DButler
10-15-2010, 07:52 AM
I am running twin 57mm turbos on a 355 sbc. I am running a blow thru carb setup. My fuel system consisst of a bg400 fuel pump, aeromotive boost referenced regulator. I am sunning -10 lines to the front and returning with the same. I sumped my oringinal tank and returning to the top. The carb was done by the carb shop, it has boost referneced power valves, annular boosters and all the mods to make it work. My question is concerning the pump. I dont seem to like the gb pump. I can't get it over 15psi and it is rated for up to 30 psi. I need to get this up because I wanna run 10psi of boost. I know the a1000 pump is probably the way to go, but I have seen somethings on some external bosch pumps that are good or maybe a walbro or weldon. Any recommendations, would like to cut back on pump noise as much as possible and something that will be good for street use. I should have bout 550 rwp. Any help is greatly appreciated. Thanks
