View Full Version : High vs low RPM
Removed user as requested
10-27-2010, 07:37 PM
Hi here is something I have received from year one in regards to the choice of engine for a pro-touring (supercar) build.
Like yourself, I am fan of V8 engines over the 10 and 12 cylinder engines used in many supercars. Big-block V8 engines (454 chevy, 429 ford, 440 dodge, 426 hemi) do not have the RPM range to compete with 12 cylinder competitors like the Diablo and some Ferraris. Horsepower and torque are not the only factors to consider
In racing, everything is a compromise. I’ll speak in general terms first. RPM = top end. A low rpm big block engine takes advantage of torque at the bottom end of the power curve and sacrifices horsepower at the top end. For example, the Viper you mentioned can run away from a Ferrari on short straights. Once the engine reaches its peak, the Viper cannot accelerate any more and will only maintain its speed. Meanwhile, the Ferrari has an additional 2~3k RPM with which to continue accelerating. On a short track, the Ferrari may not be able to catch and overtake the Viper.On a long track though, the Ferrari will catch the Viper and will likely handle better in the turns
Can some clarrify this for me? Why exactly would the ferrari be better off with 3k rpm more when the viper could simply 'shift gear' and continue climbing speed?
Is that in the context of when the car reaches its last gear and then the 3k rpm extra makes some difference which probbably wouldnt even be seen when you got 6 gears to go through???
I need some elaboration on why would someone want more RPM for a circuit car vs a massive ci engine with low rpm that makes same power/speed much lower... I dont understand how rpm works and why you would want it.
A: the bigger the engine, the less maintenance.
B: The bigger the engine, the more economical it would be as a cruising car (a small block made with 600hp will be less efficient than a 512ci engine at the same power because the small block has crazy cams etc while the big 512 is sleeping and hence if driven like a grandpa it would be more efficient and thus more streetfriendly)
C: flatter power curve with the BB and thus acceleration will be better and since its at 600hp top speed should be the same given the correct gearing.
Thats my short understanding, how does more rpm act better in a race sense at the same given power when even in this example of a diablo, he would have to change gears just like someone with a 512ci motor would have to change gears with the difference being the 512ci engine reaching higher speeds sooner
hopefully you get what im trying to get cause im confused!
tazzz25906112
10-27-2010, 08:14 PM
Wow this one that will certainly get the group in a heated debate ;-) LOL....
Everyone will have their own opinions and many will have fact, some misunderstandings and most will certainly outline preferences...
I personally believe you've hit things pretty much with the understanding of rpm, torque, and their respective rolls..... One thing that isn't in you comments or equation is how are you going to put all of this to the ground???
From experience, I built a car that has what I believe is the maxim compromise available on pump gas only to realize that not enough consideration was given to putting it down (the chassis)...
My motor is a 555ci aluminum engine that has a super light rotating mass that swings up easily in excess of 7,500RPM.... The problem I found was the power & torque is overbearing to the suspension & tires.... I haven't been talented enough or smooth enough to put it down (yet LOL) and the biggest peice of advice I can give you is "balance your effort & build"....
You can always build a car with more power,,, and more rpm for top speed,,, but the costs are going to go up cubically (and that's no joke).... So yes you can have both but it's going to cost a fortune to create a balance between that power and what your putting it in ..
(BTW you're going to want to be a hell of a driver if you chase that goal)
DartorDemon
10-27-2010, 08:29 PM
JM unprofessional opinion: i like cars that revv. I think high revvs combined with a manual transmission is heaven.
ArtosDracon
10-27-2010, 10:47 PM
Strictly speaking to what year one said, that's utter rubbish. Assuming the cars were geared identically and used the exact same size tires and had the same co-efficient of drag and weighed the same, that would be true. But you can gear your car however you want, and you can even change the gears for the track you're going to be at. I would really enjoy having whoever said that come to try and explain and back-up his statement.
Bryce
10-28-2010, 05:29 AM
Just to through this out there: throttle responce makes a huge difference in racing. So how fast does the motor accelerate. A motor with less rotational inertia may rev faster and actually be faster depending on gearing. Hopefully both cars would be geared optimally for that motor.
Example, a jerico 5 speed does not have an overdrive, so you would change your rear gears to accommodate the desired final drive.
rrunner68
10-28-2010, 11:15 AM
I would say it's 100% personal preference. I like big block torque, so if nessisary I can "dig" out of a bad turn and or shift, where if you are a revver, you'll have to shift. I also agree to the Aero/gear debate. A healthy big block with 3.23 rear gears and a 1.0-.8 final drive from the trans is perfect for anything below 120-130mph
79-TA
10-28-2010, 02:01 PM
Power is a result of force at speed, or in more familiar terms, torque at a given rpm. So what matters most, is the average horsepower over the rev range you intend to use. This varies for each track and ideally, you would customize your gearing accordingly each time. For a race car, this can be taken to the extreme. For a street car, we make compromises for reliability, cost, and flexibility.
