View Full Version : Morgan's 67 Project Trans Am Coupe
csx4766
10-31-2010, 09:14 PM
Well I picked up my next project this afternoon. It's a 67 Mustang hard top that I found on Craig?s List. The car was located in Mariposa, a small town in the Sierra?s near Yosemite. The Mustang is a roller that needs total restoration. It has no motor, transmission, hood, right front fender, grill or interior.
On the plus side it's an A code car with standard transmission. The factory red is still there and has not been painted over. It's a nice solid car with no rust and all of the body parts fit real nice.
I plan to go with the Jerry Titus Trans Am Mustang theme and replace out the front and rear suspension with 9" leafs and coil overs up front. For the motor I am thinking a stroked 331 small block and a TKO for the transmission.
https://static1.pt-content.com/images/pt/2010/11/67mustanghardtopdriverside-1.jpg
https://static1.pt-content.com/images/pt/2010/11/67reararea-1.jpg
https://static1.pt-content.com/images/pt/2010/11/67dash-1.jpg
csx4766
10-31-2010, 09:19 PM
I decided to go with a 9" rear end that my friend Pork beefed up for me along with some Moser axles and a N case 31 spline setup. I took the rear end over to Fearless Gear where they welded on torino bearing ends. Then dropped the rear housing at the powder coater.
https://static1.pt-content.com/images/pt/2010/11/HPIM0162-1.jpg
https://static1.pt-content.com/images/pt/2010/11/difhousing1-1.jpg
https://static1.pt-content.com/images/pt/2010/11/difhousing-1.jpg
https://static1.pt-content.com/images/pt/2010/11/67Mustangpumpkin-1.jpg
csx4766
10-31-2010, 09:21 PM
The underneath is basically rust free. So I decided to clean it and repaint it the original color. I had some spray paint mixed up years ago that matches the original under coating.
https://static1.pt-content.com/images/pt/2010/11/67underneath-1.jpg
https://static1.pt-content.com/images/pt/2010/11/67underneathnov1-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00736-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00735-1.jpg
csx4766
10-31-2010, 09:22 PM
Next I installed five leaf reverse eye springs and heavy duty shackles.
https://static1.pt-content.com/images/pt/2010/11/DSC00732-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00733-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00731-1.jpg
Then in goes the rear end assembly
https://static1.pt-content.com/images/pt/2010/11/DSC00734-1.jpg
csx4766
10-31-2010, 09:24 PM
Next I installed the Fays2 Watts Link setup.
https://static1.pt-content.com/images/pt/2009/12/DSC00743-1.jpg
https://static1.pt-content.com/images/pt/2010/03/DSC00744-1.jpg
https://static1.pt-content.com/images/pt/2010/03/DSC00742-1.jpg
csx4766
10-31-2010, 09:27 PM
Brakes for the rear are Ford explorer Disc set up. Moser 31 Spline axles are bullet proof.
https://static1.pt-content.com/images/pt/2010/11/brakerear49-1.jpg
csx4766
10-31-2010, 09:29 PM
I also welded in a panel of stainless between the trunk and interior for safety and added stiffness. The stainless came from a damaged wine tank. Recycle right!
https://static1.pt-content.com/images/pt/2010/11/DSC00555-1.jpg
csx4766
10-31-2010, 09:33 PM
Here is a little more information on the Watts link set up. The Fays2 system is well designed however falls short in one area; mounting of the frame to the car. The shoulder bolts need to be change to have less shoulder and more threads. The bolt shoulder causes the bolt to stick out and he states to fill that gap with washers. The prices is very reasonable and he is a very nice guy.
https://static1.pt-content.com/images/pt/2010/11/DSC00095-1.jpg
https://static1.pt-content.com/images/pt/2010/11/watts20front20view20500-1.jpg
Original Trans Am car watts link set up.
https://static1.pt-content.com/images/pt/2010/11/DSC00032-1.jpg
csx4766
10-31-2010, 09:48 PM
I am going with Ron Morris front coil over set up. Super nice guy who is based right up 99 in Modesto CA. This should work real well.
https://static1.pt-content.com/images/pt/2010/11/street_force_demo-1.jpg
csx4766
10-31-2010, 09:50 PM
Cleaned up the backing plates on the Explorer disc brakes.
Drilled and tapped the rear end housing for line clamps for the brake line.
