View Full Version : 69 camaro called wicked impression
robertjra
10-05-2010, 02:32 PM
https://static1.pt-content.com/images/noimg.gif (http://www.facebook.com/photo.php?pid=178499&id=100000255100572)This is how I found the car 6k and drove it home nasty cat and all jk
https://static1.pt-content.com/images/noimg.gif (http://www.facebook.com/photo.php?pid=178499&id=100000255100572)After a little black paint and some old wheels just so I could drive it around before the resto.
5:00 am start of the tare down and a drag honda crv swap
https://static1.pt-content.com/images/noimg.gif (http://www.facebook.com/photo.php?pid=178499&id=100000255100572)All as one pice front end motor trans everything even the hood!
Front end off and all striped off time to strip trim and glass
Good thing I had that fork lift harder than it looks
All my new parts from bel air bobs grate guy and varry good parts shipped fast and fit was grate
front end suspenstion upper lowers subframe sway bar soon to come air lift slam air air shocks!
Sand blasted just a little to see what we have to work with and it looks good
Striped down and cut up
This is why you take it down all the way not bad rust but bad enuf
Sun roof lol
That’s better no more rust and the inner and outter fenders are off to make room for the dse mini tub kit
And thare it is lots of room for tires
Pic of the frame cut out and plate
Just a look at the in side lots of sand and dust
All new looks grate
Like I told you the fit is grate bell air bobs grate price and customer service
Next is to get it rolling!!! Will keep you posted I have more pics if you have any ?
robertjra
10-05-2010, 02:41 PM
tell me what you think!!!!!!!
Looks good to me. Sorry you had to tear it so far apart but this way you know it'll be rust free and worth your money and efforts in the long run. Good luck.
PhillipM
10-05-2010, 02:51 PM
Wow! That was a lot of work.
Nessumsar
Holy smokes! Are you replacing the front body panels as well?
What do you have planned for the drivetrain?
robertjra
10-05-2010, 02:59 PM
yes all the front end is new the frame is still in the works i have to cut and make room for the air bags and thin powder coat it
i have a 2010 2ss salvae in the works for 8k hope all works out so i will have the ls3 and the six speed would like to twin turbo it long way to go
robertjra
10-05-2010, 03:11 PM
lots of work yes pice of mind yes has any one done a after market dash
cheapthrillz
10-06-2010, 05:38 AM
Looks GRATE!
94SNGLTURBO
10-07-2010, 08:19 AM
very nice
robertjra
11-01-2010, 08:54 PM
new air shocks are in and thay look grate will fab the frame on my day off if any one has done this on a stock frame i would like some imput thanks
here is some pic the best i can do for now
http://www.facebook.com/photo.php?pid=470356&id=100000255100572
Ron.in.SoCal
11-02-2010, 08:23 AM
Looks GRATE!
I see where you got your handle...:)
robertjra
11-04-2010, 08:20 AM
so its time to start cutting up my stock sub frame has any one done this to make room for air bags or air struts? also has anyone cut the frame for tire clearance?
robertjra
11-10-2010, 09:45 PM
ok its all cut up!!!!! check out the pics
https://static1.pt-content.com/images/pt/2010/11/airshock3-1.jpg
https://static1.pt-content.com/images/pt/2010/11/airshock2-1.jpg
https://static1.pt-content.com/images/pt/2010/11/airshock-1.jpg
https://static1.pt-content.com/images/pt/2010/11/148831_169174116434424_100000255100572_4-1.jpg
https://static1.pt-content.com/images/pt/2010/11/76119_169174439767725_100000255100572_48-1.jpg
https://static1.pt-content.com/images/pt/2010/11/148474_169173989767770_100000255100572_4-1.jpg
https://static1.pt-content.com/images/pt/2010/11/76136_169172643101238_100000255100572_48-1.jpg
https://static1.pt-content.com/images/pt/2010/11/77160_169172513101251_100000255100572_48-1.jpg
https://static1.pt-content.com/images/pt/2010/11/148724_169172206434615_100000255100572_4-1.jpg
https://static1.pt-content.com/images/pt/2010/11/148495_169172239767945_100000255100572_4-1.jpg
https://static1.pt-content.com/images/pt/2010/11/76706_169171883101314_100000255100572_48-1.jpg
https://static1.pt-content.com/images/pt/2010/11/76111_169171753101327_100000255100572_48-1.jpg
https://static1.pt-content.com/images/pt/2010/11/76022_169172099767959_100000255100572_48-1.jpg
now just have to make new upper shock mount brackets
BritishGreen68
11-10-2010, 10:35 PM
Why did you cut off the old shock mounts? Nice to see another Camaro on airbags around here!
robertjra
11-10-2010, 10:39 PM
i didnt trust them and i got a shock with more travle so i wanted to relocate the upper mount and make it stronger this way i can drive at full hight and lay it on the frame
robertjra
11-11-2010, 02:32 PM
i got my new steel to make the upper shock mount. will weld this up on my next day off keep you all posted
https://static1.pt-content.com/images/pt/2010/11/74051_169171949767974_100000255100572_48-1.jpg
https://static1.pt-content.com/images/pt/2010/11/73542_169172699767899_100000255100572_48-1.jpg
robertjra
11-14-2010, 04:38 PM
i started to mock up the upper shock mounts coming along nicely its a lot of work but it will be varry strong when its all done
https://static1.pt-content.com/images/pt/2010/11/74271_170177479667421_100000255100572_49-1.jpg
https://static1.pt-content.com/images/pt/2010/11/149875_170177826334053_100000255100572_4-1.jpg
https://static1.pt-content.com/images/pt/2010/11/75684_170178006334035_100000255100572_49-1.jpg
https://static1.pt-content.com/images/pt/2010/11/73197_170177329667436_100000255100572_49-1.jpg
67goatman455
11-16-2010, 07:45 PM
:scared:
robertjra
11-16-2010, 09:16 PM
I know it looks like a hack job right now but it is still in mock up. I will clean and grind all the pices off when I take it back apart when I'm done it will look pro.
