View Full Version : Ironworks brings No brainer products to market for the Home builder.
ironworks
11-12-2010, 07:29 AM
Well after enough phone calls from you guys here on LAt-g for some of the slick brackets we make for shop projects we finally going to stock some of these parts to sell to the home builder. These brackets are all laser cut and designed with long tabs to be trimmed to fit to your desired shape for the location you choose for mounting difficult parts like a GM LS1 Engine Control Unit. ($45)
https://static1.pt-content.com/images/pt/2010/11/ShopPicsNovember2010028-1.jpg
Or an LS2-LS7 Engine Control unit. ( $45 )
https://static1.pt-content.com/images/pt/2010/11/ShopPicsOctober2010047-1.jpg
We also added a fuse panel shelf that has a tab to mount and GM style fuse panel to also. ( $65 - ECU mount and fuse panel shelf with mounting tab )
https://static1.pt-content.com/images/pt/2010/11/ShopPicsNovember2010009-1.jpg
We have ISIS mounting plates in steel and Aluminum ( $20 buck each )
https://static1.pt-content.com/images/pt/2010/11/ShopPicsOctober2010080-1.jpg
https://static1.pt-content.com/images/pt/2010/11/ShopPicsOctober2010081-1.jpg
Transmission control unit mounting brackets ( $45 for the Unit with mounting holes and 40 for the 2 piece TCI style mount )
https://static1.pt-content.com/images/pt/2010/11/ShopPicsNovember2010019-1.jpg
https://static1.pt-content.com/images/pt/2010/11/ShopPicsNovember2010016-1.jpg
FAST XFI and XIM Mounting brackets ( $45 Each or $55 for the Combo mount)
https://static1.pt-content.com/images/pt/2010/11/ShopPicsNovember2010012-1.jpg
Lokar E brake mounting bracket - ( $45 )
https://static1.pt-content.com/images/pt/2010/11/ShopPicsOctober2010048-1.jpg
All parts that need to be welded are unwelded so you can modify position if desired. Plus all these parts fit in a Flat rate shipping box from USPS. 15.00 ships all that fit in one box
Rhino
11-12-2010, 01:30 PM
Interesting timing. I was just getting ready to design a PCM bracket myself. For that price you can't go wrong.
What fuse panel are you using for the 3rd shot with the newer PCM? Can you use any fuse panel with that bracket, or is it designed with that specific panel in mind?
ironworks
11-12-2010, 02:06 PM
It is designed for the Fuse panel that comes with the GM performance parts harness, But you could drill holes to mount whatever. The flat fuse panel surface is 8.5 x 5.25 with a 1.5" side flange to trim to your desired height. It includes a tab that works with the Gm performance harness.
https://static1.pt-content.com/images/pt/2010/11/ShopPicsNovember2010023-1.jpg
srh3trinity
11-12-2010, 02:39 PM
Very nice and I like the fact that you guys kept the price down for us.
rossmacd
11-12-2010, 11:35 PM
I'll take 5 of the ISIS brackets... how do I buy em?
banzaitoyota
02-09-2011, 08:35 PM
I am interested in 3 ISIS Brackets
andrewb70
02-09-2011, 10:10 PM
Now those are some excellent product ideas at a price that everyone can afford! Nicely done.
garys 68
02-10-2011, 12:27 AM
I'm in too, could you post contact/payment info?
Pooles Mill Rods
09-19-2012, 05:54 PM
Im interested in purchasing one of these brackets. I would like to know how.
dontlifttoshift
09-19-2012, 06:02 PM
You could start here http://www.ironworksspeedandkustom.com/index.cfm/page/ptype=results/category_id=148/home_id=148/mode=cat/cat148.htm
