View Full Version : Upgrade of a Firebird -68
RamAir
12-19-2010, 11:54 AM
This is my project, a Firebird 68. I needed to replace the old 400 RamAir III engine and after some thinking I decided to go with a LQ9 (LS2 with Iron block)
https://static1.pt-content.com/images/pt/2010/12/1b-1.jpg
https://static1.pt-content.com/images/pt/2010/12/DSC_0577-1.jpg
The two things that was difficult was the headers that I made and the harness. I decide to make a new harness so it was possible to stash the PCM.
https://static1.pt-content.com/images/pt/2010/12/5-1.jpg
https://static1.pt-content.com/images/pt/2010/12/4b-1.jpg
https://static1.pt-content.com/images/pt/2010/12/P3210025-1.jpg
RamAir
12-19-2010, 12:15 PM
I also made a new electric system for the car so it could handle all new function that is going with the new engine. All cables was marked with shrink tubes labels.
https://static1.pt-content.com/images/pt/2010/12/9-1.jpg
https://static1.pt-content.com/images/pt/2010/12/11b-1.jpg
https://static1.pt-content.com/images/pt/2010/12/10-1.jpg
https://static1.pt-content.com/images/pt/2010/12/11-1.jpg
https://static1.pt-content.com/images/pt/2010/12/12-1.jpg
Omnivec
12-19-2010, 12:31 PM
Ok it had the old motor and now it has new motor. Nice thread
RamAir
12-19-2010, 12:44 PM
When this was done it was time to work with the suspension. I like the DSE suspension but it is rather expensive when you have to send the parts to sweden. So I made my own.
https://static1.pt-content.com/images/pt/2010/12/13-1.jpg
https://static1.pt-content.com/images/pt/2010/12/14-1.jpg
https://static1.pt-content.com/images/pt/2010/12/19-1.jpg
https://static1.pt-content.com/images/pt/2010/12/20-1.jpg
https://static1.pt-content.com/images/pt/2010/12/16-1.jpg
RamAir
12-19-2010, 12:50 PM
The suspension is a copy of the DSE but with some minor changes, like the possibility to adjust ride height.
https://static1.pt-content.com/images/pt/2010/12/P1070059-1.jpg
https://static1.pt-content.com/images/pt/2010/12/P1130087-1.jpg
https://static1.pt-content.com/images/pt/2010/12/18-1.jpg
https://static1.pt-content.com/images/pt/2010/12/23-1.jpg
https://static1.pt-content.com/images/pt/2010/12/22-1.jpg
RamAir
12-19-2010, 12:59 PM
With better suspension I want larger tires so I mini tubbed the car. This was done with excelent DSE part. I also narrowed the rear end, the moser axels are from the Buick GN -87. I withdrawed 100 mm from the housing.
https://static1.pt-content.com/images/pt/2010/12/27-1.jpg
https://static1.pt-content.com/images/pt/2010/12/28-1.jpg
https://static1.pt-content.com/images/pt/2010/12/29-1.jpg
Checking the straightness with laser, it was not straight after the welding. It is now.
https://static1.pt-content.com/images/pt/2010/12/IMG_1653-1.jpg
RamAir
12-19-2010, 01:14 PM
This is the result. Next thing will be to change to better tires, will go with the VW V48/Michelin PS2 335/35-17.
https://static1.pt-content.com/images/pt/2010/12/IMG_1685-1.jpg
https://static1.pt-content.com/images/pt/2010/12/IMG_1692-1.jpg
https://static1.pt-content.com/images/pt/2010/12/31-1.jpg
https://static1.pt-content.com/images/pt/2010/12/IMG_0022-1.jpg
rohrt
12-19-2010, 02:16 PM
WOW! Nice fab work on the rear suspension. Did you have someone cut those with a flow jet? I have never seen the laser trick on the rear.
dmc69
12-19-2010, 02:49 PM
awesome work on the rear end!
RamAir
12-20-2010, 06:03 AM
No, it is cut with a power jig saw and hole saw. It works excelent but time consuming. I like to do everything by my self.
The best way to check straightness is of course by using a straight bar but then you have to remove the diff. I did not have the time to do so. There is a little dish in the end of the axel shaft that makes it possible to check the straightness in the center of the axelhousing. Then I checked the straightness at the end of the housing.
RamAir
12-20-2010, 01:42 PM
Here some more photos from the fab of the rear suspension. Just before the winter arrived here in stockholm I changed the UCA and LCA. I am now runing Poly bushing from AM instead of Uniballs. Did not like Uniballs.
https://static1.pt-content.com/images/pt/2010/12/P1100074-1.jpg
https://static1.pt-content.com/images/pt/2010/12/IMG_1563-1.jpg
https://static1.pt-content.com/images/pt/2010/12/IMG_1566-1.jpg
https://static1.pt-content.com/images/pt/2010/12/IMG_1584-1.jpg
https://static1.pt-content.com/images/pt/2010/12/IMG_0034-1.jpg
RamAir
12-20-2010, 01:55 PM
I did not mention that I started the suspension work with a complete drawing so it was posible to simulate the function. This was the final drawing.
https://static1.pt-content.com/images/pt/2010/12/RearSuspensionFirebirdV4-1.jpg
bonecrrusher
12-20-2010, 03:21 PM
Wow - hand made suspension parts - love it!
T_Raven
12-20-2010, 06:11 PM
I like how you used the laser to check the housing, I've seen the bars and bushings for sale around $500 but I figured it could be done with a laser like you did it.
69face
12-20-2010, 10:07 PM
great job!
berres
08-28-2011, 02:12 PM
Wonderful car, amazing job! Looking forward to some updates :)
Hunter68
08-28-2011, 04:50 PM
very nice fab work!
LeighP
08-28-2011, 05:09 PM
Wow, great home fabrication skills....very nice work!
I like that idea of the electrical centre.
Ripper
08-29-2011, 01:56 AM
Dammit! I thought I was going to have the most badass Firebird in Sweden, haha!
But now, there's obviously some competiton showing up.
Great build! Gotta have alot of patience if you're using holesaws - I draw my parts and then have them laser cut instead... I like to build cars using white gloves, haha. ;)
(didn't realise you were swedish until I was the text "UPP" on the sheet metal)
BTW, where did you get the electrical parts? Really nice relähållare you've build there. :)
RamAir
08-29-2011, 03:04 AM
Competition is always fun ... I agree that I should use laser o water cutting, next time... I have all the drawings on the computer.
The nice relay holders are from Hella and you can buy the from Mekonomen in sweden. The electric system are now located in the glowbox and the relay can easy be replaced if they fail. All other parts in the electric central unit are from the swedish wholesaler ELFA. I will send some new photos when I have the new wheels (Vintage Works V48). I will also upgrade the brakes during the forthcoming winter,
it will be be Kore3 C6.
CliffS
08-29-2011, 06:50 AM
awesome fab work!
RamAir
09-17-2011, 12:06 PM
So, the summer is over and time start some work on the car. Better brakes are mandatory on a PT car so to day a new Master cylinder/Brake booster from DSE arrived. I will go with the Kore3 C6 brakes but I cant decide if I should invest my money on the AFX-spindle. Help me with the decision, are they as good as some people say.