67goatman455
11-18-2010, 04:22 PM
are you using an arc welder?
robertjra
11-18-2010, 06:08 PM
No its a old wire feed with no gass or flux core the welds are only to hold it in place I will take it to the local shop to have it all done the wright way
robertjra
11-19-2010, 08:29 PM
Has anyone done this on there frame I would love to see how you did yours
robertjra
11-25-2010, 04:16 PM
Still working on the frame getting it ready for the powder coat has anyone put the frame on the body with out any bushings and if you did tell me everything.
ponjohn
11-30-2010, 06:04 PM
When you remove all the sheet metal like you did, what do you use for a reference?
I assume the panels just don't fall into place, where do you take measurements from to make sure it is square?
Thanks for the info.
robertjra
11-30-2010, 09:11 PM
you have to bace it all up before you take any thing off on the inside of the car when its time to put it all back on every thing just gets clamped into place loose and all the gaps are cheked before anything is welded you have to put the doors on and the trunk everything has to be inplace
ponjohn
12-01-2010, 03:55 PM
So you actually welded some angle iron or the like to maintain the "shape" and use for reference?
robertjra
12-01-2010, 06:42 PM
ya its more of a brace but the inner structure is very strong but the main thing is to put all the body panels on without welding and fit it all so you can tweak things and move stuff around. the pic's i have don't show the brace that good but if you go to some of the other builds on this site you can see it better.
Swainbuilt
12-02-2010, 02:10 PM
Your sure not afraid to cut things up :)
twosaturns
12-02-2010, 03:52 PM
Looks GRATE! lolz...
robertjra
12-02-2010, 06:29 PM
nop not at all I'll cut any thing!!!!
robertjra
12-14-2010, 09:49 PM
lots of work planed for this thing soon i will keep all of you posted
robertjra
01-21-2011, 09:39 PM
it's bin a little while since i have posted any thing on my post still working on my frame going to notch out the frame to make room for 10" wide wheels i was thinking of running 12" wheels in the front with 335 just like big red have any of you done this or seen any one do this keep checking out my post i will have a ls7 by the end of march and my M9 rear end with the torque arm i cant wait in coming out of my skin i get a bonus from work on the 15Th of march and its on!!! my car will be a roller by June!!!!!! i know how we all like pic's so i will put one of the rear end i will be using.
https://static1.pt-content.com/images/pt/2011/01/file_12_21-1.jpg
robertjra
03-23-2011, 10:12 PM
ok droped some $$$ got a l92 from travis and a 6 speed will ship tomarow also got my 1/2 hight bushings for my frame and ls to stock frame mounts my frame is all welded up and ready for powder coat i will put up some pics tomarow or something as soon as i can
robertjra
03-25-2011, 08:00 PM
ok got some new parts travis sent out my l92 today yay hope to see it in 4-5 days so for now got some new pics oil pan, 1/2 hight bushings, and ls mounts.
https://static1.pt-content.com/images/pt/2011/03/200462_203721386313030_100000255100572_7-1.jpg
https://static1.pt-content.com/images/pt/2011/03/198976_203721226313046_100000255100572_7-1.jpg
https://static1.pt-content.com/images/pt/2011/03/195975_203721489646353_100000255100572_7-1.jpg
https://static1.pt-content.com/images/pt/2011/03/189919_203721322979703_100000255100572_7-1.jpg
robertjra
04-06-2011, 09:06 PM
So my l92 and 6l80e had a crack so travis is sending me out a diferent one hope it comes soon!
robertjra
04-14-2011, 08:55 PM
I would like to put up some new pics of my l92 and 6l80e but I still don't have them yet looks like this mon befor they ship out
Motown 454
04-15-2011, 10:26 AM
It looks great nice work.
gcallahan
04-15-2011, 05:22 PM
nice, what pan is that? doing a Lq9 in my 69, looking for a pan.
robertjra
04-17-2011, 08:29 PM
Its the gm pan for older hot rods I will see if I can find the prt #
ModedCB2
04-18-2011, 07:09 AM
I commend you on your guts to dive in. Looks like you've got a handle on the mechanical side of things....
Sorry.... in advance... sorry.... but it GRATES (as in to chew/knaw/grind into bits) on me when you don't use the GREAT feature called SPELL CHECK... a random forgotten letter or misspelling... that's cool, we all get excited.
Please, if this thread grows the way I really hope it does & we can all see the GREAT results... use the spell check on your posts...
robertjra
05-01-2011, 07:54 PM
thanks on the spell check i cant spell to save my life but.... i can turn a wrench.
robertjra
05-01-2011, 08:12 PM
OK did some work in the past week its bin a long time since some pics so i have some for all of you first i have some of my frame with most of the welding done
https://static1.pt-content.com/images/pt/2011/05/229123_212905945394574_100000255100572_8-1.jpg
https://static1.pt-content.com/images/pt/2011/05/230561_212905978727904_100000255100572_8-1.jpg
next was the cut out for room for bigger tires up front
https://static1.pt-content.com/images/pt/2011/05/230346_212905895394579_100000255100572_8-1.jpg
and my l92 i have it up in the air to change out the oil pan to fit the frame
https://static1.pt-content.com/images/pt/2011/05/223585_212906498727852_100000255100572_8-1.jpg
check out the old pan next to the new pan
https://static1.pt-content.com/images/pt/2011/05/228173_212906228727879_100000255100572_8-1.jpg
https://static1.pt-content.com/images/pt/2011/05/226591_212906858727816_100000255100572_8-1.jpg
and my 6 speed trans thanks Travis you helped me out in a big way all of you reading this Travis is a good guy
https://static1.pt-content.com/images/pt/2011/05/226835_212906712061164_100000255100572_8-1.jpg
daytonayellaz
05-03-2011, 03:45 AM
Your not drafting legal documents here..... your having fun doing what you love! Building a awesome car. Dont worry about it bro, the important thing is to have fun! Thats what this is all about. Looking really good to by the way!