Installed Moser axles along with new brake rotors and brakes with new brake pads
https://static1.pt-content.com/images/pt/2010/11/DSC00748-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00750-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00752-1.jpg
The wheels are just used to move the car around. I will be going with 17" wheels.
https://static1.pt-content.com/images/pt/2010/11/DSC00753-1.jpg
csx4766
10-31-2010, 09:54 PM
More often than not I have a list of to do items that I hope to get done in a given time. Well it did not happen over Thanksgiving. Seamed like that is two steps forward and one step back every day.
On Wed. I did get by my friends Marks shop "The Mustang Ranch of Fresno" :) and picked up a few items.
Here pinion snubber that came on the Shelby's and Mustang GT's that I picked up.
Before
https://static1.pt-content.com/images/pt/2010/11/DSC00756-1.jpg
After
https://static1.pt-content.com/images/pt/2010/11/DSC00767-1.jpg
csx4766
10-31-2010, 09:56 PM
I also managed to get the sub frame connectors installed. It was one of those job where it would been cool to have some extra hands but then again I found a way to get it done on my own.
https://static1.pt-content.com/images/pt/2010/11/DSC00779-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00782-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00783-1.jpg
csx4766
10-31-2010, 10:06 PM
My friend who is a welder came over to help. After buying some steel, we went work further reinforcing the body's floor pan and underneath. Welded up the subframes and added some 1.5"X1" retangular tubing and attached it to the sub frame connectors using steel plate.
https://static1.pt-content.com/images/pt/2010/11/DSC00794-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00793-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00787-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00788-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00789-1.jpg
csx4766
10-31-2010, 10:08 PM
Removed the front suspension.
https://static1.pt-content.com/images/pt/2010/11/DSC00790-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00795-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00797-1.jpg
csx4766
10-31-2010, 10:10 PM
Well I pulled the steering assembly out, removed wiring and everything else that was under the dash.
https://static1.pt-content.com/images/pt/2010/11/HPIM0335-1.jpg
Need to figure out which holes to weld up on the fire wall. Plan to run vintage air.
https://static1.pt-content.com/images/pt/2010/11/HPIM0334-1.jpg
I have the roll bar positioned where it needs to be and plan to get it bolted in tomorrow.
https://static1.pt-content.com/images/pt/2010/11/HPIM0332-1.jpg
csx4766
10-31-2010, 10:12 PM
It was a fun filled day and a lot of work on the body of the 1967 Mustang. My good friend Dave drove over from Salinas just to help me with the body work on the Mustang. We got quite a bit accomplished. I focused on the Radiator care support while dave focused on everything else. :)
https://static1.pt-content.com/images/pt/2010/11/HPIM0338-1.jpg
https://static1.pt-content.com/images/pt/2010/11/HPIM0339-1.jpg
https://static1.pt-content.com/images/pt/2010/11/HPIM0342-1.jpg
https://static1.pt-content.com/images/pt/2010/11/HPIM0340-1.jpg
https://static1.pt-content.com/images/pt/2010/11/HPIM0341-1.jpg
csx4766
10-31-2010, 10:15 PM
More progress; We finished bracing the underside of the Mustang and moved to the front to finish the radiator core support and front apron. Certainly got a little help from a few friends. :) Tom is a retired auto body tech and well Pork is a certified welder who has been helping since the project started.
https://static1.pt-content.com/images/pt/2010/11/DSC00854-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00855-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00856-1.jpg
https://static1.pt-content.com/images/pt/2010/11/DSC00857-1.jpg
We had the hood and fenders on numerous times. The right fender is a repop is not up to the quality i want for this build so it will be replaced. The hood will also be replaced with a poly fiber 67 Shelby style hood.
csx4766
10-31-2010, 10:17 PM
Well about a little update on Project 67:
Still in the fabrication and fender straightening stage.
Lets go to the Boss 302 Modifications.
