View Full Version : Swedish Camaro 1969 Pro Touring build (LS2/T56, AME Subframe)
ProSwede
10-20-2010, 07:42 AM
Hello all, not so many builds from outside US here so I thought I´m gonna help that a little....
So here it goes, bought a 69 (blackplate car) in California a couple of years ago, a real nice rustfree car that was driveable...the car was very untouched over the years...only one repaint with white Z/28 stripes, and it still got the numbers matching tranny, the 350 in it was changed though.....
https://static1.pt-content.com/images/pt/2010/10/S6301932-1.jpg
Here it is in the sellers garage the day I bought it....
https://static1.pt-content.com/images/pt/2010/10/S6301934-1.jpg
The interior...
https://static1.pt-content.com/images/pt/2010/10/S6301936-1.jpg
Pretty straight...
https://static1.pt-content.com/images/pt/2010/10/S6301949-1.jpg
The old 350...this engine (and tranny) later founds it way into my 57 Bel Air...
https://static1.pt-content.com/images/pt/2010/10/S6301950-1.jpg
The cowl tag...dusk blue car with white vinyl roof according to the numbers....
https://static1.pt-content.com/images/pt/2010/10/S6301993-1.jpg
Here the car has arrived to Sweden in the spring of 2009, took thoose ugly 80-ish something wheels off and replaced them with a set of rallies that I had laying around....I also continued the Z/28 theme and got some new Z/28 emblems for the car.
https://static1.pt-content.com/images/pt/2010/10/S6302002-1.jpg
I then got the car thru Swedish inspection and got it registered.
https://static1.pt-content.com/images/pt/2010/10/S6302388-1.jpg
And after that some 18" Boyd wheels took place on the car and I drove the car the summer of -09...but with a completly standard 350 engine and tranny and drum brakes the car wasn´t that much of fun...it looked faster than it was but handled, accelrated and braked terrible, so something was got to be done ....
https://static1.pt-content.com/images/pt/2010/10/S6302408-1.jpg
So the teardown begins...
https://static1.pt-content.com/images/pt/2010/10/S6302410-1.jpg
I realized when I tore the car apart that the frontclip has never been off this car before, I found orginal paint between the front sheet metal parts...
https://static1.pt-content.com/images/pt/2010/10/S6302411-1.jpg
https://static1.pt-content.com/images/pt/2010/10/S6302412-1.jpg
sighted some cray markings under the 40 year old dust....
https://static1.pt-content.com/images/pt/2010/10/S6302413-1.jpg
after cleaning...anyone know what "218" means?
ProSwede
10-20-2010, 08:04 AM
https://static1.pt-content.com/images/pt/2010/10/S6302415-1.jpg
the orginal dusk blue from -69....
https://static1.pt-content.com/images/pt/2010/10/S6302420-1.jpg
not much rust here...:-)
https://static1.pt-content.com/images/pt/2010/10/S6302421-1.jpg
subframe removal going on...
https://static1.pt-content.com/images/pt/2010/10/S6302424-1.jpg
https://static1.pt-content.com/images/pt/2010/10/S6302430-1.jpg
subframe away from car...
https://static1.pt-content.com/images/pt/2010/10/S6302426-1.jpg
well...I guess these haven´t been replaced recently....
https://static1.pt-content.com/images/pt/2010/10/S6302433-1.jpg
car without the "sub". Now its was time to begin to look what was nessecary to do for the upgrades I have planned for the car....
I started to look at the brake booster...or the lack of...
https://static1.pt-content.com/images/pt/2010/10/S6302442-1.jpg
https://static1.pt-content.com/images/pt/2010/10/S6302436-1.jpg
I took one from a 4th gen Camaro and cut away the mounting bracket...
https://static1.pt-content.com/images/pt/2010/10/S6302441-1.jpg
I fabricated a new bracket to fit the the 69 firewall...
https://static1.pt-content.com/images/pt/2010/10/S6302443-1.jpg
I had to get the lever from the 69 that connects to the pedal and weld it to the new pushrod...