robertjra
05-03-2011, 07:58 PM
Thanks travis one steep closer thanks to you!
robertjra
05-07-2011, 09:30 PM
Summit is shiping out my mounts hope to have them by my next day off!
robertjra
05-17-2011, 07:52 PM
well got the l92 into the frame!! but i need to move the mounts to see if i can make it work a little better and i have a pic for all of you
https://static1.pt-content.com/images/pt/2011/05/227507_216377258380776_100000255100572_8-1.jpg
daytonayellaz
05-17-2011, 10:05 PM
Glad to help Robert.... That L92 was one of my nicer ones to come through here, and looks right at home in the 69. Nice to see your making progress on the ride! Keep up the good work and keep us posted.
19,69camaro
05-17-2011, 10:57 PM
Wow I would sure like to get one of those engines. cough cough travis clear your pms
daytonayellaz
05-17-2011, 11:10 PM
LOL! OK..OK I cleared some of them out:cheers:
robertjra
05-18-2011, 07:10 PM
if i ever do a corvair for my wife i will use travis for shure prob not an l92 but an ls1 or ls2 would be just fine!
daytonayellaz
05-18-2011, 07:18 PM
Thanks Robert! I would be happy to help you out again! You were great to deal with and I made a new friend :)
robertjra
05-18-2011, 07:28 PM
you bet im still getting the mast cam and tune from you!!
daytonayellaz
05-18-2011, 07:35 PM
When your ready bro! I have sold a lot of Mast parts since becoming a Mast Dealer. Its been great to be able to offer this service with the engines. Your getting closer!
randywyatt2000
05-18-2011, 08:00 PM
looking good so far
robertjra
05-18-2011, 08:17 PM
looking good so far
thanks all the nice words from everyone makes it EZ to keep me motivated to stay working on my dream car i will be doing a lot this weekend
i.e bolting the frame to the body and cutting out the trans tunnel to make room for the 6l90e also more front sub frame work!!
Gandalf
05-18-2011, 09:22 PM
Great build man - keep it comin'! Looking good.
robertjra
05-29-2011, 07:59 PM
OK i did lots of work today so check it out the first thing i did was install the new mounts on my l92 and it was perfect! fits nice and snug and as always i have some pics!!
https://static1.pt-content.com/images/pt/2011/05/254269_219848481366987_100000255100572_8-1.jpg
https://static1.pt-content.com/images/pt/2011/05/254899_219848894700279_100000255100572_8-1.jpg
the next thing was to bolt up the sub frame to the body lol ya that's all just bolt it up! from what i found no one else has installed a 6l90e into a 1969 camaro and this trans is huge!!!! so a little mock up and well if you know me its time to cut something!
https://static1.pt-content.com/images/pt/2011/05/247628_219849611366874_100000255100572_8-1.jpg
https://static1.pt-content.com/images/pt/2011/05/247750_219849444700224_100000255100572_8-1.jpg
not even close to fitting no guts no glory.
https://static1.pt-content.com/images/pt/2011/05/250230_219849968033505_100000255100572_8-1.jpg
https://static1.pt-content.com/images/pt/2011/05/251459_219850171366818_100000255100572_8-1.jpg
https://static1.pt-content.com/images/pt/2011/05/253788_219850038033498_100000255100572_8-1.jpg
well we have room to fit the 6 speed in now all i have to do is bolt in the frame!!
https://static1.pt-content.com/images/pt/2011/05/248731_219850344700134_100000255100572_8-1.jpg
and this is just so i can move the car around a little better i will be installing the torque arm and the m9 rear end in the next 6 months or so have to save up a little more
https://static1.pt-content.com/images/pt/2011/05/246609_219850831366752_100000255100572_8-1.jpg
now she is sitting on all 4 tires and dang the front end is low with no air in the bags
https://static1.pt-content.com/images/pt/2011/05/253679_219851101366725_100000255100572_8-1.jpg
https://static1.pt-content.com/images/pt/2011/05/253937_219851128033389_100000255100572_8-1.jpg
so with no air in the bags the lowest point is 1 and 1/2" and its the oil pan i think a skid plate will have to be made!
https://static1.pt-content.com/images/pt/2011/05/250692_219851591366676_100000255100572_8-1.jpg
https://static1.pt-content.com/images/pt/2011/05/249268_219851731366662_100000255100572_8-1.jpg
that's all for today hope you all like it and if any of you have some suggestions or comments let me know i love hearing input from all of you!!!!
Ron.in.SoCal
05-29-2011, 10:47 PM
Robert...oil pan sits a skutch low, IMHO. Is that the L92 pan?
robertjra
05-29-2011, 11:14 PM
no its the hot rod pan from gm performance but the bags are all the way flat when i air it up to ride height i will have over 4" of clearance
robertjra
05-30-2011, 10:05 AM
Has any one used a universal transmission tunnel kit? i don't have a bead roller or a brake to bent sheet metal, i could cut and price it together but i want a one pice tunnel.
Greasy63
05-30-2011, 12:51 PM
no i havent but NICE work!
nice car!
