68metal
11-13-2010, 04:25 PM
how do I safely remove overspray from my hood without damaging my paint ?
67 ls1 vert
11-13-2010, 05:10 PM
try clay bar first and get back to us.
justasquid
11-13-2010, 07:54 PM
I think a lot will depend on how much is there and how long its been there. I've had success in the past with just re-wetsanding the paint and re-wheeling it out. If its only a light overspray, it should clean up fairly easy. You just have to be careful and not go through the paint. Also, make sure you have a large, flat sanding block so you are only removing the high spots of the overspray.
Im not sure on the claybar as I've never used one, but its certainly worth a shot before going through the hassel of re-wheeling the paint out.
klean63
11-13-2010, 09:01 PM
If it's just a little overspray the claybar should do the trick