https://static1.pt-content.com/images/pt/2010/10/S6302444-1.jpg
here it is mounted in the car...
https://static1.pt-content.com/images/pt/2010/10/S6302445-1.jpg
I took a master from a C5 Corvette (a direct fit) cause the lines is routed to the left...the F-body master line output is towards the engine.
https://static1.pt-content.com/images/pt/2010/10/S6302446-1.jpg
I took the firewall sealing from the vette and cutted it down to fit my firewall.
https://static1.pt-content.com/images/pt/2010/10/S6302448-1.jpg
pretty close to the inner fender mounting but there are a couple of millimeters space...
neki67
10-20-2010, 08:24 AM
Welcome, always good to see some fellow European toying around with some good old American iron!
ProSwede
10-20-2010, 08:26 AM
https://static1.pt-content.com/images/pt/2010/10/S6303411-1.jpg
Got a big package from US...The new subframe! :-)
https://static1.pt-content.com/images/pt/2010/10/S6303431-1.jpg
Rolled under the car for test fitment...
https://static1.pt-content.com/images/pt/2010/10/S6303414-1.jpg
A truly work of art!
https://static1.pt-content.com/images/pt/2010/10/S6303422-1.jpg
C5 AC Delco sport rotor...
https://static1.pt-content.com/images/pt/2010/10/S6303435-1.jpg
engine/tranny fitment for the first time....this is a borrowed LS1, the LS2 hadn´t arrived at the time...
https://static1.pt-content.com/images/pt/2010/10/S6303437-1.jpg
https://static1.pt-content.com/images/pt/2010/10/S6303523-1.jpg
started to look at other things like the radiator mounting....ended up with a 4th gen rad. with fans and a cut down upper C5 plastic rad.support mounted to the 69 rad. support. The rad. hoses from the C5 vette also seems to fit pretty well...
Ron.in.SoCal
10-20-2010, 08:30 AM
Very nice car to start with and a great project. Some guys (me) would kill for something that original and rust free.
ProSwede
10-20-2010, 09:49 AM
https://static1.pt-content.com/images/pt/2010/10/GTO201-1.jpg
Bought a whole donor car to get the LS2 and T56, it´s GTO from 2005 with 85K on it...
https://static1.pt-content.com/images/pt/2010/10/GTO204-1.jpg
https://static1.pt-content.com/images/pt/2010/10/GTO206-1.jpg
https://static1.pt-content.com/images/pt/2010/10/S6303553-1.jpg
Here the GTO engine has taken the mock up LS1 place...
https://static1.pt-content.com/images/pt/2010/10/S6303552-1.jpg
https://static1.pt-content.com/images/pt/2010/10/S6303554-1.jpg
Guess I have to do something about that GTO lettering on the covers later on...
This is what I am at to this day, now I need to order a lot of stuff like headers, fuel system, rear end system (some kind of coilover setup) and a harness for the engine and so on....I´m going over to the States in about a month so I´m in the middle of research work now for everything I need to buy....
coolwelder62
10-20-2010, 04:24 PM
You need to use AME header's, they fit there sub frame great. Most other's don't.I used a 99 chevy 1/2 ton p/u truck fuel pump. its fits thur. the sender hole in the stock fuel tank.Speedway motors .com, lincoln ne, 1.800.979.0122 has the fuel reg./filter and fitting's cheaper than anybody else.Also have adapters for temp and oil senders. fuel lines and fittings cheaper also. I have the same AME/GTO T-56 in my 69 camaro.you can email me at [email protected] and I can walk you thur. any help you will need.Spear tech did my ecm/harness.Scott.
osdmike
10-20-2010, 08:01 PM
Welcome! Andreas!
That´s a really nice looking car!
Ser ut att bli ett riktigt trevligt bygge!:smoke:
banksy_11
10-20-2010, 10:10 PM
[QUOTE=ProSwede;734560]https://static1.pt-content.com/images/pt/2010/10/S6303411-1.jpg
Nice project! Im also restoring a camaro outside the US and im planning to get a new subframe from the US..
