Results 1 to 7 of 7
11-27-2010 #1
- Join Date
- Dec 2009
- Location
- ri
- Posts
- 278
Staggered wheels- any real world handling benefit
I have seen a ton of cars with the staggered wheel set up and was wondering is there an actual benefit in handling or is it just for looks- I was under the impression that 4 identical size wheels would be the most balanced set up. thanks
11-28-2010 #2
New to Pro-Touring
- Join Date
- Jul 2010
- Posts
- 84
When you see a larger diameter tire in the rear as the popular 18" front / 20" rear set up then this is just for looks and you are hurting performance and adding cost. When you see a wider rim in the rear to have a larger contact patch then you are helping performance while improving looks.
11-28-2010 #3
- Join Date
- Aug 2004
- Location
- San Antonio, Tx
- Posts
- 1,193
most race cars run the same size front and rear (not the same size rim width always). they consider this a square set up and most cars handle better like that. when i had my C5Z stock was 17/18 and when i tracked it i ran 18's all the way around. the car felt better to me with the square set up. i even tried it with street tires before i mounted slicks on the rims so it wasn't because i was on r comps.
corvette racing runs 18 x 12.5 (front) 18 x 13 (rear) on my vette i ran 18x10.5 (4 rear C5Z wheels) and on my '69 i'm building i have 18x10 (front) and 18x12 (rear).Instagram: CamaroAJ
11-28-2010 #4try 245/40/18 all the way around on a car with 500+hp ,drive it hard and then get some 345/30/18 out back and try again and let us know what's better
Do what's right,not what's easy
69 Firebird
71 Cuda
98 Supra 6speed white APU
98 Lexus GS400tt widebody
Elite Custom Body
Stefan B.
11-29-2010 #5
