View Full Version : alternator hook up
67 ls1 vert
10-10-2010, 07:53 AM
I changed plans with the top the my engine and went with an intake and carb set up. Now I am using an MSD box to control my coil packs, crank, and cam sensor. My question is what do I use to make the alternator work since I'm not using the stock style harness? Frank told me a while back but I don't remember what alternator he said to use. Something with a single wire hook up I would think?
Also, if anyone has a bracket for the alternator (f-body) style, and a belt tensioner let me know.
Thanks. :cheers:
H2Ogbodies
10-12-2010, 05:18 PM
What year alt bracket are you needing? If you are using an LS harness, the corresponding alt. has a charge lead and an ignition lead I believe.