Can you give some info about your subframe? like where did you get it and around much did u have to pay for the shipping etc.. :)
wellis77
10-20-2010, 10:23 PM
Welcome! Great build you have goiong.
Danny lindstrand
10-21-2010, 12:43 PM
Sweet build ,great to see moore top of the line cars from Sweden
TGVettes
10-21-2010, 04:56 PM
always nice to see some builds from back home.
Tonny
Swede in Arizona
mc84_zz4
10-21-2010, 07:28 PM
That subframe is going to be light-years ahead in handling! of course the LS2/T56 is another tasty update.
If you have the entire GTO donor car, the back seats will look right at home, and the front seats are some of the most comfortable around (for the price).
ProSwede
09-08-2011, 10:50 AM
So it has been a while since my last update here, but things is moving along, but not in the speed that I want it to do...(too much other projects)
anyway, here are some updates....
https://static1.pt-content.com/images/pt/2011/09/S6304177-1.jpg
Fabricated some new engine plates at work...the old ones were just for mockup.
https://static1.pt-content.com/images/pt/2011/09/S6304178-1.jpg
https://static1.pt-content.com/images/pt/2011/09/S6304181-1.jpg
https://static1.pt-content.com/images/pt/2011/09/S6304182-1.jpg
https://static1.pt-content.com/images/pt/2011/09/S6304256-1.jpg
Mounted the ecm and relay/fusebox on the innerfender...the ecm will be hidden later when the fender is muonted. The electrical for the engine I had to send away, used the GTO harness that was on the engine and had it reworked at Current Performance Wiring in Florida, very happy how it turned out (well haven´t started the engine yet!).
https://static1.pt-content.com/images/pt/2011/09/S6304250-1.jpg
Clutch reservoir is mounted to the firewall....also seen is the remote bleeder. (will be hidden later)
https://static1.pt-content.com/images/pt/2011/09/S6304252-1.jpg
Intake tubing....engine cover from a Pontiac G8 GT.
https://static1.pt-content.com/images/pt/2011/09/S6304253-1.jpg
Lines for the PS made...
https://static1.pt-content.com/images/pt/2011/09/S6304249-1.jpg
Steering shaft done....Art Morrison headers also seen here...
https://static1.pt-content.com/images/pt/2011/09/S6304248-1.jpg
https://static1.pt-content.com/images/pt/2011/09/S6304246-1.jpg
Ripper
09-09-2011, 05:15 AM
Nice project!
A Pontiac heart in a Camaro - usually it's the other way around... ;)
Are you going to register it as a modified vehicle (through SFRO) or are you gonna chance everytime you visit SBP?
screamingscotty69
09-09-2011, 10:11 AM
Very nice project. Although it is pretty tame compared to some of the crazy build you guys do over there in Sweden land.
ProSwede
09-09-2011, 10:16 AM
Nice project!
Well the GTO LS2 is the same as in the Corvette, SSR, Trailblazer SS and so on so I think I´m fine with it... :-)
I have already been in contact with SFRO, to much modifications to just pass trough SBP, so yes, it gonna be registered as modified vehicle.
ProSwede
09-09-2011, 10:21 AM
Yes maybe, but it´s not that common with ProTouring Camaros here as it is in the US, we have plenty of first gen Camaros, but not so many in Protouring style, and I think I´m gonna be first in Sweden with Morrison frame....so it is kinda of a crazy build....
Tig
09-11-2011, 04:15 PM
Awesome. It really looks great man, keep it up.
CliffS
09-12-2011, 08:28 AM
Very Nice find, keep it coming!