Given that there are two basic ways to make power (focus on high torque at low rpm or maintaining torque at high rpm) one must look at what pros and cons are involved with each. Traditionally, focusing on RPM allowed racers to use a smaller engine which equated to weight savings. With tight gearing in a racing situation, the engine could stay in the powerband the entire time and the poor lowend torque would not matter as much. Cars that only make power at high rpm rely on gearing and torque multiplication. Some of the cons of this have already been mentioned in that with more rpm comes more wear and stress. Obviously, if cubic inches and torque were sacrificed, staying in the proper rev range is more critical.
Random other thought. A high revving car might not need an upshift right before the end of a straight, which can save the driver the trouble of shifting. Staying in the lower gear will mean more torque multiplication. On the other hand, a torquier lower revving engine in another scenario might not need to be downshifted in a braking zone allowing momentum to be carried more easily and saving the the driver the act of shifting. It all depends.
Here's a quote from Paul Van Valkenburgh's Race Car Engineering and Mechanics regarding stress and rpm: "Component stresses rise exponentially with the increase in rpm, so an engine might last 100 hours at 6,000 rpm, 10 hours at 7,000 rpm, and 1 hour at 8,000 rpm."
Here are my thoughts on Ferrari vs Viper. Both cars have been tested and you can find actual data for both. The current ACR is an absolute beast that would wipe the floor with most production Ferraris. For instance, the ACR already beat the F430 Scuderia by about 6 seconds around VIR (a long track) in Car and Driver's 2008 Lightning Lap.
But for the theoretical version, it all comes down to how much power each car is putting down. Peak acceleration for any car happens in first gear at peak torque. We'll assume the Viper has the raw torque advantage while the Ferrari has rpm and both have similar peak horsepower. From a standstill, the Viper would have the advantage in raw torque (and better average horsepower within 1st gear.) The Ferrari might compensate with deep rear gearing, but the average horsepower difference might be too much.
At a roadcourse, the cars won't have to dig themselves out from a standstill, so the usable rev range changes and lowend torque is not as much of an issue. The average horsepower in the rev ranges actually used will be very similar, and if the Ferrari's smaller displacement engine allows a smaller and lighter design, it might handle better as well. So yea, it all depends on all kinds of factors.
H2Ogbodies
10-28-2010, 02:32 PM
Not to mention the viper is a pig in terms of power to weight ratio when compared to a Ferrari. And being mid engine to boot. Persoanlly, I think if detroit focused on turbocharging instead of raw displacement for max power, you would see big cubic inches disappear. I see turbocharged inline motors as the future.
406 Q-ship
10-28-2010, 02:40 PM
What Brett said.
A long track does not necessarily favor a high RPM horsepower engine. I have seen a Z06 Corvette runn away and hide from a Ferrari (can't remember which one) at Laguna Seca, these were street cars on a open track event. It is about gearing, weight, and driver ability when it comes to high RPM vehicles, where a low RPM torque engine is more driver and gear friendly.
PhillipM
10-28-2010, 03:55 PM
I think this needs to be moved to the Engine Section...
rogue
10-28-2010, 05:08 PM
High RPM is fun but gets tiring winding out everywhere.
13,000 RPM sequential shifting
http://www.youtube.com/watch?v=Ig6yGvS5OkY
6500 RPM BBC TKO600
http://www.youtube.com/watch?v=V_D6HG8BuZk
Both require totally different driving styles. I find myself having trouble switching between cars sometimes they are so different.
I will admit though, NOTHING compares to the sound of a high RPM motor, but nothing compares to the torque of a BBC.
All preference I guess.
Jim Nilsen
10-28-2010, 05:40 PM
I have found that the taller the rear gear and the wider ratio 6 speeds give a much wider overlap in the best torque range and higher rpm which gives you the best of both worlds. It made a big difference at the Goodguys autox to be able to go 6500+ rpm in 1st at 35mph, the control with the throttle took out any need for the brakes at all and it was getting better each lap as I was learning what I could really do.
Wide gearing with a lot of torque makes a really nice car to drive all around and I also like being able to wind up to 6500 rpm as long as it is pulling hard and in 1st and 2nd gear the redline comes up so quick even with tall gearing in the rear with the right trans. Going to 7500 rpm would really make even more overlap. With the LSX engines flat and wide torque these days it is really a no brainer to have both !!
10-28-2010, 11:38 PM
Thanks for the feedback.
So just to make sure I understand correctly...
In theory, 2 identical cars, 2 identical weights, 2 identical drivers, 2 identical HP/Tq (as close as it can be)... so everything is the same other than one car is high RPM and the other low RPM Big Cube...
Both cars should reach the finish line after 20-30 laps at the same time, its just how you drive it?
See, Im going to take my 68 Charger down to prodrive to do a supercar suspension on it (probbably looking at 40 000 or so for suspension fabrication), The power will be put down to the ground, going to run 335s out back unless I find 345s possibly and likely to run 265/275 front.
All I want to get my head around is...
A Lamborghini Diablo for example to me is a street car. I can hop in it... it goes hard, it definatelly handles awesome, feels racey on the road but not 'hard like a rock such as a dedicated race car'. So to me its something you can go in a nice cruise in but also take it out to a race course and have some serious fun with it.
