View Full Version : Brake noise?
CHRIS67
12-14-2010, 09:03 AM
Guys I'm hoping that someone will be able to point me in the right direction here. I replaced the pads and rotors in my 05' Silverado, broke the pads in stopping slowly from 30 MPH and everything was OK. I drive the truck 40 miles to work and everything is normal. 20 miles later going home I take a sharp right hand turn at speed and I hear a grinding noise coming from the driver's side. I ride the brake pedal and I can feel it grinding. Corner finishes and the noise stops. Now occasionally I hear a metal to metal grind noise when hitting a bump or sharp right turns over 30 MPH. Does it would like a caliper getting hung up? Or retracting more than it should so the pad is chattering? What do you guys think?
kryptik
12-15-2010, 04:03 AM
Did you apply anti-seize lubricant to the floating caliper pins?
gort69
12-15-2010, 09:13 AM
Wheel bearing?
Rick Dorion
12-15-2010, 09:25 AM
I had that happen on my 68. It was a small pebble that caught between the pad/rotor. It left a slight groove around the disc.
CHRIS67
12-15-2010, 10:16 AM
I figured it out. Wheel bearing.
Apogee
12-15-2010, 04:41 PM
Wheel bearing?
Ding, ding, ding...and we have a winner.