ProSwede
09-16-2011, 11:37 AM
now it´s time for upgrading the rearend.....
https://static1.pt-content.com/images/pt/2011/09/S6304393-1.jpg
So I bought a Chris Alston G-link kit throgh Frank at Protouring superstore....
https://static1.pt-content.com/images/pt/2011/09/S6304384-1.jpg
The rearend itself is from a 1999 Camaro....
https://static1.pt-content.com/images/pt/2011/09/S6304382-1.jpg
Mockup...
https://static1.pt-content.com/images/pt/2011/09/S6304383-1.jpg
https://static1.pt-content.com/images/pt/2011/09/S6304385-1.jpg
https://static1.pt-content.com/images/pt/2011/09/S6304387-1.jpg
https://static1.pt-content.com/images/pt/2011/09/S6304390-1.jpg
https://static1.pt-content.com/images/pt/2011/09/S6304391-1.jpg
Before I welded the cradle I put some welding primer to the bare metal to prevent rust....
https://static1.pt-content.com/images/pt/2011/09/S6304394-1.jpg
On the ground for the first time with the new suspension.....
https://static1.pt-content.com/images/pt/2011/09/S6304388-1.jpg
I test fitted a swaybar from the same -99 Camaro the rearend came from and it seems to fit pretty well....only need to make some brackets for the endlinks....the width of the bar was perfect.....
https://static1.pt-content.com/images/pt/2011/09/S6304398-1.jpg
Rybar
09-16-2011, 12:02 PM
Project looks great, I'm not a fan of those 4th gen Fbody rear ends I blew up 1/2 dozen of them on my old 4th gen. I would look to beef it up or put something else in there.
ProSwede
09-16-2011, 12:50 PM
Yes, I´m aware of the weakness of these newer rearends compare to the older 10 bolts or 12 bolts...
coolwelder62
09-16-2011, 06:17 PM
Very nice.How long does it take for parts to show up over there from the states.I couldn't take the wait.It would kill me.Keep up great work.
Motown 454
09-16-2011, 07:09 PM
Nice install. It looks like a nice fit.
ProSwede
02-20-2012, 10:56 AM
Been a while since last update so I guess it´s time...
https://static1.pt-content.com/images/pt/2012/02/IMG_0584-1.jpg
Had the car teared down and started to do some paint prep work with the firewall and the new subframe and other small things...
https://static1.pt-content.com/images/pt/2012/02/IMG_0585-1.jpg
Converting to a bigblock style heater box so I decided to get rid of the holes for the small block heater box...also welded a lot of other holes that I ddn´t need anymore...
https://static1.pt-content.com/images/pt/2012/02/IMG_0586-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_0603-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_0592-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_0593-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_0606-1.jpg
The firewall painted...
https://static1.pt-content.com/images/pt/2012/02/IMG_0607-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_0608-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_0609-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_0610-1.jpg
ProSwede
02-24-2012, 10:30 AM
https://static1.pt-content.com/images/pt/2012/02/IMG_0611-1.jpg
Didn´t like the bolts that came with the frame from Morrison for the upper A-arms, they where inch bolts with washers and the A-arms are made for metric bolts (M10) so I mounted OEM Corvette C5 bolts for a much tighter and more OEM look...we will see if the length of these are enough later when I start to add schims for the A-arms....had them laying around anyway so.....
https://static1.pt-content.com/images/pt/2012/02/IMG_0612-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_0614-1.jpg
Rolled the frame under the car with 2 jacks...
https://static1.pt-content.com/images/pt/2012/02/IMG_0632-1.jpg
Caution made not to scratch the new paint....
https://static1.pt-content.com/images/pt/2012/02/IMG_0628-1.jpg
Prepared for the brake plumbing...
https://static1.pt-content.com/images/pt/2012/02/IMG_0630-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_0635-1.jpg
Engine is in...
https://static1.pt-content.com/images/pt/2012/02/IMG_0633-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_0638-1.jpg
Brakes from a C5 Z06...
https://static1.pt-content.com/images/pt/2012/02/IMG_0647-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_0641-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_0642-1.jpg
https://static1.pt-content.com/images/pt/2012/02/IMG_0644-1.jpg
ProSwede
04-09-2012, 09:23 AM
Time for an update....
https://static1.pt-content.com/images/pt/2012/04/IMG_0652-1.jpg
Started to fill some unnecesseary holes on the inner fenders...
https://static1.pt-content.com/images/pt/2012/04/IMG_0653-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_0650-1.jpg
Same with the Rad. support...