First I cleaned and primed the shock tower pockets then made a template out of card board.
https://static1.pt-content.com/images/pt/2010/11/Picture0011-1.jpg
https://static1.pt-content.com/images/pt/2010/11/Picture006-1.jpg
https://static1.pt-content.com/images/pt/2010/11/Picture002-1.jpg
Then trasferred the cardboard template to metal.
https://static1.pt-content.com/images/pt/2010/11/Picture005-1.jpg
Then welded the plate in the pocket at a 45 degree angle.
https://static1.pt-content.com/images/pt/2010/11/Picture031-1.jpg
https://static1.pt-content.com/images/pt/2010/11/Picture033-1.jpg
csx4766
10-31-2010, 10:19 PM
Moved to the inside of the engine bay and welded the shock tower seams.
https://static1.pt-content.com/images/pt/2010/11/Picture0501-1.jpg
https://static1.pt-content.com/images/pt/2010/11/Picture051-1.jpg
https://static1.pt-content.com/images/pt/2010/11/Picture052-1.jpg
https://static1.pt-content.com/images/pt/2010/11/Picture053-1.jpg
csx4766
10-31-2010, 10:20 PM
I also welded the roll bar backing plated to the inner fender wells and bottom of floor.
https://static1.pt-content.com/images/pt/2010/11/HPIM0485-1.jpg
After the backing plates were welded I coated the rear interior fender area.
https://static1.pt-content.com/images/pt/2010/11/HPIM0488-1.jpg
https://static1.pt-content.com/images/pt/2010/11/HPIM0504-1.jpg
csx4766
10-31-2010, 10:22 PM
Spent a few hours this week with the welder and a friend.
Filled in all the emblem and trim holes.
https://static1.pt-content.com/images/pt/2010/11/HPIM0503-1.jpg
The fenders were 1968 model fenders so I made a patch for the side marker lights.
https://static1.pt-content.com/images/pt/2010/11/HPIM0501-1.jpg
https://static1.pt-content.com/images/pt/2010/11/HPIM0502-1.jpg
Also took care of the hole for the antenna
https://static1.pt-content.com/images/pt/2010/11/HPIM0498-1.jpg
csx4766
10-31-2010, 10:23 PM
Took the 67 down to Caps Powder Coating last Monday to get the front end and fenders soda blasted.
https://static1.pt-content.com/images/pt/2010/11/HPIM0514-1.jpg
https://static1.pt-content.com/images/pt/2010/11/HPIM0515-1.jpg
https://static1.pt-content.com/images/pt/2010/11/HPIM0516-1.jpg
https://static1.pt-content.com/images/pt/2010/11/HPIM0519-1.jpg
https://static1.pt-content.com/images/pt/2010/11/HPIM0520-1.jpg
https://static1.pt-content.com/images/pt/2010/11/HPIM0521-1.jpg
csx4766
10-31-2010, 10:24 PM
More work on the 67. Man what a mess when doing body work in the home garage.
https://static1.pt-content.com/images/pt/2010/11/Picture011-1.jpg
https://static1.pt-content.com/images/pt/2010/11/Picture010-1.jpg
https://static1.pt-content.com/images/pt/2010/11/Picture012-1.jpg
https://static1.pt-content.com/images/pt/2010/11/Picture009-1.jpg
Fitting the headlight buckets
https://static1.pt-content.com/images/pt/2010/11/Picture014-1.jpg
https://static1.pt-content.com/images/pt/2010/11/Picture013-1.jpg
CruizinKev
11-01-2010, 01:20 AM
nice project! good work so far!
Bryce
11-01-2010, 06:22 AM
sweet project. I cant wait to see this car done!
WS6
11-01-2010, 06:43 AM
Good work so far. Keep it up. I love seeing these old cars turned into TA racers from back in the day.
csx4766
11-21-2010, 12:24 PM
Well I have been working on the Mustang but it’s still going slow with other projects and work keeping me busy. Yesterday and today I am working on the front sub members. Using 3/16 steel plate to wrap the sub frame members in an effort to had strength and stiffness.
https://static1.pt-content.com/images/pt/2010/11/HPIM0612-1.jpg
https://static1.pt-content.com/images/pt/2010/11/HPIM0615-1.jpg
69X22
11-22-2010, 05:32 PM
looking good!
705.0Merc
11-23-2010, 07:58 AM
Very nice.
GHOSTDANCER
11-23-2010, 08:27 PM
Subscribed :twothumbs
chunger
11-23-2010, 09:42 PM
Looking great! Be sure to check the cowl area for rust, this era Mustang are notorious for it.
What are the plans for the driveline?
vprace
11-24-2010, 10:42 AM
nice work and cool project. I am curious whats the point of the watts linkage on a leaf spring car?
csx4766
11-25-2010, 12:26 PM
Chunger, The only rust was a 6" X 6" spot in the drivers floor pan I replaced already and a 3'X#3" spot in the driver side rear quarter in the lower corner. I have a patch panel, but right now trying to decide how much of the patch panel I want to use.