Now... considering its a street car, 5mpg cruising means I cant really use it for anything and therefor defeats the purpose. I know a engine builder that is able to pull out 565hp out of a 440 stroked to 512ci, running on a proform 850cfm 4 barrel carb and gets 20mpg (if you feather the accelerator and drive like grandma)
If I build a small block at 600hp vs a 528ci engine at 600hp, which one will be definatelly the more 'street' engine... and if taken to the track (say 2 identical chargers built identically one with the small block at 600 and one with the 528 at 600) which one would be the leading car? Or would performance be the same just requires a different way of driving it?
I mean, vipers as example can go to 300kmh, so can ferraris... so how the heck does the extra revs help when they both got the same top speed.
Which style would be best for me and can CI be gotten with the RPM? (roller motors etc with reliability)?
Last thought... they also told me the 440 would run circles around the hemi because it can make the same if not 'more' power than a Hemi and the 440 would be alot more reliable while the Hemi was designed for drag race and designed to be pretty much rebuilt after every race. Obviously speaking in the context of a lambo, its a car that would be fun to cruise in, handles awesome, can be taken to the racetrack for fun and wont need a 20 000 dollar engine rebuild at the end of the race... so obviously I need a durable engine style build as this is a street car with fun at the track (context of the lambo which to me is a street car)
HUSTLESTUFF
10-29-2010, 01:21 AM
For what you are looking for, you may want to look at XV motorsports and a twin turbo new Hemi and 6 spd. XV http://www.xvmotorsports.com/ has done all of the homework for the early Mopars, but did so with the new Hemi in mind. Get the Level II Suspension (probably what prodrive would come up with), stiffen up the car, get brakes to match and stuff in a TT 6.1 and you'll get 20+ mpg unless you're WOT. I'd guess you'd be in below $40,000 for motor and suspension. Mike
MonzaRacer
10-29-2010, 02:32 AM
OK so a lot of people will spread misconceptions on which is better. Small blocks were built to make small ,compact, fuel efficient and easily maintained power plant at a reasonable price.
Now in small block terms after a point they ran out of power potential in design and materials stand point.
So fast forward nearly 60 years from the development of the small block chevy and if properly well built the engine can make literally unknown amounts of power. now go back, why did we build big blocks, they were developed heavy truck, industrial use. As the Hemi was but because if its success in industrial use it was put in cars, so never say a hemi wont last, it just doesnt last in stock form at high rpm.
You must decide, which engine suits the application, could a 409 fit into NASCAR now,, most likely not due to a compromise design, can it be done ,sure, with enough cash but a clean sheet design gets the nod over an adaptation.
Now do you need torque to get you there in quicker acceleration or do you need your power up on top end.
There where CanAm 305 big blocks running super light rotating assemblies, and turned some serious rpms and were competitive.
Make the engine larger displacement and you blow the design idea of the nearly $5million dollar program of making a BBC rpm and make power. From what I got those FI engien would spin up to 11,000 and make well over 600hp, but no torque.
Take a 454 sbc and spin it 11000 rpm and you wont own it long with out NASA spec/price parts.
Any engine IS and always will be a compromise by the designer to fit the application/use.
Why is it that NASCAR engines are big bore short stroke? Because it was the best design, now can you drag one, yes but its no a smooth match. Now take a 434/454 sbc it will be a better drag engine,,,and cheaper as it isnt required to spend ridiculous sums of cash to build over the NASCAR unit.
Trying to say that one engine suits everything is a misnomer and shouldnt be believed.
I have always been a believer in smaller engines, in some respect. the best of both worlds, I have a 77 Monza, the 355 I built for the yellow car in my avatar was simply the best performing engine for the least amount of parts and time and cash I ever built.
BUT its bottom end torque was BRUTAL in the car. So now I am going to do something slightly different, less stroke/CU in. a slightly better cam head combo to kill low end torque, thne to build upper end torque I am going to turbo it.
The 355 wouldnt pass in turbo form but the number do play out for my 302 sbc idea.
Match torque production in a flat curve for moderate weight cars, with a faster acceleration ramp, ie it makes torque but accelerates faster will , if match with proper gearing , be better engine.
Peaky torque curve with slow or fast acceleration ramps will need crutches to live in same environment.
Like probably one of the best seat of the pants engineers ,Smokey Yunick (sp) , mentioned in an article I read, his theory was build as much torque as quickly as your chassis can apply, and your in the right ball park.
The more power you can build , faster will out accelerate the engine that takes time to build power, and less crutching you have to do with gearing and suspension.
Too much torque and you use less effective gearing, , not enough and you have to over gear it.
In drag racing if your final drive gearing stays in the 10to 1 range in low your nearly golden if your power is right. Proven numbers.
Most guys and gals are running 4,5 and 6 speed in Auto cross but are using what 2nd and 3rd? , maybe 1st?
But if they have a decent power curve that accelerates at sufficiently enough speed/torque you do less shifting(modifying) of the gearing as is.
Take Jim Nielsons (sp) Cormaro, his first engien was a compromise, in many ways. It was good deal but want really built for the use.
