    Results 1 to 11 of 11
      Mar 2010
      south of cleveland,ohio
      18's and 20's whats your opinion?
      put on a new set of wheels this summer and looking for comments.
      Aug 2003
      Orlando, FL
      I do not like the fact the front tires have more rubber around the rim then the rears, a common problem with 18s and 20s. makes the front tire look taller then the rear. To make it look right you have to find a 25" front and 27" rear. or 26" front and 28" rear
      Jun 2010
      Western Kentucky
      Quote Originally Posted by ProdigyCustoms View Post
      I do like the staggerd fitment, but this is a good point, the tires should be equal
      Dec 2009
      knoxville, tn
      Frank is absolutely correct. you need AT LEAST as much stagger in tire diameter as you have in rim diameter. even a little extra tire diameter in the rear is good to be certain that the rear sidewalls don't look shorter than the fronts. 18's and 20's are a hard look to pull off on a fendered car.
      very nice ride nonetheless.
      Tom Hensley
      69 ss/rs clone
      98 ta ragtop
      "attack life....it's going to kill you anyway."
      Agree with the above, need the same amount of rubber height f/r to look right. Not only that, but less sidewall on the rear means less straight line traction. I wouldn.'t go down to a 25" total diameter in the front on a Chevelle, looks out of place in the wheel well. Stay close to a 26" total front, which means you'll want to shoot for a 28" tall rear.
      Nor Cal
      I have never ever seen an 18/20 combo that looked good on any car. Too large of an obvious contrast in wheel diameter just kills it for me.
      1968 Camaro widebody project
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Crown Point, Indiana
      I think they look good on this car... But I may be a little bias.
      Aug 2003
      Orlando, FL
      Quote Originally Posted by 68Formula View Post
      Agreed, 25 is to short up front on that car.
      Agree with Frank the profile on the tires need to match!
      Aug 2010
      Texas
      I love the way they look!
      Jan 2009
      I'm an 18/19 kind of guy. I think the proportions are better. Unless you're slammed to where 1/3 of wheel is buried in the fender well - at that point the difference in look is greatly diminished.
      car blog... updated sporadically. http://regans66.blogspot.com/
