View Full Version : Speedtech lower control arms
johnnymac46
12-19-2010, 07:45 AM
I'm currently attempting to install speedtech LCAs, the problem I'm having is the bushings won't clear my subframe mounts by and 1/8-1/4 inch on the inside.
Is the powder coating that thick? Should I sand the powdercoating off? I don't want to modify the arms for obvious reasons.
Thanks for any help
paul67
12-19-2010, 10:05 AM
have you original lca's can you take a measurement and compare ,I know the original lca can be a pain to fit.Don't forget to slap a load of silcone gel around the bushes .
XLexusTech
12-19-2010, 10:43 AM
common problem... get a piece of threaded rod some washers and nuts... put the nuts and washers on the interior side then then them forcing the frame to open up a bit
Poochie
12-19-2010, 11:01 AM
That's exactly what I had to do to get my Speedtech arms in on my '69 Firebird. Only took a couple of minutes per side to do.
12-19-2010, 11:41 AM
Some go in tight. I have and to use a floor jack to help slide them in. The delrin or poly type bushings don't give like the factory rubber.
Set floor jack under frame, lay the spring pocket into jack plate. Jack up while guiding into bushing slots. You may have to wiggle the arm a bit. Should slide right in. Don't be shy with the lube.
johnnymac46
12-19-2010, 01:43 PM
Thanks for the help ill try it again in the morning ill write my results up
Damn True
12-19-2010, 02:08 PM
Like so:
https://www.pro-touring.com/showthread.php?42059-Introducing-Project-1-2-TRAK&p=460953#post460953
killer69
12-19-2010, 08:31 PM
the instructions actually show the process described above. this is the MOST common problem. the factory sub frames get collapsed during bushing changes over the years. it is not an issue with the control arms.
johnnymac46
12-20-2010, 12:34 PM
Thanks for the help I got them in, it took a few persuasive words but they are in
killer69
12-20-2010, 07:00 PM
:twothumbs
there you go
Bill Howell
12-21-2010, 12:17 PM
Dang it Blake, I was going to suggest a BFH, those fix anything, of course I am a carpenter by trade.....haha
killer69
12-21-2010, 01:15 PM
yea that would have worked also, thanks for the help Bill, we will ad that you our instructions.
