View Full Version : C5 brake people, what studs did you use?
Vicinity
10-22-2010, 10:19 AM
Anyone who installed C5/LS1 brakes, what size studs did you use? The stock ones are too short for my rotors and spacers, so I need to upgrade. No auto place near me has studs with the same knurl and shoulder as the stock studs. Any ideas?
Vicinity
10-22-2010, 10:29 AM
Whoops, clicked the wrong subforum, can any Mods move this to brakes, please?
Z06vet
10-22-2010, 10:35 AM
Try a napa hub store- the one with the parts wharehousein back. Not sure if you have one there, but they had a ton of studs. My front C4 spindles had long studs in them for wheel spacers & i had to find shorter ones- go figure. I may still have the long studs- what length do you need?
Scott
Vicinity
10-22-2010, 10:51 AM
I need about 2.25 to 2.5 inch. I've found a set from Moser that's 2.85, but I think that's too long, it might stick out past the spacer. I think the Napa I went to has a warehouse, me and the guy there spent over an hour looking through books for a stud that would fit, we had no luck.
Throttle
10-22-2010, 11:01 AM
I bought mine from Summit..
Moser 12mm x 1.50RH
2.50 Underhead length
http://www.summitracing.com/parts/MSR-8255/
Vicinity
10-22-2010, 11:16 AM
Moser 12mm x 1.50RH
Holy crap, .505" knurl, will that fit a first gen?
Throttle
10-22-2010, 11:26 AM
I have a kit that has 3rd Gen Camaro Hubs.. You can always drill them out.. Factory a 1st Gen is .472 knurl, So I would see if you could drill them out to fit bigger.. I did it on my Brother Mustang..
Here are some pics of the brakes for the 72 Camaro..
https://static1.pt-content.com/images/pt/2010/10/2588490301_7fa630c855-1.jpg (http://www.flickr.com/photos/26414016@N00/2588490301/)
Camaro Big Brake Kit (http://www.flickr.com/photos/26414016@N00/2588490301/) by throttle_junkie1972 (http://www.flickr.com/people/26414016@N00/), on Flickrhttps://static1.pt-content.com/images/pt/2010/10/2854108467_7524bb3339-1.jpg (http://www.flickr.com/photos/26414016@N00/2854108467/)
September 12 2008 004 (http://www.flickr.com/photos/26414016@N00/2854108467/) by throttle_junkie1972 (http://www.flickr.com/people/26414016@N00/), on Flickrhttps://static1.pt-content.com/images/pt/2010/10/3402841661_4f1f6268c4-1.jpg (http://www.flickr.com/photos/26414016@N00/3402841661/)
March 31 2009 012 (http://www.flickr.com/photos/26414016@N00/3402841661/) by throttle_junkie1972 (http://www.flickr.com/people/26414016@N00/), on Flickr
Vicinity
10-22-2010, 11:35 AM
3rd gen hub? It fits fine? Would a 4th gen hub fit, too?
gearheads78
10-22-2010, 11:37 AM
I used ARP but I don't remember the part#. They were 3" and I cut them down to the length I needed.
Vicinity
10-22-2010, 11:44 AM
I thought cutting the stud would cause some loss in strength...?
gearheads78
10-22-2010, 12:17 PM
Other than maybe at the 1st thread or 2 how would it loose strength. I cut them so they would be engaged in all the threads in my lugs. My 1st cut was about 1/8" long and I ground them down to final size on a belt sander and tapered the edges a little to ease starting.
Vicinity
10-22-2010, 12:25 PM
I read it on the internet. :doh:
srh3trinity
10-22-2010, 02:03 PM
Do you remember the specs that you turned down the third gen hub to or did you buy the hub from Tobin? I picked some up at the junkyard and I am going to take them to the machine shop.
Throttle
10-23-2010, 10:41 AM
I got the kit off of http://www.flynbye.com/
Great kit, same with everything to run these brakes and it wasnt over the top expensive..
Vicinity
10-23-2010, 01:11 PM
Sweet Jesus, they have some nice prices.
Vicinity
10-23-2010, 05:19 PM
Hey, would you recommend new hubs? They seem to be priced great and just in my range, I'm considering it now, only thing I'd worry about is the lugs not matching up. Do you know the thread size/spacing and length of the studs?
Throttle
10-23-2010, 05:49 PM
The factory studs for that setup is what I posted earlier, but shorter by .50.. So that would make them 2 inches long.. As for the lug pattern, it is the same as any Chevy Passenger Car lug..
Vicinity
10-23-2010, 05:52 PM
They offer factory conversion and ARP studs, the factory ones are what you bought and are 2"?
Throttle
10-23-2010, 06:23 PM
Yeah, that is what it came with.. You could get it how every you want it.. Just give him a call, he is a great guy..
Vicinity
10-23-2010, 06:28 PM
I plan to on Monday, thanks for the link man. Those ebrake cables look pretty good, too, if I can't get the stock LS1's to work.
Olav
10-24-2010, 02:27 AM
12-1.5 X 54mm serrated bolt part number Dorman 610-323
I used these for my 3-gen hubs/ rotors i machined for my 2-gen.
Vicinity
10-26-2010, 11:51 AM
I guess he's behind on his calls, he supposed to call me back tonight. Definitely thinking I'll just get new hubs and replace the rear studs, so much less work, lol.
sebtarta
11-01-2010, 04:53 PM
Kore3 has better prices in my opinion.
Late reply is late...:D
SLO_Z28
11-01-2010, 07:02 PM
Kore 3 has a better part, Ebmiller has the better prices.
Its easy to make your own hub. Buy a 3rd gen rotor(cheapest possible should be about $35), cur the rotor part off, and cut the outside edge of the hub down to clear the vette rotors, you just have to bevel the outside edge 45 degrees about .300-.400 . Get the Kore 3 or Flynbye kit for $70 ish bucks and buy your calipers and abtunment brackets used. You can put together C5 brakes for well under $500.
Im lucky that I have access to a machine shop in northern california, but even paying for it, its probably a cheap job.
http://www.nastyz28.com/forum/showthread.php?t=74546
Vicinity
11-03-2010, 12:13 PM
I just ended up buying studs from Tobin at Kore 3, the Flynbye guy was wicked hard to get on the phone, so I gave up and just get my stuff through K3. I'll go with those ATS spindles eventually, so I guess this is a better temporary solution. Well, at least cheaper.
