richiedd
10-27-2010, 03:50 PM
Looking for some views on a cam recommendation from my engine builder. I am building a stout(ish) street motor and my builder recommends the following comp hydraulic roller cams. Would they work well as a combination (aiming for 600hp/600lb/ft)?
Car is a 77 TA, 462cid, 3700 lbs, 3000 stall converter and 3.23 rear. E heads to flow ~310 - 320 cfm
SERIAL # O 1390-08
> PART # 51-000-9 CAMSHAFT, P8 PONTIAC V8 265-455 1955-81
> CORE C51-9C CAMSHAFT BLANK, P8 PONT 265-455, 5160
> GRIND # P8 3115B /3171B HR108.0
> DURATION @ .050 INTAKE 246 ROCKER ARM
RATIO
> VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 258 INTAKE
1.50
> VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .4000 EXHAUST
1.50
> VALVE LIFT INTAKE .600 LOBE LIFT EXHAUST .3610
> VALVE LIFT EXHAUST .541 LOBE SEPARATION 108.0
> DURATION .006 INTAKE C/L 108.0
> TAPPET LIFT INTAKE 306 CAM ADVANCE 0
> TAPPET LIFT EXHAUST 325 HYDRAULIC Y
> VALVE TIMING .050 OVERHEAD CAM N
> VALVE OPEN INTAKE 15 JOURNAL DIAMETER STD 1.899
> VALVE OPEN EXHAUST 57 RECOMMEND VALVE SPRINGS
> VALVE CLOSED INTAKE 51 DEPARTMENT P
> VALVE CLOSED EXHAUST 21 SPC INSTR FOR CUSTOMER
> SERIAL # O 1391-08
RATIO
1.50
1.50
Rich
SERIAL # O 1390-08
RATIO
1.50
1.50
> SERIAL # O 1391-08
RATIO
1.50
1.50
Rich