Vprace,
Connect or replaces the left lower leaf spring shock plate. The other arm connects to a bracket mounted on the 9" dif.
Morgan
csx4766
12-27-2010, 09:13 PM
I am starting to jump around to different areas on this project just because I have run across deals that were hard to pass on. First came a deal on a Boss 302 R block still in the box with the windage tray out of Landcaster. So I met the guy in bakersfield to make the exchange to save on shipping.
https://static1.pt-content.com/images/pt/2010/12/HPIM0674-1.jpg
https://static1.pt-content.com/images/pt/2010/12/HPIM0675-1.jpg
Phoenix protecting valuable cargo.
https://static1.pt-content.com/images/pt/2010/12/HPIM0673-1.jpg
csx4766
12-27-2010, 09:18 PM
Then the rods, don't tell the Boss block but we are going to shove Nissan H beam small journal rods. All in an effort to reduce rotational weight.
https://static1.pt-content.com/images/pt/2010/12/HPIM0676-1.jpg
Now the kicker, here is the Bryant crankshaft which will give us a stroke of around 331 cubic inches. This is being shipped out of a Nascar shop from Mooresville NC.
https://static1.pt-content.com/images/pt/2010/12/bryantcrank-1.jpg
https://static1.pt-content.com/images/pt/2010/12/bryant-1.jpg
csx4766
12-27-2010, 09:21 PM
Diamond Flat Top custom pistons are ordered and three weeks out. Much more to come, we should have a short block assembly pulled together by the end of January.
csx4766
01-08-2011, 04:28 PM
So more parts arriving, I am now addicted to Nascar shop cast offs. Here we have four brake cooling duct that I will try to adapt to my brakes somehow. One of the ducts is marked as Mark Martin. Figure for the $5 dollars it cost me it's worth a shot. :D
https://static1.pt-content.com/images/pt/2011/01/brakeducts154-1.jpg
Then the is the MSD ignition box I also picked up from the same shop for 115 dollars it was a bargain.
https://static1.pt-content.com/images/pt/2011/01/MSDIgn155-1.jpg
The wire are from Roush Yates shop.
https://static1.pt-content.com/images/pt/2011/01/spakplugwires157-1.jpg
csx4766
01-08-2011, 04:35 PM
The Boss 302 Block has been dropped off at Daves Performance and Engineering for final machining.
racedaddy
01-08-2011, 06:57 PM
so how do you get in the know on the nascar parts?
Bjkadron
01-08-2011, 07:10 PM
Awesome project! I really like these trans-am themes! do you by any chance have any more pictures of the old trans am car that you showed the Watts set-up on?
csx4766
01-08-2011, 08:17 PM
Benjamin Here you go:
https://static1.pt-content.com/images/pt/2011/01/DSC00027-1.jpg
https://static1.pt-content.com/images/pt/2011/01/DSC00028-1.jpg
https://static1.pt-content.com/images/pt/2011/01/DSC00034-1.jpg
https://static1.pt-content.com/images/pt/2011/01/DSC00044-1.jpg
https://static1.pt-content.com/images/pt/2011/01/7030520100_medium-1.jpg
csx4766
01-08-2011, 08:21 PM
Race Daddy,
The best way to find them is to do a search for Nascar race parts or racing parts in both google and ebay. then do a search for team shops like roush yate racing.
csx4766
01-13-2011, 11:52 AM
We considered several cam manufacturers including Comp and Cam Research but during my search for a cam I heard some really great things about Anderson Ford Motorsports and the cams they produce.
They are well known among the Fox bodied and newer Mustang guys and they have their own chassis dyno that they use to test their cams. If you go to their site they give real examples of different profiles and the chassis dyno results mapped out. Also customers cars with specs and 1/4 mile times.
http://www.andersonfordmotorsport.com/
I went with a Hyd. Roller that will be good over 7000 RPM’s. A guy I know has a similar Anderson grind in his fox bodied Mustang with a rotating assembly not near as good as mine, he said that he is making close to 600 HP at the flywheel and has revved it up to 8300RPM's with no damage to a Stock 5.0 Block.
http://www.andersonfordmotorsport.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=548&category_id=659&option=com_virtuemart&Itemid=1.
Heads will be custom order from AFR with Titanium retainers and keepers as well as larger intake valves and springs to match the cam profile 195/525 Spring Pressure.
Even with the Hydraulic Roller cam they said I should expect that there will be a lumpy idle and a motor that will really start to take off after 2800 RPM’s. Crossing my fingers on this one. All for wild and long and its manageable on the street.
