View Full Version : signals went out ! almost died all the way home.
ssick chevelle
10-29-2010, 12:34 AM
so my signal has been shady for a whie.today both sides went out. I keep spare fuses but that was not the prob. flashers work still however. 1970 chevelle. please help 911
Steve68
10-29-2010, 01:54 AM
you need to elaborate/clarify just a little more before you get any answer/help,
formula
10-29-2010, 06:21 AM
well if it's been sketchy for a while, my bet would be that the switch in the column or the flasher failed.
John Wright
10-29-2010, 06:38 AM
The lights (especially the rear) have poor grounds, make sure all of the light fixtures are getting a good ground. Make sure all of the bulbs are good(no broken filaments), the flasher needs resistance to make it flash, and it gets that from the filament in the bulb.
ssick chevelle
10-29-2010, 02:46 PM
thanks all i will check all bulbs and fuses. its just kinda odd thay all flash with the hazards on. is the flashers in an area where i would be able to reach it? and to be clear we are NOT talking about the flasher on the fuse box correct?
10-29-2010, 09:16 PM
the flasher unit on the fuse box are for the hazards...the turns are usually clipped to the instrument cluster or dash support bar.
turn the hazards on and listen for the ticking to be sure.
Im suprised you almost died....4 gazillion drivers never used their turn signals and they are ok.
I am in no way making fun of your situation, I m just sayin.
Rod
10-29-2010, 10:35 PM
4 gazillion and one drivers my girlfriend never uses her signals! scares the Chiclets outta me
Mingus
11-01-2010, 04:44 AM
If both sides went out at the same time it is most likely the turn signal flasher itself, especially since the hazards are still working.
John Wright
11-01-2010, 06:00 AM
Check behind/above the ash tray......in that general area is where they stuff those flashers on 2nd gen camaros...I would think they would be in a similar area in your car.
ssick chevelle
11-04-2010, 11:25 PM
wow. thanks you all. my baby is fixed. man this forum is the truth.
