View Full Version : Got Volvo?
Pages : 1 [2]
Poopy
12-04-2013, 09:26 AM
I just registered for this car. Poopy how is your car doing? Is the project still alive?
It is alive, sort of. It is currently sitting in my shop with the motor removed while I finish off the engine bay and get it painted. I just had an aluminum flywheel made for the new motor, so once painted it will all go in and get rewired and tuned with a new ECU. Then I will start picking away at the body work, I didn't have it on the road last summer and that was a let down for me. So this spring I hope to have it back together. ;)
Thanks for registering!
Mr.Markos
12-05-2013, 02:42 PM
I do have a couple of questions:
- Is it also possible to use an LS400 instead of the SC400? The wheelbase is slightly different (LS400: 2,814 mm (110.8 in) and the SC400: 105.9 in (2,690 mm)) And also the width is larger (LS400: 1,821–1,829 mm (71.7–72.0 in) and the SC400: 70.5 in (1,791 mm)) And afaik the engines aren't that different. I thought the SC400 has a dry-sump and the LS400 doesn't?
- How did you fix the shortening the drivetrain? Cause it is a RWD right? :)
- Why did you make a custom petrol tank? Did you have to remove the original one because you had to shorten the whole car? Or because regulations with track cars? In other words, can the original tank be used as well?
- Are the original seats of the SC400 useable in the volvo?
- Where are the chassis numbers of both cars located? This because I would like to have it roadlegal (in the Netherlands)
- Is it possible to get the wheels more inside the car by using other ET-values rims (I dont know if this is called the same way in English). When you use rims with the center placed more to the outside of the wheel so it will be placed further inside the car. Maybe with some re-welding of the inner fenders (I have no idea how to call this, I hope it is clear what I mean)
I actually have a lot more questions because I love the project. But I'll keep it with these for now ;)
Poopy
12-05-2013, 03:44 PM
I would not use the LS400 just because of the width, the SC400 was hard enough to make fit. They use totally different suspensions, the SC is the same platform as the last generation Supra, so there is actually a bit of aftermarket for it.
Yes RWD, and I just had the stock driveshaft shortened to match the amount I shortened the SC400 chassis.
The SC400 tank sits high up behind the rear seats, not a great place for center of gravity, as well, I wanted an SCCA approved fuel cell, but otherwise the stock tank might have fit, if it cleared the Volvo package tray area. I didn't try it, so I am not 100% sure.
The volvo has a small riveted tag under the hood, the lexus is on the door jamb and on the dash i believe. I wanted all trace of lexus gone, so it is registered as a volvo.
Yes a little bit, mine are ET35, so you could get a bit extra as long as the tire doesn't start contacting the suspension, or frame when turning.
Hope that helps!
One thing I would do different next time: Unbolt the front and rear suspensions from the lexus and just build a new frame, and put in all new sheet metal. Trying to join curvy lexus sheet metal to straight volvo bits was a tremendously frustrating task. It would have been faster to start from scratch with all flat steel.
Mangohick
09-03-2014, 06:10 AM
This makes me wish I'd kept my 122 :/
Streetrunner
12-15-2014, 07:18 PM
Love the build more pics updates !!!!
bpmack16
03-09-2015, 07:57 AM
More updates please.
jerome
03-09-2015, 09:48 AM
Got some paint on the engine finally. My first attempt at ppg envirobase, it was pretty damn easy to work with. Came out a bit more blue than I was hoping for, but it really changes with the light. ;)
Do you have any more info on the paint color? Really like the looks of it.
Poopy
04-11-2015, 05:11 AM
Sorry guys, this thing keeps getting delayed. I feel much guilt!
Paint color is Audi Nimbus Grey. ;)
Godbolt
04-11-2015, 05:22 PM
No guilt. I understand the limits of time and funds. Absolutely awesome build. True hot rod spirit poopy!
Would love to see it on the road beating up tossers in Porsches or Ferraris. Update when you can as I am sure I am not alone in following this.
Poopy
04-24-2015, 12:24 PM
Finally got the engine bay painted
https://static1.pt-content.com/images/pt/2015/04/DSC_0005_zpsbizttdfx-1.jpg (http://s212.photobucket.com/user/Poopy62/media/Volvo%20122s/DSC_0005_zpsbizttdfx.jpg.html)
New custom aluminum flywheel:
https://static1.pt-content.com/images/pt/2015/04/DSC_1332_zpssvpddhkj-1.jpg (http://s212.photobucket.com/user/Poopy62/media/Volvo%20122s/DSC_1332_zpssvpddhkj.jpg.html)
Engine and tranny mated:
https://static1.pt-content.com/images/pt/2015/04/DSC_0025_zpsfbejzwkr-1.jpg (http://s212.photobucket.com/user/Poopy62/media/Volvo%20122s/DSC_0025_zpsfbejzwkr.jpg.html)
YAY! motor installed:
https://static1.pt-content.com/images/pt/2015/04/DSC_0026_zps18vhoe8n-1.jpg (http://s212.photobucket.com/user/Poopy62/media/Volvo%20122s/DSC_0026_zps18vhoe8n.jpg.html)
https://static1.pt-content.com/images/pt/2015/04/DSC_0028_zpsk7hvpg4x-1.jpg (http://s212.photobucket.com/user/Poopy62/media/Volvo%20122s/DSC_0028_zpsk7hvpg4x.jpg.html)
https://static1.pt-content.com/images/pt/2015/04/DSC_0029_zpsbvgnzgrx-1.jpg (http://s212.photobucket.com/user/Poopy62/media/Volvo%20122s/DSC_0029_zpsbvgnzgrx.jpg.html)
chunger
04-24-2015, 02:19 PM
This engine seems to have 2 upper cooling hose outlets. It seems the Lexus uses an odd downflow radiator with two upper inlet, one of which goes straight into the upper tank, the other through an expansion tank first.
