Results 1 to 13 of 13
Thread: 315/35/17 on 10" wide rim?
11-17-2010 #1
I've been looking into widening my soft 8's from 9" to 10"... i know that most tire manu. suggest 10.5" min (except bfg drag radial - 10")..
I know the best thing to do is go 11", but when (quoted from a local guy) I'm looking at $75 an inch on each side to get the right offset ($150 per wheel).... multiply that by 4- i'm looking at $600 bucks before tires, which defeats the whole budget wheel thing.... I can justify $300 if i can run a 315 on a 10" .... but not $600 (yes, i'm going to try and fit 315's on all four corners)
Just wanted to know if anyone has done 315's on a 10" rim and if they had any problems... or if you think i should keep the 9" wheel and just run 275/40/17's on all four corners...
Thanks in advance,
-Sean
My 1973 Chevelle "Bad Buzz" build: https://www.pro-touring.com/showthre...velle-PT-Build
