View Full Version : Show me your front/rear brake cooling ducts
Ripped
10-18-2010, 11:21 AM
Gonna be working on this soon. I have a decent idea, of what I want to do on the rear.
The front I see as more challenging.
If you've done brake ducting for your car, I'd like to see your pics
ProBell
10-18-2010, 12:02 PM
I was able to run the air into and out of the frame to give me the clearance needed. Then used a standard style hat to push the air into the rotor. Randy
silver69camaro
10-18-2010, 12:19 PM
I know you didn't ask for this but (maybe for others to read), I'd only look at adding ducting if you find you have an excessive heat problem to start with. Most of the cars built here with large rotors rarely get into higher temps, making ducting a bad thing.
More along the lines of your question, I've seen a couple Porsche GT3 cars that have a plastic scoop attached to the LCA which ducts it into the rotor's general area. I'd look into something like that, much easier than a hose.
Ripped
10-18-2010, 01:30 PM
Thanks, great pics, and nice idea about the frame. My frame, I cannot cut like that, though. Still good ideas there
Yeah, that's kind of what I was thinking, as the routing of a duct hose, in my car -through the A frame, and under the front apron, might end up being more restrictive, than something , such as you're suggesting.
