ironworks
11-12-2010, 07:29 AM
Well after enough phone calls from you guys here on LAt-g for some of the slick brackets we make for shop projects we finally going to stock some of these parts to sell to the home builder. These brackets are all laser cut and designed with long tabs to be trimmed to fit to your desired shape for the location you choose for mounting difficult parts like a GM LS1 Engine Control Unit. ($45)
https://static1.pt-content.com/images/pt/2010/11/ShopPicsNovember2010028-1.jpg
Or an LS2-LS7 Engine Control unit. ( $45 )
https://static1.pt-content.com/images/pt/2010/11/ShopPicsOctober2010047-1.jpg
We also added a fuse panel shelf that has a tab to mount and GM style fuse panel to also. ( $65 - ECU mount and fuse panel shelf with mounting tab )
https://static1.pt-content.com/images/pt/2010/11/ShopPicsNovember2010009-1.jpg
We have ISIS mounting plates in steel and Aluminum ( $20 buck each )
https://static1.pt-content.com/images/pt/2010/11/ShopPicsOctober2010080-1.jpg
https://static1.pt-content.com/images/pt/2010/11/ShopPicsOctober2010081-1.jpg
Transmission control unit mounting brackets ( $45 for the Unit with mounting holes and 40 for the 2 piece TCI style mount )
https://static1.pt-content.com/images/pt/2010/11/ShopPicsNovember2010019-1.jpg
https://static1.pt-content.com/images/pt/2010/11/ShopPicsNovember2010016-1.jpg
FAST XFI and XIM Mounting brackets ( $45 Each or $55 for the Combo mount)
https://static1.pt-content.com/images/pt/2010/11/ShopPicsNovember2010012-1.jpg
Lokar E brake mounting bracket - ( $45 )
https://static1.pt-content.com/images/pt/2010/11/ShopPicsOctober2010048-1.jpg
All parts that need to be welded are unwelded so you can modify position if desired. Plus all these parts fit in a Flat rate shipping box from USPS. 15.00 ships all that fit in one box
