Results 1 to 13 of 13
Thread: AFCO and DSE vs Hotchkis TVS
05-24-2005 #1
Starting The Transformation
- Join Date
- Dec 2004
- Location
- Greeley, Colorado
- Posts
- 485
I need to start picking out suspension components for my Firebird. I'd really like to get this right the first time. The car will be primarily a street car but it will see some open road style events and a few auto-x's here and there.
The car is pretty nose heavy. It has a pontiac 455 with iron heads and aluminum intake up front. Later on down the road and intercooler, turbo and piping will also be added. battery will at that point be moved tot he trunk.
Would you go with:
a) Hotchkis TVS with QA-1's
b) AFCO 700 or 750 lb springs, DSE rear leafs with QA-1's (stock front sway bar, no rear bar)
If you were to choose (b) would you go with the 2" or 3" rear leafs, and 700 or 750 lb front springs? How much springs would need to be cut up front?
I plan on doing slide-a-link in the rear as well. Any information and suggestions would be most helpful. Thanks in advance.
Jason Mounce
1969 Firebird | 2008 Corvette Z06 | 2008 Mustang GT/CS
05-24-2005 #2
- Join Date
- Jan 2005
- Posts
- 160
I can't help you with spring rates (I'm more of an A-body guy) but I could take some guesses if you can give more specs on the car (weight, and other things).
In any case, I'd recommend going with the AFCO's and some hidden weight jacks. Look up Dennis68's website if you want to see how they work. This will give you an in on cheaper springs and let you set your ride height any way you want without having to cut coils.
Here's a catalog link for the adjusters: http://www.speedwaymotors.com/xq/asp...qx/product.htm
As for shocks, I prefer bilstiens for a general, good quality shock. adjustables are over rated since you don't need to change them once you have them set (unless you run different tracks or something like that).
Sorry, can't help you on the rear except that AFCO makes leaf springs too (no recommendations though).
Wally
05-24-2005 #3dennis68 GuestI'll second the Bilsteins.
The AFCO hidden adjusters can be seen in the suspension page of my site (link below). You shouldn't need to cut any spring at all, that is what the adjusters are for. 750 might be a little stiff for an "F" body. I think Carl runs 650's and his Camaro sees much track time.
05-24-2005 #4