He, from what I read had a better suited design/matching of parts and now has a better car for it.
So would a properly tuned V12 work better in a dump truck, yes but it would be over kill and over engineering. A big low speed V8/V10 lumbering along works fine. try to patcha small block for heavy use and it wont live.
So saying one is better than another is a misnomer or in actuality WRONG. Each engine has it purpose.
Put a 305 BBC CanAm engine in place of a 502 and you might not even move the truck.
Its design of the package.
The hemi of 1950s has barely a resemblance to the Hemi in a Top fueler of today, but share history and maybe some basic design influences yet the Hemi started life as an industrial engine and thats a fact.
Why did it get hot rodded, because it was bigger, had heavierduty parts that would hold up to being beat on, remember a 331 Firedome was a very large engine at time, did have a very solid head design and made great torgue over a 265 or 283 SBC.
Torque accelerates you faster , horsepower just gives you speed.
Look at Bonneville land speed cars 1500 hp but very little low end torque and compromised gearing, thye cant even take off from standing start most times yet make ludicrous speed!
Now take tazzz and his engine build same light weight engine decrease the stroke to take bottom end edge off and it power to weight ratio might be more suited. too much of a good thing like torque CAN be a bad thing per application.
If it was say 505 with less stroke, would it suit his use more, maybe if its matched properly, would it be worth packing into my 3000lb Monza, nope. too much torque for chassis/driveline, put it into a car with more room for mods and tada a better package.
One engine design will fit a one car design better, but must be matched.
How is it LSx engines work so well, because a designers took 60+ years of ideas, new design technologies and new materials and made it a near perfect power plant, light, strong, powerful. BUT is it for ,say my car, nope I cant even afford to delve into LSx ignition.
Heck I am even working on something for SBC engine, well any engine actually , just for my project but would work on LSx too.
Because Iliek to design and swap and modify and make odd parts work.
Ever car I have built has almost always been a compromise of power,performance and money.
I have gotten cars to a point in every build, mainly because I work in automotive field and get to pick up some cool toys from tool truck, but just enough to get me one step closer to being able to build a quality car.
Oh and most of my stuff winds up off of someone scrap pile most times!
So. NEVER stick any one engine into the perfect box. Right now the LSx is top dog, 50 yrs ago the sbc was, and before that a Flat head Ford V8.
Give me or one of the others who noodle out power packages on this forum, a price application and frame you need it in, and most of us can make something extraordinary. Give me $1000 and and moderate weight car to drive and race and Ill got back to the same 355 design I bragged about from the old Monza, Give me $10,000 and I can do a pretty good sbc,bbc or LSx. Give me $100,000 and ill design the dog gone engien to fit if need be. Give me a $1,000,000 and I can build you a near car from ground up and make it look like what ever.
Zachalanche
10-29-2010, 03:00 PM
Remember that torque HP and RPM are all related (HP = (torque*RPM)/5252). on the low end torque is easy to come by without having a lot of horspower (diesels are a good example of this) on the high end it takes an exponential amount of horsepower to maintain the same amount of torque (for example my yamaha R6 has to spin at 17,000 RPMs and makes 100+ HP just to make 40 ft*lbs of torque).
HP is a work rate and Torque is simply a force. A deisel truck can apply a massive amount of force to the ground which allows it to move a lot of mass but it lacks aceleration due to its inability to do a lot of work in a small amount of time. Conversely a streetbike cant move a lot of mass, but it can move a small amount of mass very quickly.
Ultimately it comes down to power to weight ratio. Heavier vehicles will require more foce to make them move, but thats not all, not only does it take a lot of force it takes a lot of work to keep that car accellerating if you want to accelerate a heavy car in a short amount of time it requires a very high work rate (HP) which is easier to come across at high RPMs. Thus torque is more useful (for going fast) if applied at high RPMs, but if you refer to the formula, that would require a lot of power.
Lots of torque at low RPMs requires less power. so, the extreme example here (if you limit power) is a car that does a nasty burnout because it is trying to apply too much force to the ground, but once it gets moving there is not enough HP to keep the torque up resulting in poor acceleration. yes gearing up would help optimize this setup, but would not make up for lack of necessary HP.
As with everything there are always compromises, but for performance Higher RPM operation is more desirable. And big displacement that can reliably run high RPMs - that would be having your cake and eating it too.
feel free to rip into me for missing any info or misstating anything. I have a hard time explaning this sometimes.
79-TA
10-29-2010, 05:02 PM
. . . on the high end it takes an exponential amount of horsepower to maintain the same amount of torque (for example my yamaha R6 has to spin at 17,000 RPMs and makes 100+ HP just to make 40 ft*lbs of torque).
The relationship would be linear, not exponential. Constant torque with twice as much rpm would result in twice as much horsepower. Now, in a real situation, the torque curve begins to drop at high rpm, so the engine will have to spin much faster, which is what I think you were getting at.
