View Full Version : Mast Motorsports builds Ultimate NA LS Pump Gas Street Motor (870hp/665tq)
MastMotorsports
10-19-2010, 03:07 PM
Mast Motorsports is pleased to share the dyno results of our RHS based 466 using a set of our PXR Canted Valve heads and Hilborn Individual Runner system. This was our first chance to dyno using our PXR Canted Valve Heads and we feel the results speak for themselves. The engine will find its home in a 56 Chevy and will utilize our new M-120 WBO2 ECM with Bank to Bank wideband closed loop control.
Published Engine Specs:
466 Cubic Inch, 4.300” Stroke 4.155” Bore
RHS Tall Deck Block
Callies Dragonslayer Crankshaft and H-Beam Rods
Mahle Custom Canted Valve Box in Box Pistons
Mast Motorsports PXR Canted Valve Heads
Hilborn Individual Runner Intake
Solid Roller 60mm Cam Core
Runs and Dyno tested on 93 Octane
870 Peak Horsepower at 7800 RPM using 93 Octane!
41519
Goto our Facebook (http://www.facebook.com/mastmotorsports) page to see the dyno pull!
67 ls1 vert
10-19-2010, 03:18 PM
wow, very big numbers. Huge RPM's! Good job guys.
Now build me one! :)
ProdigyCustoms
10-19-2010, 03:21 PM
Send me a quote for one
Rybar
10-19-2010, 03:33 PM
Badass, I want one too
Ron.in.SoCal
10-19-2010, 04:02 PM
Huge - HP and Tq cross over @ 5250 as usual, but HP peaks @ 7700 and Tq @ 6500. I'm a fan...!
James OLC
10-19-2010, 04:36 PM
I could use one of those too!
Great numbers
Very impressive
killer69
10-19-2010, 05:16 PM
James.............. we could ALL use one!! tell you what you buy 2 and l will gladly test one for you, you know just to make sure. lol
John McIntire
10-19-2010, 05:30 PM
WOW!!! Thats all I have to say about that!! Job well done!!
preston
10-20-2010, 11:34 AM
Can you tell us what the idle rpm and vacuum are ?
Steve1968LS2
10-20-2010, 05:14 PM
Sweet.. interesting to compare that to the 461 (4.155 bore x 4.250 stroke) LS engine I just did using your Black Label heads. We made about the same torque but you had an extra 120 hp due to being reved so high. I imagine this was due to the solid roller cam and increased air from the uber bitchen heads.
I would be interested in the cam specs.. also, if I sent you my dyno file could you overlay it.. would be an interesting comparison between a hyd and solid engine, assuming our cams aren't so far apart.
Must sound crazy good reving that high..
My graph
http://i52.tinypic.com/2l8izps.jpg
The WidowMaker
10-20-2010, 05:35 PM
looks good chris. whats up with the m-120? is this the replacement for the m-90?
btw, thanks for the answers to my fuel pump and pedal questions today.
Tim
rayy
10-20-2010, 06:52 PM
Great job! I wish I could have been there to see it.
Bowtie racing
10-21-2010, 01:17 AM
Awsome power..Used to be forced air numbers few years ago.
shortrack
10-21-2010, 03:05 PM
you dont need no stinking power adders........!
we need pichers......!!
68Formula
10-22-2010, 03:44 AM
The peak numbers are extremely impressive, but look at the torque curve as well.... 400ft-lbs from 2500rpm up! Pretty darn good for engine designed to spin that high.
Gandalf
10-27-2010, 07:40 AM
Exactly what I was thinking - crazy LS power!
fletcherscustoms
10-27-2010, 08:56 AM
WE want pics!!! And I sent a PM please send a quote to [email protected]