GL w/the rest of ur build
robertjra
05-30-2011, 04:34 PM
Thanks it is taking forever to build but I will be doing more work to the frame soon
robertjra
06-01-2011, 09:51 PM
Looking for a little help from all of you. If you have seen my build thin you know I'm trying to do all of this on my own and that I'm till in the mock up stage, oh ya and I have a budget, I think my next step should be the rear end and the torqe arm from speed tec? What do all of you think? Thank for all of your imput! Just want to see what all of you would do if it was your car
daytonayellaz
06-02-2011, 04:39 AM
Robert.. Can you post a pic of the stock tunnel you cut out sitting over the trans so we can see how far off it is?? Im wondering if you can do a little hammering and add back a little sheet metal where needed and use the stock tunnel?
John Wright
06-02-2011, 04:43 AM
Robert.. Can you post a pic of the stock tunnel you cut out sitting over the trans so we can see how far off it is?? Im wondering if you can do a little hammering and add back a little sheet metal where needed and use the stock tunnel?Like he said...can you sit the stock tunnel over it and add a strip of sheet metal along each side to get the height you need to clear? If it isn't wide enough...split it down the middle and add a strip there to widen it.
robertjra
06-02-2011, 09:50 AM
My next day off I will do that most of the fitment prob is at the bellhousing cus of the 1" back kit I think I will need a new trans fill tube also
robertjra
06-02-2011, 08:37 PM
your 69 looks very good i keep checking on your build all the time!!!!
robertjra
06-05-2011, 02:32 PM
mock up on the trans tunnel looks like i will need 1 1/2" of steel to fill in what do all of you think if i use some thicker steel from the fire wall all the way down to the cross member to tie the body in a little tighter? hope you all are still fallowing me but the cross member i want to use is the one that DSE built and cuts into the floor like this pic
https://static1.pt-content.com/images/pt/2011/06/DSE011201_detail1-1.jpg
i think this will make the body stronger and help with flex also i have to make my own cross member any way so... oh ya i have a pic of the tunnel with the cut out piece on top of the trans i used some 3/4" wood blocks on top of the trans to get room for servicing and adjustment of angles cables wiring etc....... this is what the gap looks like.
https://static1.pt-content.com/images/pt/2011/06/253777_221560931195742_100000255100572_8-1.jpg
by the way i don't care how much the car weighs i will not be racing it all the time, prob just some road race and daily driving and some auto cross just for fun oh ya and all burn outs i can get away with. lol
robertjra
06-06-2011, 08:51 PM
so i orderd the lokar 6l80e trans midnight fill tube so i can keep moving on, cant wait to build my trans cross member!!!!!!!!
robertjra
06-09-2011, 02:57 PM
look what i have !!!!! 2x3" steel tube and 1x3/4" steel time to make a cross member every thing cost me $30.00
https://static1.pt-content.com/images/pt/2011/06/248483_222578014427367_100000255100572_8-1.jpg
robertjra
06-09-2011, 07:20 PM
well I'm done for the day played around with the steel and this is what i came up with keep in mind I'm not done yet so what do you think?
start found the center line of the steel
https://static1.pt-content.com/images/pt/2011/06/248306_222608007757701_100000255100572_8-1.jpg
cut outs so i can bend the tubing
https://static1.pt-content.com/images/pt/2011/06/252580_222608181091017_100000255100572_8-1.jpg
https://static1.pt-content.com/images/pt/2011/06/254380_222608191091016_100000255100572_8-1.jpg
all my cut outs made now on to the test fit
https://static1.pt-content.com/images/pt/2011/06/246910_222608394424329_100000255100572_8-1.jpg
https://static1.pt-content.com/images/pt/2011/06/248630_222608331091002_100000255100572_8-1.jpg
i welded every thing all up, but the floor piece
https://static1.pt-content.com/images/pt/2011/06/250107_222608494424319_100000255100572_8-1.jpg
this is just sitting in the car i will have to cut the floor piece to fit it all in
https://static1.pt-content.com/images/pt/2011/06/254812_222616121090223_100000255100572_8-1.jpg
https://static1.pt-content.com/images/pt/2011/06/249882_222616101090225_100000255100572_8-1.jpg
robertjra
06-10-2011, 09:35 AM
I will have more updates on sun. I will cut into the floor and weld everything up
FRENCHBLUE72
06-11-2011, 07:16 AM
Tuning in to see what happens next...
robertjra
06-11-2011, 10:19 AM
Just good stuff trying to as much by my self as I can I will post more tomarow I'm on lunch brake
robertjra
06-12-2011, 07:01 PM
did some more work too day cut out the floor and fited the cross member i ran out of wire for the welder so this is as far as i got hope you like it!
cleand up allmy welds
https://static1.pt-content.com/images/pt/2011/06/248474_223355687682933_100000255100572_8-1.jpg
all fitted in the car
https://static1.pt-content.com/images/pt/2011/06/254910_223355924349576_100000255100572_8-1.jpg
https://static1.pt-content.com/images/pt/2011/06/251773_223355801016255_100000255100572_8-1.jpg
https://static1.pt-content.com/images/pt/2011/06/260467_223355757682926_100000255100572_8-1.jpg
robertjra
06-21-2011, 07:34 PM
time to update my thread most of my cross member is done check it out
https://static1.pt-content.com/images/pt/2011/06/253570_225286097489892_100000255100572_9-1.jpg
https://static1.pt-content.com/images/pt/2011/06/263615_225275474157621_100000255100572_9-1.jpg
https://static1.pt-content.com/images/pt/2011/06/254876_225559340795901_100000255100572_9-1.jpg
https://static1.pt-content.com/images/pt/2011/06/269940_225816140770221_100000255100572_9-1.jpg
https://static1.pt-content.com/images/pt/2011/06/259977_225815964103572_100000255100572_9-1.jpg
https://static1.pt-content.com/images/pt/2011/06/267279_225815734103595_100000255100572_9-1.jpg
robertjra
06-22-2011, 07:58 PM
so I ran out of wire for my welder but i got far enuf to fit every thing is and drop the trans down into place check it out!!