The Hyd Roller Cam:
https://static1.pt-content.com/images/pt/2011/01/1292011014-1.jpg
csx4766
01-30-2011, 11:27 AM
Did some cleanup on the Parker Funnel web it will get bead blasted again. Then we will port match it to the AFR Heads.
https://static1.pt-content.com/images/pt/2011/01/1292011012-1.jpg
https://static1.pt-content.com/images/pt/2011/01/1292011013-1.jpg
FRENCHBLUE72
01-30-2011, 12:08 PM
Not much of a ford guy but nice work how long have you been working on this ride?
csx4766
01-30-2011, 12:36 PM
A couple of years, it has been moving slow but picking up steam with the motor build starting to move a fast pace.
csx4766
03-13-2011, 10:41 AM
We continues to move forward on the motor.
The AFR heads arrived with the ti retainers and keepers and LSX springs.
https://static1.pt-content.com/images/pt/2011/03/March2011021-1.jpg
We mocked up the heads and intake on a 347 that belonged to one of the guys that worked at the shop.
It was determined that the head ports would need to be enlarged to match the intake ports on the funnel web.
https://static1.pt-content.com/images/pt/2011/03/March2011018-1.jpg
https://static1.pt-content.com/images/pt/2011/03/March2011017-1.jpg
csx4766
I removed the valves and springs so Doug could port match the heads.
https://static1.pt-content.com/images/pt/2011/03/March2011022-1.jpg
https://static1.pt-content.com/images/pt/2011/03/March2011023-1.jpg
https://static1.pt-content.com/images/pt/2011/03/March2011024-1.jpg
https://static1.pt-content.com/images/pt/2011/03/March2011027-1.jpg
csx4766
03-13-2011, 10:42 AM
We are using a larger gasket which is a Fel Pro 1262R so there is no interference with air flow.
https://static1.pt-content.com/images/pt/2011/03/2011March331001-1.jpg
https://static1.pt-content.com/images/pt/2011/03/2011March331002-1.jpg
Finished head
https://static1.pt-content.com/images/pt/2011/03/2011March331003-1.jpg
csx4766
03-13-2011, 10:44 AM
We picked the block up from Daves Performance
https://static1.pt-content.com/images/pt/2011/03/Ebay2011feb007-1.jpg
Here is the block before I pulled it apart to wash and paint it.
https://static1.pt-content.com/images/pt/2011/03/2011March331007-1.jpg
I scrubbed the block clean before coating the internal area with glyptal. I spray the outside of the block glosss black.
https://static1.pt-content.com/images/pt/2011/03/2011March331005-1.jpg
https://static1.pt-content.com/images/pt/2011/03/2011March331008-1.jpg
https://static1.pt-content.com/images/pt/2011/03/2011March331011-1.jpg
csx4766
03-13-2011, 10:46 AM
Last thing to do on todays agenda is install that Bryant crank.
https://static1.pt-content.com/images/pt/2011/03/2011March331015-1.jpg
https://static1.pt-content.com/images/pt/2011/03/2011March331016-1.jpg
https://static1.pt-content.com/images/pt/2011/03/2011March331017-1.jpg
Bryce
03-13-2011, 10:51 AM
Great progress
kmdracer
03-13-2011, 06:23 PM
Very Nice! Should be a screamer!
RicerwannaB
03-13-2011, 06:54 PM
Looks great!
craigs73
03-13-2011, 07:53 PM
sweet car!! where you gonna mount the brake ducts on front
csx4766
03-14-2011, 05:52 AM
Thanks guys.
The Bryant crank will certainly will make the motor heart beat fast.
Every corner will have some form of brake duct to provide ventilation to the brakes. I have four that I can play with. Just trying to figure out where to grab the air in the rear.
Bullockracing
03-14-2011, 07:49 AM
Can you make the side vents functional? I personally just don't like non-functional scoops/vents, but there's two in front of each rear tire...
csx4766
03-14-2011, 02:00 PM
Yeah I am with you but I do not want to go with the traditional 67 Shelby scoops. I am thinking about it, sure I will come up with something but its not at the top of the list right now.
craigs73
03-14-2011, 07:44 PM
thats my first choice or if your really serious about the race theme/look you can use the quarter windows like in nascar
gjs14
04-03-2011, 08:38 AM
what brand is you roll bar? and will the stock side panels fit w/the roll bar?