Charley Lillard
10-29-2010, 06:26 PM
I have a 66 Shelby GT350 vintage race car with a 289 making 480 hp that I can rev to 8000 with no problems. I have found that those extra rpms really come in handy when you are closing on someone right before a turn etc and upshifting would just screw everything up since you are about to be decelerating. It's just nice to have that little something extra.
ratman67
10-29-2010, 08:53 PM
one of the car mags a few years back built a 406sbc and a 402 bbc ran em back to back in the came car at the same track, same day. the bbc always one and pulled a little more mph. look at the oppen road races like the the one the big red camaro ran, that 540 crushed everything in the field including all the high strung exotics. lol my 540 bbc make 800 ponies just like the big red camaro...but on pump gas. i look at mark stielows red devil build. he is running a cast iron block ls series motor then added a blower and all the other stuff needed to run the blower i bet my alum headed bbc weighs about what his sbc does with the blower and all the other stuff he had to add to run the blower, inter cooler, plumbing, etc.. i saw where he said he has to slip the clutch to hook it up in 1st gear and slip it some more at the 1-2 shift. he is making over 800 ft of tq at 3500 rpms, im making 680, i would be willing to bet i would out accelerate him as i think i can hook my power up without feathering the clutch as he does. i watched the grumpy jenkins tribute camaro run an autocross and he boiled the hides trying to get off the line with that 572 he is running 1/4 more stroke than my 540. i have seen several pro touring cars running turbos and they can't hook em up at 50 mph, and they are always out of control. i think around 700 foot lbs is the most you can hook up with a 335 rear tire. just my .02, rm
10-30-2010, 01:49 AM
Thanks guys.
Being honest I still dont trully get the whole High vs Low RPM thing... it just doesnt seem to go into my head *argh*. I guess its because my brain is still saying "why make 600hp at 8000rpm when you can make it down at 4000rpm" (speed would be the same wouldnt it cause its 500hp????) and 6 gears to use to play with... I dont see how the SB would keep up.
Whether its high or low rpm, big or small block, I only plan to run 600-650HP with 650-700ft/lbs torque.
If BB can be gotten to have RPMs I know my heart is set on a Hemi 528 alloy block, heads, etc. But I got told that motor wont last long...
So If a built a small block 360 or something outputting 600hp... wild camshaft to do it (fuel economy out the door) reving its head off... that will last longer than a 528 thats sleeping at 3000rpm making 500+ ft/lbs up to 6000rpm...
Some reason something tells me the BB would be the winner and the more street friendly motor at the same time and probbably the economical version of the 2 (even though both are not economical). I dont want to run any power adders, whether big or small both will be made to make 600hp naturally aspirated. I also am not going to Auto-X this car. I will only run it at the Bathurst raceway course in Australia or Eastern Creek Raceway down in sydney as a circuit car (primarily street car).
O yeah, others suggested I put a v10 viper engine in charger as I get new technology, reliability, high power (more than Hemi they said - uhm... i doubt it) and RPMs. However... I hate the sound of the 10. I like v8s and why cant a v8 be made to make the power Im after 600-650 with reliability and gearing to get enough top speed to run with the best of them and probbably out accelerate them out of corners.
DUnno but my heads spinning.
wmhjr
10-30-2010, 04:34 AM
A standard block pontiac does :)
Just yanking your chain. I know what you were trying to say. Us "off brands" are just a little sensitive, and us pontiac guys give instructions to chebbies every day on what torque is REALLY all about :)
wmhjr
10-30-2010, 04:56 AM
Lee, I have to say that I'd love to get into a conversation with you over this and a couple of beers. There's a lot you said I agree with, and a good bit that I strongly disagree with. There are advantages and disadvantages to both small and big blocks - considering that you're also leaving out a whole lot of blocks. To use the 409 as an example is defective from the start. The 409 was a relative unique situation, and the entire combustion chamber difference is enough to keep it out of this contrast.
IMHO, forget about the block in your analysis, Lee. Think about the rotating assembly and the induction system and valve train. These days, big blocks and long rod motors can easily be built to spin fast - but the real point is how quickly the motor accelerates. Not just where the torque is. I've got a "harley type" motor as an example. It's a 113" long rod motor with both the bore and stroke a good big larger than "stock". Now normally that means it would be even more "torkey" but would have issues in the whole "increase rpm over time" equation. However, the superb R&R heads in that S&S case allow the motor to rev REALLY quick - through it's rpm range. Now, the entire Evo V-Twin design is obviously limited in terms of RPM range, so while it gets there real quick, there is only so far to go. I'm not running that motor past 6500, and peak torque is at around 4800 - though it's still pulling hard through 6500. The correct analogy in car engines for the whole tq vs rpm debate would be better shown by a F430 vs a 427 or something. The debate there is NOT the block design. It's the rotating assembly and valvetrain. There is IMHO far too little difference between a BBC and a SBC for the debate to be very accurate these days in this regard.
For the OP, the real question is what do you want to do with the car, how much, what are you willing to spend, and how much time are you willing to devote. The question why wouldn't 600hp at 4000rpm be as good as 600rpm at 8000rpm is again easily explained by us motorcycle guys. The working RPM range, when larger, allows for more flexibility in gearing and speed. But that's assuming you're making relatively equal amounts of torque through most of the power band, which is difficult to do. Otherwise, you're simply adjusting your gearing to take advantage of whichever design you have. At that point, weight and reliability become the largest factors.