https://static1.pt-content.com/images/pt/2012/04/IMG_0648-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_0759-1.jpg
Then I send it all away to the blaster....
https://static1.pt-content.com/images/pt/2012/04/IMG_0758-1.jpg
https://static1.pt-content.com/images/pt/2012/04/IMG_0757-1.jpg
Some parts for the front end....the parts turned out really nice, no previous damage to them at all, only suface rust and old paint. :cheers:
kaboffa
05-05-2012, 04:33 PM
Deleted post
CruizinKev
05-06-2012, 03:51 AM
wow nice progress! looks great! :twothumbs
Gandalf
05-06-2012, 06:00 AM
First off - project is looking great. Nice work!
I do wonder though - the end-links on the front sway bar look like they are laid over way too much (even though I realize the suspension is unloaded - it doesn't look like it will improve any when on the ground). I'm not saying they won't work and AME might have revised their front bar since mine but this doesn't look right to me. Check they sent you the correct bar or maybe this bar didn't come from them? The ends of the 7/8" bar should be slightly longer and kick-out to sit over the end-links (still leaving you tire clearance). Maybe we can have Matt give us his opinion from these pictures.
In the mean time - here's a decent AME stock photo online to compare:
http://www.electronic-pr.com/pr/images/new_ame_660.jpg
G.
coolwelder62
05-06-2012, 06:12 AM
I do wonder though - the end-links on the front sway bar look like they are laid over way too much (even though I realize the suspension is unloaded - it doesn't look like it will improve any when on the ground). I'm not saying they won't work and AME might have revised their front bar since mine but this doesn't look right to me. Check they sent you the correct bar. The ends of the 7/8" bar should be slightly longer and kick-out to sit over the end-links (still leaving you tire clearance). Maybe we can have Matt give us his opinion from these pictures.
G.That's the way AME designed them to work.He has put it togather right.
Gandalf
05-06-2012, 06:16 AM
I'm not questioning his assembly - I just want to make sure he has the right part. I'm thinking what has to happen during suspension compression for the sway bar to be able to do its job.
G.
silver69camaro
05-08-2012, 02:18 PM
I'm looking into that right now. Proswede, did you buy the clip direct from us or from a dealer? Give me a PM when you can.
67SSDan
05-08-2012, 04:57 PM
Nice work man!! This thing is going to be awesome when you're done!
Dan
ProSwede
05-09-2012, 12:32 PM
G.
I think the pics is lying, when that photo was taken I didn´t had spring seat at ride height, and the endlinks wasn´t torqued down at all, (just loosely)and as you said the suspension is unloaded so the control arms is hanging very low causing that extreme angle....now I have the car close to ride height and that angle is pretty much gone...but I shall take a closer look to it. I did find this old pic though where you can see the part number of the sway bar that I got from AME....maybe Matt can confirm this is the right part?
https://static1.pt-content.com/images/pt/2012/05/S6303429-1.jpg
ProSwede
05-09-2012, 01:00 PM
I didn't realize that you had actually bought the Art Morrison front sub frame for your car when we talked about pro touring stuff and cars in general at the 16.000 control room couple of months ago.
Very nice. Im jealous as hell! It will be very interesting to here your reviews on the car when it is finished :)
Kör hårt / - "det hänger spaghetti ur tröjan" Kenny - smed 16
I´m not following? What/where is 16.000 control room???
ProSwede
05-15-2012, 10:53 AM
https://static1.pt-content.com/images/pt/2012/05/IMG_0777-1.jpg
Took the rearend down for detail work....also the undercarrige gonna get some treatment...:)
https://static1.pt-content.com/images/pt/2012/05/IMG_0791-1.jpg
https://static1.pt-content.com/images/pt/2012/05/IMG_0797-1.jpg
https://static1.pt-content.com/images/pt/2012/05/IMG_0798-1.jpg
https://static1.pt-content.com/images/pt/2012/05/IMG_0799-1.jpg
https://static1.pt-content.com/images/pt/2012/05/IMG_0801-1.jpg
https://static1.pt-content.com/images/pt/2012/05/IMG_0818-1.jpg
https://static1.pt-content.com/images/pt/2012/05/IMG_0809-1.jpg
Changed side of the backing plates so I get the calipers rearward of the axle instead of front as it is standard on the 4th gen axle...this way a get the park brake cable facing forward instead of backward, allowing a shorter cable and also I attend to hook them up to the orginal bracket in the frame, and from there go with 69 oem cables forward.