https://static1.pt-content.com/images/pt/2011/06/264504_233505903334578_100000255100572_9-1.jpg
https://static1.pt-content.com/images/pt/2011/06/269409_233541526664349_100000255100572_9-1.jpg
robertjra
07-10-2011, 06:18 PM
Well I didc a little more work today I welded in the cross member and cleaned the floor with a wire wheel for like 4 hr I put a coat of the anti rust paint down from the cross member back I will post more pic's soon I still have to replace the left front floor pan and finsh the tunle work I will keep you all posted
robertjra
07-21-2011, 06:30 PM
I cut out the floor pan and fixed some rust in the firewall
https://static1.pt-content.com/images/pt/2011/07/284266_246264135392088_100000255100572_9-1.jpg
got the new pan to fit nice and tight still a bit more to do and one more piece to make and all my rust will be all gone!!!!!!!!
https://static1.pt-content.com/images/pt/2011/07/285360_246264522058716_100000255100572_9-1.jpg
started the trans tunnel fab work this will take some time. I get one day a week to work on my car and all I want is for it to be done.
https://static1.pt-content.com/images/pt/2011/07/282088_246268792058289_100000255100572_9-1.jpg
RicerwannaB
07-21-2011, 10:10 PM
That looks intense
robertjra
07-22-2011, 05:26 AM
Not all that bad just keep going!!!
daytonayellaz
07-25-2011, 09:57 PM
Your moving along really good for only having one day a week to work on it. Keep after it Robert!:cheers:
robertjra
07-26-2011, 10:05 AM
Thanks travis this Thursday I should have the tunnle all done thin its off to the firewall smoothing
John Wright
07-26-2011, 10:57 AM
Keep after it, you'll get it.
robertjra
07-26-2011, 07:55 PM
thanks i will keep on it!! don't look at my welds too close i just saw your occupation
robertjra
07-28-2011, 08:23 PM
well did a lot more work on the car to day lots of welding and welding oh ya i did more welding all my floors are in and welding is done on them my trans tunnel is all fabed up. now I have to pull the frame off the car and weld up all the seams under the car. I will put up some more pics soon thanks for looking. I'm always up for new ideas so if you have any let me know!
Dobster
07-29-2011, 06:25 AM
Nice work... It will be plenty strong..
robertjra
08-03-2011, 07:48 PM
MY FLOOR IS DONE!!!!!!! AND MY TRANS TUNNLE TOO!!!!!!
https://static1.pt-content.com/images/pt/2011/08/251478_252559598095875_100000255100572_9-1.jpg
https://static1.pt-content.com/images/pt/2011/08/283903_252559058095929_100000255100572_9-1.jpg
https://static1.pt-content.com/images/pt/2011/08/284338_252558351429333_100000255100572_9-1.jpg
https://static1.pt-content.com/images/pt/2011/08/267361_252559204762581_100000255100572_9-1.jpg
https://static1.pt-content.com/images/pt/2011/08/252186_252558498095985_100000255100572_9-1.jpg
https://static1.pt-content.com/images/pt/2011/08/228935_252558991429269_100000255100572_9-1.jpg
https://static1.pt-content.com/images/pt/2011/08/226170_252558111429357_100000255100572_9-1.jpg
https://static1.pt-content.com/images/pt/2011/08/284685_252558194762682_100000255100572_9-1.jpg
robertjra
09-25-2011, 06:12 PM
one more step closer!!!
https://static1.pt-content.com/images/pt/2011/09/311696_278863788798789_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2011/09/294095_278863135465521_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2011/09/166960_278860972132404_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2011/09/321661_278863052132196_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2011/09/307212_278860228799145_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2011/09/297622_278860395465795_100000255100572_1-1.jpg
Bryce
09-25-2011, 06:50 PM
nice progress!
robertjra
09-25-2011, 07:17 PM
thanks!! i need more time off to get more done
robertjra
10-06-2011, 03:51 PM
more work done time to put the frame back on and do the rear
https://static1.pt-content.com/images/pt/2011/10/308679_283894558295712_100000255100572_1-1.jpg
FRENCHBLUE72
10-07-2011, 07:44 AM
Looks like the floors are solid agian..
robertjra
10-07-2011, 07:55 PM
ya, floors are all done next year in march i will have it running and driving. oh ya and stoping if all goes as planed
LeighP
10-08-2011, 04:00 AM
Looks good and solid.....nice and tough!
robertjra
10-08-2011, 07:22 PM
thanks I think that I will start to smooth the firewall tomarow
robertjra
10-12-2011, 08:18 PM
well the DSE plate is in one million tack welds later and a flap disk this is what i have.........................
https://static1.pt-content.com/images/pt/2011/10/298029_286787174673117_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2011/10/297069_286787574673077_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2011/10/300152_286787644673070_100000255100572_1-1.jpg
robertjra
10-23-2011, 07:32 PM
well have some free time and i was looking at a wiper relocation so i jumped in and started cutting stuff up so check it out the wiper will go under the drivers side fender
https://static1.pt-content.com/images/pt/2011/10/298348_292201647465003_100000255100572_1-1.jpg
now I cut out a plate and welded it in
https://static1.pt-content.com/images/pt/2011/10/296644_292202067464961_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2011/10/299910_292202720798229_100000255100572_1-1.jpg
I used a filler called metal to metal and it is some tuff stuff!!!!
