View Full Version : How much RW Hp do you think I will be putting Down?
rfalker1
11-07-2010, 12:04 PM
I am new here and was curious if anybody had an idea about how much power I will be getting to the ground.
I have a 68 camaro with a 383 stroker from blueprint engines. Dyno'd at 405hp and 440lbs of torque. I have hooker super comp long tube headers, a serpentine system, electric radiator kn high flow 3 inch air filter. It has power steering, no AC. A 700r4 tranny with a hughes 2500 stall converter with lockout. A 3:43 rear gear posi and 19 inch aluminum racing wheels. ALl components are new also.
Thanks for any help
robertjra
11-07-2010, 12:09 PM
300 rw
Pro Stock
11-07-2010, 12:16 PM
325-330 rwhp
XLexusTech
11-07-2010, 12:25 PM
typically yo ulose 25% flywheel to wheel through the drivetrain
rfalker1
11-07-2010, 12:47 PM
hmmmm, thanks for the answer, know the only question will be is that enough?
Flash68
11-07-2010, 01:00 PM
300 sounds about right with an auto tranny.... what headers did they engine dyno with? that must have either a very mild cam or very mediocre heads or both to barely put down 1 hp per cube.
rfalker1
11-07-2010, 01:04 PM
Not sure, I think short tube dyno headers and it has a vortex heads
this is my engine build sheet so far
Block:
4-bolt main block
Passenger side dipstick
Square and parallel decked
Align honed main bearing bore
Cylinders are sonic tested for thickness
Cylinders honed on a computer controlled machine to within .0002'' straightness and roundness
Rotating Assembly:
SCAT 3.75'' stroke cast crankshaft
Chevy 5.7'' heavy beam rods with 150,000psi bolts
Keith Black hypereutectic pistons
Hastings Moly rings
Clevite bearings
Externally balanced rotating assembly
Melling high volume oil pump
Heavy duty double roller timing set
Cylinder Heads:
GM Vortec cast iron heads
Hardened retainers and 1.25'' diameter valve springs
2.02'' swirl polished intake valves
1.60'' swirl polished exhaust valves
Hardened pushrods
Camshaft Specs:
Hydraulic Flat Tappet
Duration @ .050'' Lift: 234 Intake / 244 Exhaust
Lift: .487'' Intake / .508'' Exhaust
Lobe Separation: 112°
Other Features:
Professional Products dual-plane satin aluminum intake
Chrome valve covers
Chrome timing cover
New 5-quart oil pan
Brass freeze plugs
9.5:1 compression
Dress Model Adds:
Edelbrock 750cfm Carburetor
Edelbrock water pump
Edelbrock fuel pump
MSD distributor
MSD Coil
MSD spark plug wires
Braided fuel line
Horsepower: 405
Torque: 440
ADD ONs
Mr. Gasket Hi-Thermostat 160 degree
BeCool Complete Crossflow Electric Radiator
BeCool Radiator Fluid 4 Gallons
JEGS Inline Radiator Hose Drain
Drop, Incldes Temperature Wiring Kt
March Performance 22050 Serpentine Kit
Gates 6-Rib Micro V Belts (Alternator)
Gates 6 RIb Micro V Belts (Power Steering)
JEGS Saginaw Style Power Steering Pump
JEGS Power Steering Adapter Fittings
JEGS GM Kool-FIn140-amp Serpentine Belt
JEGS Hi-Output Alternator Wiring Kit
Hooker Super Competition Headers
Full Length 2207HKR, Jet Hot Ceramic Silver Coated
Mr. Gasket Ultra-Seal Exhaust Gasket
MSD Ignition Kit
Bullockracing
12-06-2010, 08:50 AM
405 hp sounds pretty optimistic for that motor combination. The motor may put out 405, but the water pump and power steering may not have been hooked up, the rest of the belts/accessories may have been off, etc. I would bet more around 300 rwhp for that combination, with most of the loss being the accessories and the auto trans.
Once you get it to a chassis dyno, you should post back on here and let us know how FOS we are, LOL!
ArtosDracon
12-06-2010, 10:40 AM
Yeah, that's a bit optimistic by blueprint, I'd be interested to see what the chassis dyno says, I'm thinking 300 would be a bit lucky of a number to pull. I hate to be the pessimist of the group, but my money would be on 285-290RWHP.
1970 TT Rustang
12-06-2010, 12:04 PM
iam with him on this
rfalker1
02-15-2011, 04:17 AM
Ok, I will, maybe in the future I will get the cam and heads changed, so far we have lifted the cam and put a different carb.
