View Full Version : Need '67 Vent Window Help
RodDawg
12-19-2010, 09:21 AM
Does anyone have assembly instructions for '67 Camaro vent windows (particularly the pivot stud on the bottom of the window)? I'm trying to re-install and either didn't document the order or can't find it. There are several spacers/washers along with the spring, some type of lock washers, and the nut.
Any help, pics or a diagram would be greatly appreciated.
Rag-Rat
12-19-2010, 02:10 PM
When the stud goes through the frame: Large washer w/slit, then fiber gasket rest on pedestal. On the underside of the pedestal: fiber gasket-then "D" shaped washer that will face the outside of the vehicle when window is open-then spring-then small washer with locking tab-then nut. I will try and sent you a picture.
Do you need a photo ?
Rag-Rat
12-19-2010, 02:53 PM
having problems loading a picture on this thread. send me a PM with your e-mail if you still need a photo.
Rag-Rat
12-19-2010, 03:06 PM
https://static1.pt-content.com/images/pt/2010/12/67vent001-1.jpg
RodDawg
12-19-2010, 03:53 PM
Chris
Thank you very much. I couldn't find this info anywhere in the net.
That is exactly what I needed.
Problem solved!!