https://static1.pt-content.com/images/pt/2011/10/304088_292202870798214_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2011/10/317722_292203114131523_100000255100572_1-1.jpg
robertjra
10-30-2011, 07:53 PM
After all the filler was sanded down I put down a layer of primer down to used as a guide for my bondo this way I know how far to sand with out going all the way down to the metal
https://static1.pt-content.com/images/pt/2011/10/308604_295526810465820_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2011/10/310500_295526643799170_100000255100572_1-1.jpg
After my layer of primer is the bondo keep in mind this is not my strong suit so any of you out there that would like to give me a little advice im wide open thank you!!!!!
https://static1.pt-content.com/images/pt/2011/10/377015_295526253799209_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2011/10/392613_295526453799189_100000255100572_1-1.jpg
robertjra
11-07-2011, 07:57 PM
well its all smoothed and the frame is back on im not happy with the way it came out so my plan is to get the rear suspension in the car (when Hotchkis has the 3 link ready to go hope by Feb-march!!!) thin get the car running and drive it for 6 months or so to get all the bugs out, and after that do a full plate of steel!!
https://static1.pt-content.com/images/pt/2011/11/316126_299313943420440_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2011/11/383984_299313833420451_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2011/11/375692_299314036753764_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2011/11/302434_299314130087088_100000255100572_1-1.jpg
robertjra
01-03-2012, 06:42 PM
well look what i got in the mail to day!!!!!!
https://static1.pt-content.com/images/pt/2012/01/381347_334554746563026_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2012/01/395389_334554946563006_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2012/01/386435_334555629896271_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2012/01/386129_334555326562968_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2012/01/386192_334557539896080_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2012/01/396970_334557346562766_100000255100572_1-1.jpg
looks like i will be doing more work on the car this weekend!!!!
robertjra
01-08-2012, 04:43 PM
did a lot of work on the Caro today got my air ride in the front end and the drop spindles with the big bite rotors installed to do a little more mock up and get some height numbers to see how my ride height will come out so i have some pics tell me what you all think
drop spindles installed
https://static1.pt-content.com/images/pt/2012/01/399949_337188952966272_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2012/01/403745_337189326299568_100000255100572_1-1.jpg
rotor installed
https://static1.pt-content.com/images/pt/2012/01/393607_337189719632862_100000255100572_1-1.jpg
car on ground with no air
https://static1.pt-content.com/images/pt/2012/01/407186_337798036238697_100000255100572_1-1.jpg
car with full air
https://static1.pt-content.com/images/pt/2012/01/400186_337797806238720_100000255100572_1-1.jpg
some more of the pics air and no air
https://static1.pt-content.com/images/pt/2012/01/398601_337796282905539_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2012/01/409040_337795586238942_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2012/01/377415_337794166239084_100000255100572_1-1.jpg
this one is with on air in the bags the front center of the frame is 3/4" off the ground (cuz it is siting on the oil pan)...... I will fix that latter
https://static1.pt-content.com/images/pt/2012/01/393385_337795119572322_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2012/01/386339_337795322905635_100000255100572_1-1.jpg
now the bags full of air the front of the frame is around 5 1/4"
https://static1.pt-content.com/images/pt/2012/01/406528_337794916239009_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2012/01/397178_337794716239029_100000255100572_1-1.jpg
so that is what I have for you today keep looking and i will keep puting up new stuff!!!
robertjra
01-10-2012, 09:49 PM
time to start tinking of a rear end and new three link thiking or going with speed tech and the m9
robertjra
01-16-2012, 10:06 PM
any one have a 6l80e with a trans controller and a display for the dash
robertjra
04-08-2012, 08:51 PM
578855788657887got some new parts in today!!! my speed tech 3 link is still on back order wish it would show allready!!!!! time for some work!!
Blown73
04-08-2012, 09:12 PM
Sweet build Robert! Nice work.
robertjra
04-09-2012, 07:20 PM
Thanks Jeff!! just got off the phone with jegs they told me my 3 link is shiping tomarow! i was installing my rack and pinion and looks like i will need to move the motor up 1/2"
robertjra
04-23-2012, 09:14 PM
https://static1.pt-content.com/images/pt/2012/04/522206_413182098700290_100000255100572_1-1.jpg my new rear suspension from speed tech!!!!
daytonayellaz
04-24-2012, 04:47 AM
Your getting there Robert, looking good! Keep up the hard work...:cheers:
robertjra
04-24-2012, 06:32 PM
She is comming a long Travis I think I will have it running in one more year lots to do still rear end is next..... do you know what gear I should runn with a 29" tall tire with the 6 speed you sold me? ford 9"
johnny68
04-24-2012, 08:02 PM
youll like the torque arm blake makes great stuff good job
john
robertjra
09-22-2012, 07:18 PM
Well i installed the Rack & Pinion in my Camaro and I did need to move the mortor up 1/2 inch so...... I made my own mounts not much to look at but strong!!!
