View Full Version : Inverted flare or -AN fitting for stainless brake lines
gearbanger
11-29-2010, 06:30 AM
I just bought new rolls of stainless line for my car and new stainless inverted flare fitting too, but was wondering if it is easier and/or better to use -AN type fittings?
Bryce
11-29-2010, 07:06 AM
AN does not require a double flare. But it requires a 37 degree flare instead of the 45*. You also need the back up sleeves. I would say its about the same amount of work.
gearbanger
11-29-2010, 08:05 AM
Will a regular flare set work or will I need a hydraulic flaring tool?
Bryce
11-29-2010, 08:10 AM
You should be able to do it by hand. A 37* is easier to make than a 45*
gearbanger
11-29-2010, 09:58 AM
A inverted flare tool is 45 degree, correct?
Bryce
11-29-2010, 10:33 AM
yep!
dipren443
11-29-2010, 11:11 AM
Flaring stainless by hand is NOT fun... A hydraulic tool would make your life a ton easier.
gearbanger
11-29-2010, 11:18 AM
Do you have to use copper washers to get them to seal? If so, where do you get them?
Bryce
11-29-2010, 11:47 AM
I have no issues making double flares in 3/16" stainless tubing using my performance tool kit.
no copper washers needed
Rhino
11-29-2010, 12:41 PM
You got me curious. I'm in need of a flaring tool and was looking around for one made by performance tool. This rather eloquent and learned man doesn't share your experience :2nd:
NEEDED ONE FLARE, AFTER 18 ATTEMPTS GOT 0WING NUT BROKE OFF IN MY HANDCHINA MADE AND TERRIBLE. I'VE DONE THIS HUNDREDS OF TIMESTHIS WAS THE CHEAPEST OVER PRICED JUNK.LESSON LEARNED, SAME PRICE 100% BETTER QUALITY-WAIT TILLMONDAY AND GET ONE FROM [@]
Bottom Line No, I would not recommend this to a friend
1969CamaroRS
11-29-2010, 01:28 PM
Its not that hard with the right tools. Like this Rigid flaring tool:
http://www.amazon.com/Ridgid-41162-Flaring-Tool-Degrees/dp/B0002DOUFQ
https://static1.pt-content.com/images/pt/2010/11/316RZG33JAL_SL500_AA300_-1.jpg
What I used to flare all my stainless lines (some as large as 5/8").
gearbanger
11-29-2010, 06:38 PM
Did you do inverted flares or just single 37 degree. Can you use regular brake line fittings with a single flared 45 degree?
Bryce
11-29-2010, 06:56 PM
You need a double flare 45* with stainless steel line.
Steel can use a single flare 45*.
AN fittings which are 37*, are single flare.
gearbanger
11-30-2010, 06:52 AM
Bryce, are you sure on that 45deg stuff, cause from what I am reading, people are saying the opposite, double on regular steel, and single on stainless. Any insight?
Bryce
11-30-2010, 07:02 AM
Alex,
Stainless is a harder steel than mild steel (normal brake line). With a single flare stainless has a tendency to split down the lenght of the tube. That will never seal.
Saying that, I would never do a single flare unless it was 37*
Bryce
11-30-2010, 07:04 AM
Alex,
Also I have run completely new brake lines on two cars in stainless with no issues and no leaks with double flares.
1969CamaroRS
11-30-2010, 09:35 AM
I had good luck avoiding the stainless from splitting by chamfering and deburring/polishing the ends prior to single flaring 37*.
Bryce
11-30-2010, 09:55 AM
I agree, a 37* is a shallower angle so the SS tube doesnt need to bend as far. But with a 45* single flare will not work on SS.
I just wanted to clarify.
parsonsj
11-30-2010, 10:10 AM
I used 37 degree flares on stainless steel all over II Much. Brake lines and power steering lines. No splits, no leaks. My take that is a double flair is more likely to split (ss fails due to fatigue and a double flare works the metal more).
I do agree that 37 degree flares are better than 45 degrees.
I used this hand tool (http://www.purechoicemotorsports.com/index.cfm/page/ptype=product/product_id=46/category_id=70/home_id=70/mode=prod/prd46.htm) from Pure Choice Motorsports. $90 and I've made dozens of flares from 3/16 to 5/8 in all materials. SS at 5/8 takes effort... but it can be done with this tool.
jp
dipren443
11-30-2010, 04:11 PM
I have the right tools (Have the exact same Ridgid tool)... It is still not that easy. I went through a couple double flare dies doing my lines. Was it possible? Yes. Still not easy.
Mbwicz
12-07-2010, 05:52 PM
I have successfully used a snap-on double flare kit with SS lines. The only time I had trouble is when I did not debur the cut end properly. The trouble I had was uneven flares, I have never split a line by flaring. I think that deburr is a critical step no matter what type of flare you do (single 37, double 45). I have had good luck with supplies from Classic Tube, and I know that they have a hydraulic flare kit ($395), but I think that you will do fine with a manual kit. Make sure that your tubing is meant for brake lines, this is usually a bit softer because of the requirement of double flares.
Mike
gort69
12-07-2010, 08:57 PM
I have found through first hand experience that deburring the end of the tube is a critical step in flaring tubing. I have also found through first hand experience that the most beautiful flare in the world is useless if you forget to slide the flare nut onto the tubing first.
parsonsj
12-07-2010, 10:56 PM
I have also found through first hand experience that the most beautiful flare in the world is useless if you forget to slide the flare nut onto the tubing first.That killed me!!! I have made several hard-lines about 1/2" shorter than I originally intended, if you get what I mean, lol.
jp
