've used Valspar line for long time till Kemperly came into town and my usual distributor lost Valspar,so I quit using it,never had any problems,loved their ColorFill tintable sealer,can't comment on the epoxy you got,get product tech sheet to get all the instructions and what this product is compatable with
H2Ogbodies
12-23-2010, 10:06 AM
Epoxy primer/sealer is to be used as a topcoat over your finishing bodywork to seal it from moisture-it's not meant to be used as a bare metal primer. You need to use an etching primer which gives it a phosphorous coating which allows high build primer to "stick" to it. Then, you'll want several medium coats of high build primer to start working/blocking with.
After you get your initial blocking done with 320 grit, spray a couple of light-medium coats of primer surfacer/sealer to "seal in" your finishing work, then lightly block with 600 grit and you're ready for your initial topcoat. This is an overview of the process-I'm doing a base/clear, 2-tone finish on a customers 79 Monte which I thought about doing a step by step process....there's alot to a show quality paint finish.