I cut out some plate
https://static1.pt-content.com/images/pt/2012/09/545701_490501347635031_167736668_n1_zps0-1.jpg
and made my bace and drilled out the holes to bolt into the frame and tack welded
https://static1.pt-content.com/images/pt/2012/09/155162_490501440968355_1328478704_n1_zps-1.jpg
welded up and boxed in and cleaned up ready for paint
https://static1.pt-content.com/images/pt/2012/09/550700_490501577635008_1324881068_n1_zps-1.jpg
https://static1.pt-content.com/images/pt/2012/09/541118_490501544301678_1178692451_n1_zps-1.jpg
More to come!!!!
robertjra
09-22-2012, 08:22 PM
first coat of paint I'll install them tomarow and put up more pics of the rack / oil pan to show how it came out
https://static1.pt-content.com/images/pt/2012/09/301344_490530620965437_1174883787_n1_zps-1.jpg
https://static1.pt-content.com/images/pt/2012/09/58717_490530780965421_421551751_a1_zps0a-1.jpg
Hotwhilz
09-23-2012, 01:16 AM
Nice work! And nice parts installed!
robertjra
09-23-2012, 01:46 AM
Thanks I need to stay motivated so I can start driving this beast
robertjra
09-23-2012, 08:27 PM
Mounts are in and everything clears nice and I now have my frame on the ground oil pan is no longer the lowest point!!!! so I cleaned the shop and started on the rear torque arm.
Got the old rear end out:
https://static1.pt-content.com/images/pt/2012/09/548483_490920960926403_1090838154_n1_zps-1.jpg
Toruqe arm by Speed Tech
https://static1.pt-content.com/images/pt/2012/09/522206_413182098700290_100000255100572_1-1.jpg
Got the frame plates welded in, and the shock tower mocked up
https://static1.pt-content.com/images/pt/2012/09/485753_490921424259690_1412979511_n1_zps-1.jpg
https://static1.pt-content.com/images/pt/2012/09/308220_490921280926371_1172054317_n1_zps-1.jpg
https://static1.pt-content.com/images/pt/2012/09/230528_490922037592962_1963596478_n1_zps-1.jpg
https://static1.pt-content.com/images/pt/2012/09/66537_490921747592991_31931027_n1_zps78a-1.jpg
Thats all for today!!! till my next day off
Hotwhilz
09-24-2012, 02:54 AM
Keep at it, the final touches will be a great reward!
KnightMare
09-24-2012, 07:30 PM
You got alot of work in her, your getting closer
robertjra
09-24-2012, 08:23 PM
Only 10-15 more large purchases and its on to all the little stuff so.... two more years till she is done? lol thanks for the suport this is my first build and Im trying to do as much on my own as I can
https://static1.pt-content.com/images/pt/2012/09/58351_493653513986481_1899551026_n1-1.jpg
started working on the trunck floor this is what I have so far
https://static1.pt-content.com/images/pt/2012/09/576928_493653777319788_831132432_n1-1.jpg
my templet to fit my floor
https://static1.pt-content.com/images/pt/2012/09/230456_493653883986444_1059630166_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/09/251303_493654133986419_2083607793_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/09/150137_493654280653071_1849547752_n1-1.jpg
this is all I have for now one more day off and I will have the floor all done!!!!
robertjra
09-30-2012, 08:38 PM
Next week all my parts for my rear axle will be in... I hope called Randy's Ring and Pinion. I will be installing the center and narrow the axles
gak68
09-30-2012, 09:11 PM
Nice looking project. Great welding on the suspension. I'm jealous about you getting your suspension in your car, I'm still saving up my pennies for all my parts and pieces.
robertjra
10-02-2012, 07:13 PM
I saved my pennies for a long time to get lots of the parts I have, just keep at it!
robertjra
10-05-2012, 06:28 PM
The ups guy dropped off my 9" !!!!!!!! Time for the fun stuff post pics ASAP
robertjra
10-06-2012, 09:45 PM
well pics are in!!!!
https://static1.pt-content.com/images/pt/2012/10/480929_495617277123438_650260026_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/10/261943_495616213790211_289534634_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/10/155634_495616967123469_1503543463_n1-1.jpg
robertjra
10-14-2012, 08:21 PM
I got two days off of work so I put it to good use mocked up my rear torque arm got some pics for every one
https://static1.pt-content.com/images/pt/2012/10/61471_498841793467653_971672734_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/10/427946_498841946800971_998878739_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/10/552756_498842150134284_4370064_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/10/76590_498842630134236_1432240772_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/10/486727_498842783467554_109661593_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/10/47520_498842383467594_1848719305_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/10/564829_498842506800915_1353968684_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/10/536553_499255980092901_1742165006_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/10/22692_499256280092871_1484165353_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/10/384272_499256693426163_1491417767_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/10/299384_499257770092722_60912107_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/10/525464_499257040092795_979096547_n1-1.jpg
This is the only part I had to fab the kit came with stock 9" brackets so I made my own not burned in yet
https://static1.pt-content.com/images/pt/2012/10/554097_499257506759415_841818864_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/10/58339_499257380092761_1013085164_n1-1.jpg
Well thats all till my next day off
robertjra
10-21-2012, 08:44 PM
Lots more work done in the trunk to day things are slowing down not as much big stuff to install got the car all the way down as far as it will go in the rear looks like I need to make more room for the axle to go up I'll post pics as soon as I can
robertjra
10-22-2012, 06:52 PM
https://static1.pt-content.com/images/pt/2012/10/385766_502205393131293_186042122_n1-1.jpg
Little blurry but this is as low as I can get it rear end is hitting the trunk floor so time to cut some more!! this is all for now
robertjra
11-18-2012, 07:56 PM
I put the fenders on just for fun
https://static1.pt-content.com/images/pt/2012/11/188475_512720052079827_1116071137_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/11/14280_512705965414569_638708166_n1-1.jpg
Started the marker light delete
https://static1.pt-content.com/images/pt/2012/11/598484_513504485334717_777234450_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/11/602368_513504725334693_400094871_n1-1.jpg
https://static1.pt-content.com/images/pt/2012/11/230081_513505738667925_14147646_n1-1.jpg
robertjra
11-18-2012, 08:18 PM
Did my first door skin replacement not as hard as every one says
https://static1.pt-content.com/images/pt/2012/11/417065_513506095334556_974813808_n1-1.jpg
off with the old
https://static1.pt-content.com/images/pt/2012/11/46180_513506198667879_386349565_n1-1.jpg
cleaned and primer painted used rust away worked like a charm!!!