But for the OP, let's keep it simple. If your car will be mostly driven on the street, building tq from idle up is simpy wonderful. There is nothing like being in 5th (overdrive in a TKO600) and being able to simply press the gas pedal a bit to increase speed up a hill and pass somebody. And, the motor is not being pushed - and I'm using less fuel. OTOH, if it's mainly a track car (I'm talking road and not drag) then a lighter motor helps with weight distribution. Don't forget though that I'm betting I'll go far longer between rebuilds as I'm making over 550lbs tq pretty much ALL of the time - through my entire rpm range - meaning I won't have to hammer my motor quite as much as somebody running for example a large displacement SBC. And I've got more material in my cylinder walls, etc.
This debate will never get resolved. It can't be. Too many variables. But I'm thinking that just for this debate, LS is pretty hard to beat.
10-30-2010, 02:43 PM
wmhjr - just for clarrification...
Thats Big Block?
Thats Big Block also? Going far longer between rebuilds, saying the engine will last a lot longer (more durable/reliable)?
While SB = lighter/better weight distribution? This can be overcome via other means if the choice is BB though cant it?
Charley Lillard
10-30-2010, 04:25 PM
Shifting takes up valuable track time. If you can wind a little higher instead of shifting I think that time from point a to b will be faster.
Jim Nilsen
10-30-2010, 05:41 PM
Especially at an autox track that keeps you in 1st gear looking for and needing 2nd !
79-TA
10-30-2010, 06:37 PM
That works both ways. Ideally, your engine makes torque everywhere and can rev high. If it's one versus the other, the high revving engine might save you from upshifting at the end of a straight, but the torquey engine might save you from downshifting in another scenario.
Vegas69
10-30-2010, 08:36 PM
That's an awful lot of speculation. The day you out run Mark Stielow in anything, I'll be the first to congratulate you. You have a looong way to go.
wmhjr
10-31-2010, 05:26 AM
Thats Big Block?
What I was trying to say is that you can certainly build a SB to generate tons of low end torque, but you'll make sacrifices. How exactly do you generate torque low? Think about it. Really it's like I said, this discussion isn't really about high vs low rpm. It's about more than that. Take for example the engine in a Honda S2000. Great little engine that makes good power. But down low it's not a rocket. You need to KEEP the motor revving high to make power. Now, if you could generate a flatter tq curve it would be a different story.
But yes, I stand by my point that a flatter and higher tq curve motor that doesn't need to spin as hard and has more meat (like for example a long stroke BBC, a poncho SB) may be a more "driveable" and "reliable" choice for a mainly street car. For a pure race car it's way different.
camcojb
10-31-2010, 06:28 AM
uh.....yeah. :) I haven't ridden in Marks newest car, but I rode with him at Thunderhill in the Mule, and the power was not an issue, we were flying through the field of track cars and race rubber in a street car with full street tires. He has a lot of experience driving high horsepower cars with street tires.
Jody
Scott Parkhurst
10-31-2010, 07:35 AM
Until the 'speculators' show up on-track and prove their points, I'm not buying their logic. There are too many guys who actually have running cars and show up at events to listen to philosophers like this who either don't have running cars or don't show up at events to showcase them.
With regard to the original post, I humbly submit that compromise is key. We (as a group) are fielding street cars. That immediately firms up a few things - like sub 9,000 rpm engines. So, make the best sub-9,000 rpm engine you can. Whether that's a small- or big-block is less important than the car's ability to put that power down and the driver's ability to control it.
It also matters if we're talking about a tight, twisty auto-cross course (adequate power to get out of shape is relatively low), a road course (longer straights and a wide range of tight and sweeping turns challenge the driver and suspension to stick all the way around), or an open road deal like Silver State (power and aero become priorities as the road is pretty much straight and flat, and the engine's durability will be tested as it must make steady power for more than an hour under high duress).
Building one, single car than can perform well at all of these places is an even greater challenge, and engineering a car capable of such performance borders somewhere between art and technical genius.
tazzz25906112
10-31-2010, 07:58 AM
Thanks guys.
For the kind of power you're looking for and the requirements/budget you're speaking of,,,,,, I can't see where there is any other choice than a newer LS type build......
In my opinion I'd concentrate on the suspension/braking area first and use what is let for the drive train as far as budget balances go.... That is one heavy car and if you want to cheat the odds's a little look into stock appearing light weight panels for the car. I've been playing with Carbon composites on my TA's (and soon on my 2nd Gen Camaro's)..... Hell loose a pile of weight up front (and anywhere else) and balance out the car a little and you'd be surprised how much of a difference that'll make...
Also be smart and ask the king of Charger corner carvers (fellow board member/moderator Bill Howell) for some advise...... I'm unaware of anyone with half the seat time in any single Charger as he has...... Bill is a "great guy" who would likely put you on the right path with pleasure..... I believe Mrangry on the board here is a big Mopar player too (and has a sick 68 or 69 come to think of it)..... I believe he is extremely knowledgeable as well (just don't know him as well as I know Bill so sorry for not immediately mentioning him as well)...