Any insight why Toyota would design this thing with the two outlets (it seems quite odd to me)?
What are you plans for cooling this beast?
Poopy
04-24-2015, 03:37 PM
I'm not sure what they had in mind, probably some intake warming emission type crap, the race truck this motor came out of had them all tied together with braided hoses. I already have a mishimoto radiator with dual fans and shroud that I ran with the original motor. It worked quite well. ;)
Poopy
05-09-2015, 04:20 AM
Picked up some new wheels today..
https://static1.pt-content.com/images/pt/2015/05/DSC02334_zpsryjam6te-1.jpg (http://s212.photobucket.com/user/Poopy62/media/Volvo%20122s/DSC02334_zpsryjam6te.jpg.html)
https://static1.pt-content.com/images/pt/2015/05/DSC02330_zps920qxtvq-1.jpg (http://s212.photobucket.com/user/Poopy62/media/Volvo%20122s/DSC02330_zps920qxtvq.jpg.html)
NickNitro
05-09-2015, 09:19 AM
Just read the whole thread, awesome build. The new wheels look great too. Really suit the look. Keep up the great work.
Nick
LERM
05-09-2015, 12:32 PM
Great car in general... but I really dig the "hidden" tube bumper idea. New wheels look great too. Somthing in the darker simpler wheels that looks more sinister...
Poopy
05-09-2015, 06:07 PM
Nick
Thanks Nick. ;)
Thanks for noticing! and ya I like the black wheels on this thing.
BenE64
05-10-2015, 04:18 PM
Really awesome project! Just read through the whole thread and it is a good bit of inspiration! It appears that while you are very good at the panel work you dont seem to enjoy it much,(just from some comments you've made) it is something I am not looking forward to, any tips you've learnt for a newbie to the cut and shut proffesion? I was wondering if you use different wire to do panel work to other structural work? Keep up the good work your on the down hill run now and im sure im not alone in looking forward to the updates! Thanks for sharing.
Poopy
05-11-2015, 06:54 AM
If I could do it over again, I would have bought a Tig welder to start with. I just bought one a few weeks ago and it sure works great on thin steel with little to no grinding when you're done. The non stop welding, grinding, warping, hammering, shrinking, welding, grinding, warping routine got old really fast. The tig would have forced me to do a bit better fitting, and would have saved me a hundred hours of messing around making a mess. The other tool I bought after the fact is an english wheel. In reality I should have shaped and tig'd the panel roughly into shape, cut the whole 1/4 panel off strategically, english wheeled it smooth and perfect, and tig'd it back on. Maybe next time! lol
As far as the mig wire, I tried 023 and 035, and really didn't have much preference between the two.
BigRedCamaro
05-11-2015, 08:35 AM
Just went through this thread (at a fast pace). So cool! Thanks for posting so many pictures. Like what you've accomplished. This obviously isn't your first rodeo. Can't wait to see more!
Poopy
05-11-2015, 11:44 AM
Thanks! I'm very motivated to get it completed now. ;)
andrewb70
05-11-2015, 12:05 PM
The Stance kids around the world will go nuts over this...
grendel
05-11-2015, 06:11 PM
Love it man, keep it going. May need to steal your flare idea.
Poopy
05-12-2015, 04:58 AM
Haha ya, but this car still has useable suspension travel, it was mostly lowered by dropping the body. :razz:
Thanks, ebay flares are awesome!
Godbolt
05-13-2015, 04:02 AM
That motor looks so good in there. Such a cool engine bay. Love the wheels too.
Godbolt
08-03-2015, 02:27 AM
Update?
Poopy
08-03-2015, 03:25 PM
Moving this weekend.... Holy crap it's a lot of work to move from 10 acres and 10 years. I'd like to get a shop up for winter and hide in the shop with the car all winter. ;)
Supra510
08-03-2015, 08:45 PM
Nice work
Godbolt
08-04-2015, 01:25 AM
Good luck with the move. Last time I did it I said the next move would be when they carried me out in a box.
Twentyover
08-04-2015, 08:37 AM
Me too.. two moves ago. Each time they carried me out- in a couple hundred cardboard boxes
Poopy
08-04-2015, 09:22 PM
Haha...this is a seriously daunting move...almost 4 hours away...lowbeds, shipping containers, excavator, bobcat...5 or 6 vehicles...plus a house, wife and 2 kids worth of stuff....good grief.
Ant
08-05-2015, 10:33 AM
that right there is something to be proud of, bad ass
DrFraZZy
08-10-2015, 08:15 AM
Pure badass! One of a kind!
Godbolt
10-31-2015, 05:51 PM
Hope the move went well. Any progress on the build? Mine has stalled for a while but hope to finish soon..... ish....
Godbolt
05-31-2016, 02:45 AM
Updates? Hope this is still progressing.
Flipper
12-30-2016, 08:13 PM
Just now found this...freakin' cool! What's the latest on this one?