https://static1.pt-content.com/images/pt/2012/05/IMG_0815-1.jpg
https://static1.pt-content.com/images/pt/2012/05/IMG_0825-1.jpg
https://static1.pt-content.com/images/pt/2012/05/IMG_0823-1.jpg
Shortened 4th gen park cable attached to 69 frame bracket...
https://static1.pt-content.com/images/pt/2012/05/IMG_0824-1.jpg
Reshaped 4th gen bracket for the cable...
https://static1.pt-content.com/images/pt/2012/05/IMG_0811-1.jpg
Managed to fit the 4th gen swaybar perfect to the car...really happy how it all turned out...
https://static1.pt-content.com/images/pt/2012/05/IMG_0813-1.jpg
https://static1.pt-content.com/images/pt/2012/05/IMG_0832-1.jpg
CliffS
05-15-2012, 11:23 AM
Very nice!!!! I see you swapped the rear coul over springs. What lenght and springrate did you go for?
ProSwede
05-16-2012, 11:41 AM
Got these used from a friend, think they are 10" long and spring rate 300 LBS.
geberhard
05-24-2012, 09:58 PM
Hejsan!! Very interested in seeing the project coming along Andreas! Definitely great work so far. What are the plans with the rest of the car? Also have any links for SBP and also inspection of the car once it gets to Sverige? I.e. is it easier to bring a car that has the LS swapped in already (prior to inspction), or have it inspected andthen start the project? Also any info or difference on cutover dates(i.e. I believe I was reading easier to bring pre 69 cars?) All help (in Svenska or English or links greatly appreciated!)
Tack!
Gui
FRENCHBLUE72
05-25-2012, 02:37 PM
How long does it take for you to get parts.. I hate waiting for parts...
ProSwede
03-11-2013, 08:08 AM
Been a long time since update, but that doesn´t mean nothing have happened! The car is now test drived and all worked out really well, I´m really happy how everything turned out....but lets go back in time and go from where i left last time....
https://static1.pt-content.com/images/pt/2013/03/IMG_0835-1.jpg
The new tank from Spectra...
https://static1.pt-content.com/images/pt/2013/03/IMG_0839-1.jpg
Corvette C5 filter mounted to the frame rail...
https://static1.pt-content.com/images/pt/2013/03/IMG_0837-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_0836-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_0842-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_0852-1.jpg
The mounting bracket for the orginal fuel line....
https://static1.pt-content.com/images/pt/2013/03/IMG_0850-1.jpg
Made my own copy of the factory bracket and used a "cage nut" instead....then I spot welded these to the floorpan....
https://static1.pt-content.com/images/pt/2013/03/IMG_0843-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_0848-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_0855-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_0856-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_0857-1.jpg
Fuel line mounted....
https://static1.pt-content.com/images/pt/2013/03/IMG_0858-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_0860-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_0861-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_0862-1.jpg
ProSwede
03-11-2013, 08:18 AM
double posting
ProSwede
03-12-2013, 11:34 AM
And now some electrical work...
https://static1.pt-content.com/images/pt/2013/03/IMG_08801-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_08791-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_08971-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_09131-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_09091-1.jpg
Was able to use a complete Pos. cable from a Dodge Charger (2006-)....was perfect in lenght....
https://static1.pt-content.com/images/pt/2013/03/IMG_09471-1.jpg
Was also able to use this isolated "connector" that came with the Dodge cable...perfect way to go thru the firewall instead of just draw the cable thru....
https://static1.pt-content.com/images/pt/2013/03/IMG_0654-1.jpg
Engine side of firewall...