Continue looking for impute from knowledgeable sources,,,, "make a solid build plan and stick to it" because after all this is your dream car,,, build it your way.
Jim Nilsen
10-31-2010, 08:38 AM
I have always looked at the whole thing about what it takes to beat someone and I always get reminded of the spinning tire and loss of time and acceleration. It doesn't matter what makes the tire go it is how it wants to make it go that counts. That is where driver input and output make the whole thing beter for one person and not another.
I have found I like more RPM's on tap and the control I get from it in the lower gears. Think of it in pedal travel/rpm and you get the idea of how your foot has more control. With just the tap of the pedal the high tq low rpm engines start to spin the tires fast and in corners that is not going to make you faster.
It's all about how you can drive a car to me and the more experience I get at the track the more I like the extra RPM's.
wmhjr
10-31-2010, 08:41 AM
Scott, not sure which "speculators" you're talking about here. I kinda agree with you here. Remember that some of us haven't had the opportunity to get to some of the tracks you've been at, but may well be putting their cars through the paces as much as possible. For me, though I know I don't have the kind of build to really challenge Penny or Mary (that term compromise comes to mind) you can expect to see me at MMCC and/or the Motor State Challenge, and likely RTTH in 2011! I know I'm gonna get smoked but at least it ought to be some good guys laughing at me while it's going on.
Couldn't agree more. That's why I'm more comfortable with torquey motors. JMHO. Because when you add in the activity of just cruising down the road, we've all got to admit that low end torque is really optimal for cruise driving. It all depends on what you are trying to do. There's no one recipe for success. If there were, we'd all be building exact clones.
Scott Parkhurst
10-31-2010, 08:51 AM
Agreed- and I'm anxious to see your GTO 'vert come out and play! Love the Ponchos (just sold my '65 project...) and yours is better than most.
Check your PMs, too!
shortrack
10-31-2010, 09:08 AM
To the OP.....if your running a 68 Charger I would say build a big block 440/512 or whatever with alum heads/intake.....you need torque to move a heavy car.
This guy runs an all aluminum BBC in this track/street car and it eats Murcialagos for lunch at the track (the guy actually owns a couple of Ferrari's) .....he says in the article that hes had small blocks in heavy track cars before and they cant beat the torque of a big block so he built this all alum engine as the best of both worlds...big block torque/small block weight.
https://static1.pt-content.com/images/pt/2010/10/67chevelle-1.jpg
tazzz25906112
10-31-2010, 11:52 AM
I love Aluminum BB's,,,, that is the BB aluminum domain that I was eluding to in my earlier comments....
A way expensive way to go,,, but one Hell of a lot of fun doing it....
https://static1.pt-content.com/images/pt/2010/08/555-1.jpg
I hear him on the Ferrari-Lambo front, it's a blast when you see their jaws drop in surprise ;-)
Roadrage David
10-31-2010, 12:50 PM
Some time ago i posted a post about me and my car battling it out on the dutch and german high way. against modern great euro cars.
never lost of any of them beat the snot out of porses(panamera 911 gt3 ecetera ferarri,s. ecetera..
Biggest scalp i took was a brand spanking new Aston Martin Vantage past him at 190 mph!!.
Afther i duct out of his slip stream.. at 6200 rpm with my 462ci 4.25 stroke Pontiac powerd 68 firebird!!! 530hp 577lbs feet of torque. 3.42 rear ratio 0.67 overdrive tr2004r...
This old set up never lost a highway battle. Right now we are working on a 475ci 4 inch stroke aluminium Pontiac engine 730 hp 700 lbs tq 7200 rpm!!. and a compleet new build up Firebird called ""Road Force One"".
I can tel you one thing, not a modern euro fighter that wil last aganst it, and il take a NA engine to a fight any day against a turbo ore twin turbo powerd V8, on the track .. the more hp those engines have the quiker they lose....... In my opinion twin tubo,s 1000/1500 and 2000 hp is just for bragging rights..
Last but not least the traditional pontiac engine hase always been the best ""street"" engine a intermidiate block equipt with aluminium heads and manifold hase the weight of a sbc, but BBC torque.........Last but not least it was Smokey unich that said about pontiac and i quote""Dont Rev it up GEAR it UP"" in a time when afthermarked wassend there like now.
