View Full Version : 10 bolt rear end retaining bolt broke
Coursey
11-26-2010, 06:55 PM
The retaining bolt that holds the pin in on my 10 bolt is broke.https://static1.pt-content.com/images/pt/2007/09/mad-1.gifhttps://static1.pt-content.com/images/pt/2007/09/mad-1.gifhttps://static1.pt-content.com/images/pt/2007/09/mad-1.gif
I have tride a screw extractor, but can not get it out.
How do i get this bolt out?
please help
NOT A TA
11-26-2010, 09:51 PM
Did you heat it before trying to remove it? Locktite might be your problem.
BonzoHansen
11-27-2010, 04:26 AM
http://www.nastyz28.com/forum/showthread.php?t=107063
Coursey
11-27-2010, 05:33 AM
It was broke prior to removing it. I found out it happens alot.
68nate
11-27-2010, 05:14 PM
I have removed several of these by hitting the remaining bolt with a hammer and punch several times to loosen the threads and then spin out whats left with a pick. This probably wouldn't work if you've already drilled a hole and used a screw extractor.
Coursey
11-27-2010, 09:03 PM
I got it out today .....but....i had to use a cutting torch, and melt out the pin until it got past the bolt.
BOBBYA312
11-28-2010, 06:00 AM
The old smoke wrench