https://static1.pt-content.com/images/pt/2013/03/IMG_0655-1.jpg
With the cable to the starter attached....(the rubber flap then completly seals it when put in place)
https://static1.pt-content.com/images/pt/2013/03/IMG_0914-1.jpg
Bought some new gauges rom Dakota Digital....really like these gauges...was perfect for my application...
https://static1.pt-content.com/images/pt/2013/03/IMG_0917-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_0946-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_09441-1.jpg
Mounted the control box up under the speaker grille in the dash....(or just left of the orginal AC vent location)
https://static1.pt-content.com/images/pt/2013/03/IMG_09321-1.jpg
Continued with some modifications for the ash tray....mounted the OBD II connector in there....
https://static1.pt-content.com/images/pt/2013/03/IMG_09351-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_09341-1.jpg
Mounted a more modern 12V plug for GPS/mobile phone charger etc....
https://static1.pt-content.com/images/pt/2013/03/IMG_09361-1.jpg
https://static1.pt-content.com/images/pt/2013/03/IMG_09371-1.jpg
makoshark
03-13-2013, 01:14 AM
Nice job. I really like your custom brackets for mounting the fuel lines. Where did you get that accessory port from? I've been hunting for a couple myself.
ProSwede
03-15-2013, 12:20 AM
If you mean the positive port that go thruu the firewall its from the same Dodge Charger I took the cable from...I used the cable in its full lenght and it fit perfect.
Gandalf
03-19-2013, 09:10 AM
Looking good man - keep it up! I like the underfloor clips and the re-purposing of the ashtray!
G.
Chadman27
03-19-2013, 04:45 PM
Nice work!
ProSwede
06-24-2013, 08:52 AM
New Driveshaft mounted....
https://static1.pt-content.com/images/pt/2013/06/IMG_0951-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_0954-1.jpg
Some prep work before paint...
https://static1.pt-content.com/images/pt/2013/06/IMG_0955-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_0949-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_0948-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_0958-1.jpg
Parts hanged up for spraying...
https://static1.pt-content.com/images/pt/2013/06/IMG_0960-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_0957-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_0967-1.jpg
Painted and ready for mounting...
https://static1.pt-content.com/images/pt/2013/06/IMG_0961-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_0962-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_0963-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_0966-1.jpg
ProSwede
06-24-2013, 10:10 AM
https://static1.pt-content.com/images/pt/2013/06/IMG_0968-1.jpg
Time for some fender repair....even that my car had lived all its life in California some rust was present in the lower fender area...
https://static1.pt-content.com/images/pt/2013/06/IMG_0979-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_0978-1.jpg
Some poor previous work unveiled when I tooh a clooser look...
https://static1.pt-content.com/images/pt/2013/06/IMG_0971-1.jpg
Choosed to temporaly remove the inner structure to have the fender properly repaired...
https://static1.pt-content.com/images/pt/2013/06/IMG_0972-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_0982-1.jpg
Not a pretty sight....
https://static1.pt-content.com/images/pt/2013/06/IMG_0981-1.jpg
These were sent away to the blaster before they were rewelded back in to position...
https://static1.pt-content.com/images/pt/2013/06/IMG_0973-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_1010-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_1002-1.jpg'
https://static1.pt-content.com/images/pt/2013/06/IMG_1000-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_0998-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_0999-1.jpg
https://static1.pt-content.com/images/pt/2013/06/IMG_1529-1.jpg
ProSwede
07-01-2013, 10:17 AM
Got some brake lines made....
https://static1.pt-content.com/images/pt/2013/07/IMG_1509-1.jpg
https://static1.pt-content.com/images/pt/2013/07/IMG_1514-1.jpg
https://static1.pt-content.com/images/pt/2013/07/IMG_1502-1.jpg
https://static1.pt-content.com/images/pt/2013/07/IMG_1501-1.jpg
https://static1.pt-content.com/images/pt/2013/07/IMG_1504-1.jpg
https://static1.pt-content.com/images/pt/2013/07/IMG_1506-1.jpg
https://static1.pt-content.com/images/pt/2013/07/IMG_1507-1.jpg
https://static1.pt-content.com/images/pt/2013/07/IMG_1510-1.jpg
ProSwede
07-01-2013, 10:18 AM
https://static1.pt-content.com/images/pt/2013/07/IMG_1503-1.jpg
https://static1.pt-content.com/images/pt/2013/07/IMG_1500-1.jpg
ProSwede
08-12-2013, 07:09 AM
Time for some updates.....