406 Q-ship
11-01-2010, 08:42 AM
I think I can shine a light on why your example is the way it is. Yes you can get a 528 Hemi to rev to 8000 and easily make 650 HP, or you can make the same 650 HP with a 360 spining to 8000. Both combinations will be high strung and expensive to build. Both will require highly detailed and exotic material in the rotating and valvetrain due the the high RPM. The 528 will not last as long due the weight of the recipricating assembly and the long arm crank, the 360 just isn't slinging the same kind of weight give it a durability advantage. As the lenght of stroke increases it hughly increases the load on the crank due to Moment of Interia, (the 528 will never accelerate as quickly as a shorter stroke 360 either), remember that as the RPM level doubles the stress increase to a factor of four. Durabilty in this combination is closely tied to the size of the engine the weight required to get the engine to that size.
wmhjr
11-01-2010, 09:19 AM
Actually in the above comparison, however don't you need to think it a little more through? Why would you need to rev to 8k with the 528 to make 650hp? 600-650hp in a 528 is frankly not that tough to build - it does not require it be high strung. It's the revving to 8k (when it isn't required) that creates the issues. That's the point. We're talking low RPM vs high RPM here in this post - NOT big vs small block. I know this topic is easy to go in multiple directions. But in a large displacement motor you can develop the same power without spinning (other than the tires :) ) so much. So the OPs question really is whether or not you "need" that higher RPM range. There are a number of perspectives. And somebody called it right earlier - it's all about compromise. Personally, I'm more comfortable with a high tq low RPM motor making the same power if it's mainly a street car. If the car is mainly raced, then depending on what kind of racing it's a different story and there are folks here FAR more experienced than I. I think somebody else made a great comment early on also - this is all theoretical. Unless equal time and attention is focused on the chassis/suspension AND driving technique, either choice (high vs low rpm) will suffer greatly. I'm guessing people like Mary, Brian, Mark could likely run circles around me in my 600hp car if they were driving a bone stock car - simply because of how much more AutoX experience they have.
A final note. I do not believe personally that a small block 360 making 600hp with a "wild cam" "revving its head off" will last longer than a 528 that's "sleeping at 3k to 6k". It might last longer in general if you're pushing the 528 repeatedly to 8k, but not if you're staying at 6500 or lower. JMHO.
Bottom line is that depending on the course, speed and acceleration are functions of rpm and tq. The larger the rpm range you can USE, then potentially you can reduce required shifts. Combine this with your ability to transfer power to the ground without melting tires, and the real comparison is TORQUE CURVES!!!!!!! Because it's the nature of your tq curve that limits gearing for a particular type course. Bottom line is the wider the usable power in a tq curve, to me the more flexibilitty you have in taking advantage of it. I guess also combined with how quickly the particular motor can rev through that usable curve.
79-TA
11-01-2010, 10:23 AM
The OP said 600-650 hp and 700 lb-ft of torque. The horsepower figure immediately makes the car magazine-reading portion of my mind think, "oh LS7 with some cam," but that wouldn't supply the desired torque figure. Nevermind that it's a GM engine and the car is a Charger.
By laying out these figures, you've already dictated what you want your torque curve to look like. More torque than horsepower means that the torque curve will be higher in the low rpm range with max torque occuring quite a bit before the 5252 rpm cross over point (the point where power measured in horsepower happens to equal the amount of torque in lb-ft.)
To get that kind of torque, I'd think some sort of derivative of a 440 (bored and/or stroked to a greater displacement) would work well. The more aluminum to save weight, the better.
If you plan to do any amount of drag racing, just go for the torque. A bigger, flatter torque curve makes the car more flexible as a driver and track toy. I'm not sure, however, that 700 lb-ft is really necessary. Which I guess touches on the OP's original question. Maybe 500-600 would be an epic enough amount?
I'm sorry, I haven't added much new to the conversation with this post, but does the 700 lb-ft figure grab anyone else as a bit excessive?
wmhjr
11-01-2010, 11:26 AM
Yes. I think it's going to be REAL hard to control 700lbs unless the chassis has a lot more money and time spent on it than the engine. JMHO. I'm still trying to figure out how to control the 600lbs I've got.
JEFFTATE
11-02-2010, 07:13 AM
McClaren used Aliminum Big-Block Chevys , and ran very well in the Can-Am Series in the late 60's/early 70's.
Ferrari entered the 512( 5.0 liter V-12) and 712( 7.0 liter V-12 ) in the Can Am , but did not compete very well with the big bore American powerplants ..
For a street-car , torque is king , whether you use a small block or big block to make it.
Low RPM cruising saves engine wear and yields better gas mileage .
On a race car , often times there are engine size limitations , and the higher RPM makes more horsepower for a given cubic inches.
John Wright
11-02-2010, 07:54 AM
engine size limitations , and the higher RPM makes more horsepower for a given cubic inches.Yup, engines are basically an air pump...the more air/fuel you can pump through them, the more power, and if cubes are limited, then you have no choice but to increase the revs to get more air/fuel through the n/a engine.
Jim Nilsen
11-03-2010, 02:50 PM
It has always seemed to be that if you couldn't rev past 5250 RPM torque was all you could count on which made the big blocks feasable with taller rear gears to go forever in the old days and it is still the same today. The killer HP that a big block makes when you spin it up is exponential.
I have trouble with 400 ft lb of torque staying planted in 1st and 2nd so that much power would take it to 3rd and 4th and that is very fast territory and you better have room if you plan to light them up, which will happen too easily with little pedal travel. I have a lot of experience to gain to be able to be in total control at the 3 digit speeds on a track where each lap is different because of all the factors involved. Brakes always change a little and stopping is where a lot is gained in time.
I truly think that no matter what engine he puts in the car it will be as much as he expecting and more ! I hope he gets what he wants and likes it.
