TCI Engineering
12-13-2010, 10:39 AM
Total Cost Involved would like to officially introduce the Torque Arm suspension for the 3rd gen Nova.
http://www.totalcostinvolved.com/68-72_Nova_Torque_Arm.cfm
NEW '68-'74 Chevy Nova
Rear Torque Arm Suspension
Pro-Touring Style
The TCI Engineering Rear Torque Arm suspension is built for the 68-74 Chevy Nova. TCI Engineerings Rear Torque Arm suspension was designed to eliminate the suspension bind that occurs when cornering using the stock conventional leaf spring suspension. The rear Torque Arm features a slider on the front of the arm that slides for and aft and rotates as the car goes through suspension travel thus allowing the cars handling to be controlled by the coil-over shocks and the rear sway bar with no suspension binding variables.
The kit is a bolt on application except for welding the axle brackets, panhard bracket and optional sway bar brackets on the 3 inch axle housing tubes of a Ford 9 housing. Optional TCI Ford 9 housings come with all brackets installed and heli-arced for a complete bolt in application.
Features & Benefits
New TCI Engineering rear suspension built for the pro-touring and road racing enthusiasts
Increased ground clearance while keeping ride height and center of gravity low
New Complete bolt-on rear suspensions while using most stock holes
Suspensions increases corner carving control
Dramatic improvement on handling
Kit allows for a lower stance
Great rear axle control
Dare to be different on Looks, Style and Performance
What will you receive from this TCI Engineering Product?
USA Made Product
Product engineered from US DOM Steel
36 years of experienced manufacturing and tested engineering knowledge
Better handling and more controlled braking
Comprehensive customer service
Knowledgeable technical staff
Unlimited warranty on fabricated parts
Pricing information can be found in the following attachment
42975
https://www.pro-touring.com/images/misc/pencil.png
-J
Pro-Touring Style
Features & Benefits
USA Made Product
42975
-J
