View Full Version : Ridetech Airpod and Shockwaves
prine68
10-22-2010, 01:37 PM
Hey guys, here's what I'm thinking about doing. I'm looking to purchase the Ridetech Airbar system along with the Master Series S/A Shockwaves for my '68 Camaro. The part I'm still thinking about is whether I want the Shockwaves or to go with Coilovers? I'm going to be using a 12 bolt rear with the set up. If anybody is running something similiar to this set up now let me know how you like it, mines going to be mainly street use, but working towards autocross use once it's done.
If somebody here sells what I need and can shoot me a PM with a price, I'd appreciate it.
MonzaRacer
10-23-2010, 07:57 PM
spend the cahs and try BlackWaves first then if you like them and the ride(some say they hate the ride or cant get it to work right) then when you get up into some real autocrossing you may want to upgrade.
Honestly if you intend to autocross, I would simply give Darren or one of them over at RideTech a call and talk it out.
BUT I am still saving for my ShockWaves/BlackWaves for my Monza as I am doing a custom set up.
I honestly can brag enough about my CoolRide set up and I am sure the only way to be better is to use ShockWaves.812-481-4787 is number I have, give them a call! They are a sponsor and direct help can be a good thing!
Good luck.
marolf101x
10-24-2010, 09:10 AM
Here's the link to everything we offer for the first gen Camaro:
http://www.ridetech.com/store/musclecar/?subcats=Y&features_hash=V174
Here's the AirBar alone:
http://www.ridetech.com/store/suspension-components/airbar/1967-1969-chevy-camaro-firebird-airbar-systems.html
What are you doing with the front end? That will tell you a lot about which kit you should use.
You can run just rear Shockwaves, but the e3 control system will not have full functionality as you need to run 4 corners.
If you want to do air, but want to build it in stages you can simply use a manual 2-way control system, or you can go even simpler and use just a Shrader valve (no in-cab control).
We now offer coil overs as well:
http://www.ridetech.com/store/suspension-components/airbar/airbar-coil-over-system-single-adjustable.html