https://static1.pt-content.com/images/pt/2013/08/IMG_1527-1.jpg
Manage to get a wiper motor from a newer Camaro (Gen 4) to fit with some modifications....made a adapter plate to fit it to the firewall....
https://static1.pt-content.com/images/pt/2013/08/IMG_1519-1.jpg
Took it apart and modified the module to get rid of the hidden wiper feature....
https://static1.pt-content.com/images/pt/2013/08/IMG_1522-1.jpg
Cut this "cam" away...as you may have seen in an earlier post I have a steering column from same year camaro/transam that this wiper motor came from (93-02) so in my case this was the modification that had to be done to make it work....if you have any other type of wiper switch things may be different!
https://static1.pt-content.com/images/pt/2013/08/IMG_2034-1.jpg
New front spoiler mounted....
https://static1.pt-content.com/images/pt/2013/08/IMG_2032-1.jpg
Choosed to use the bars that attach to the spoiler...did make a small modification though....the outer bars now mounts to the subframe instead of the fenders...thats for two reasons...one, if you hit something with your spoiler hard you dont mess up the fenders...two, the outer bars isnt so visable as they are when mounted in the fenders....
https://static1.pt-content.com/images/pt/2013/08/IMG_2033-1.jpg
https://static1.pt-content.com/images/pt/2013/08/IMG_2051-1.jpg
Time for some lightning upgrade...found H4 lights with LED:s...I connected these as DRL lamps....good to always be visable...
https://static1.pt-content.com/images/pt/2013/08/IMG_2049-1.jpg
Also, I found some projector type of switchbacks for the parklight/blinkers....white when in parklight, amber when flashing...
https://static1.pt-content.com/images/pt/2013/08/IMG_2045-1.jpg
ProSwede
08-12-2013, 07:14 AM
https://static1.pt-content.com/images/pt/2013/08/IMG_2068-1.jpg
This is a pic with ONLY the LED:s lightened.....No H4!
ProSwede
08-12-2013, 07:17 AM
Had the car to the Exhaust shop to have a stainless system custombuilt to the car....very happy with the result!
https://static1.pt-content.com/images/pt/2013/08/IMG_2058-1.jpg
https://static1.pt-content.com/images/pt/2013/08/IMG_2059-1.jpg
https://static1.pt-content.com/images/pt/2013/08/IMG_2060-1.jpg
https://static1.pt-content.com/images/pt/2013/08/IMG_2062-1.jpg
https://static1.pt-content.com/images/pt/2013/08/IMG_2063-1.jpg
https://static1.pt-content.com/images/pt/2013/08/IMG_2064-1.jpg
https://static1.pt-content.com/images/pt/2013/08/IMG_2035-1.jpg
https://static1.pt-content.com/images/pt/2013/08/IMG_2036-1.jpg
https://static1.pt-content.com/images/pt/2013/08/IMG_2037-1.jpg
85coupe50
08-12-2013, 11:21 AM
Great upgrades...
cactuss4
08-12-2013, 02:08 PM
w00t, great build.. Can't wait for the vids of it running etc (you stated you have had it out on it's maiden voyage already, so more updates are forthcoming ya? :) Very well done!
I'm also interested in the lighting, do you have links or other information on who sells those fixtures?
Tory
ProSwede
08-15-2013, 09:55 AM
Tory
The 7" H4 I bought at www.tlg-auto.com and the switchback bulbs for park/blink I found on Ebay...just do search there and you should find them...
tmadden
08-17-2013, 03:55 AM
Sweet!! Love the exhaust work.
Nicke blom
11-09-2013, 05:53 AM
bra jobbat! Har du några Camarodelar ligger?