https://static1.pt-content.com/images/pt/2012/11/540010_513514408667058_636925412_n1-1.jpg
black paint
https://static1.pt-content.com/images/pt/2012/11/483499_513514545333711_1101346251_n1-1.jpg
robertjra
04-27-2013, 07:56 PM
droped the trunck floor 9" front 5" rear for my tank geting one built by Boyds welding got my A1000 pump too!!!
https://static1.pt-content.com/images/pt/2013/04/911807_588877934464038_780085580_n1_zpsb-1.jpg (http://s1197.photobucket.com/user/robertjra/media/911807_588877934464038_780085580_n1_zpsb2ca327b.jp g.html)
https://static1.pt-content.com/images/pt/2013/04/908703_588877971130701_181826919_n1_zpsd-1.jpg (http://s1197.photobucket.com/user/robertjra/media/908703_588877971130701_181826919_n1_zpsd6d04c69.jp g.html)
https://static1.pt-content.com/images/pt/2013/04/912188_588878041130694_668777699_n1_zps5-1.jpg (http://s1197.photobucket.com/user/robertjra/media/912188_588878041130694_668777699_n1_zps5911d80a.jp g.html)
https://static1.pt-content.com/images/pt/2013/04/912213_590480757637089_428471329_n1_zpsf-1.jpg (http://s1197.photobucket.com/user/robertjra/media/912213_590480757637089_428471329_n1_zpsfd406055.jp g.html)
robertjra
04-28-2013, 10:41 PM
Got a lots done on the roll cage today floor plates welded in and the main hoop along with the hallo still working on the front down bars that go through the dash I will have the pictures up tomorrow
RBEAST
04-29-2013, 08:20 PM
good to see you've started back up on car or at least posting updates again , looking forward to seeing how it all turns out!
have you decided on a color yet?
kevincp
04-30-2013, 05:48 AM
Nice Job..lot of work. thanks for sharing
19,69camaro
04-30-2013, 08:06 AM
Not trying to be too critical, but I would grind out those welds on the rear-end brackets and do them over. From the pictures you dont seem to be getting it hot enough and its just balling up in the middle.
jtm311
05-01-2013, 02:57 PM
I have to agree 100% some are real cold with no penetration. Better to be safe.
John
robertjra
05-01-2013, 07:04 PM
Thanks! I will and I just got a new welder from lincon its a wire feed like what I had but much better its the 140
robertjra
05-01-2013, 07:06 PM
Yes the new camaro color synergy green with a modern take on the yanko stripes
robertjra
06-03-2013, 09:26 PM
well more parts and more done to the car and got more pic's too
https://static1.pt-content.com/images/pt/2013/06/911615_591679837517181_1397602854_n1_zps-1.jpg (http://s1197.photobucket.com/user/robertjra/media/911615_591679837517181_1397602854_n1_zps2344994e.j pg.html)
https://static1.pt-content.com/images/pt/2013/06/911624_591679794183852_919782298_n1_zpsa-1.jpg (http://s1197.photobucket.com/user/robertjra/media/911624_591679794183852_919782298_n1_zpsa7aed188.jp g.html)
https://static1.pt-content.com/images/pt/2013/06/912226_591679910850507_532452439_n1_zpsd-1.jpg (http://s1197.photobucket.com/user/robertjra/media/912226_591679910850507_532452439_n1_zpsd9bfb9a4.jp g.html)
https://static1.pt-content.com/images/pt/2013/06/911925_591773740841124_1467518510_n1_zps-1.jpg (http://s1197.photobucket.com/user/robertjra/media/911925_591773740841124_1467518510_n1_zpse196fb54.j pg.html)
https://static1.pt-content.com/images/pt/2013/06/911420_594896343862197_256005674_n1_zpsd-1.jpg (http://s1197.photobucket.com/user/robertjra/media/911420_594896343862197_256005674_n1_zpsdab5d0cb.jp g.html)
https://static1.pt-content.com/images/pt/2013/06/913122_594896293862202_1026836507_n1_zps-1.jpg (http://s1197.photobucket.com/user/robertjra/media/913122_594896293862202_1026836507_n1_zpsf4245a9a.j pg.html)
https://static1.pt-content.com/images/pt/2013/06/954582_594896373862194_1254367665_n1_zps-1.jpg (http://s1197.photobucket.com/user/robertjra/media/954582_594896373862194_1254367665_n1_zps7e0f6b19.j pg.html)
https://static1.pt-content.com/images/pt/2013/06/973061_606845816000583_138226621_n1_zps2-1.jpg (http://s1197.photobucket.com/user/robertjra/media/973061_606845816000583_138226621_n1_zps2bf5883f.jp g.html)
https://static1.pt-content.com/images/pt/2013/06/972971_606857682666063_1711417078_n1_zps-1.jpg (http://s1197.photobucket.com/user/robertjra/media/972971_606857682666063_1711417078_n1_zpsf50555c3.j pg.html)
https://static1.pt-content.com/images/pt/2013/06/975583_606857735999391_144223478_n2_zpsd-1.jpg (http://s1197.photobucket.com/user/robertjra/media/975583_606857735999391_144223478_n2_zpsdd30c01a.jp g.html)
https://static1.pt-content.com/images/pt/2013/06/974893_607174619301036_1905982192_n1_zps-1.jpg (http://s1197.photobucket.com/user/robertjra/media/974893_607174619301036_1905982192_n1_zps5bcbce01.j pg.html)
https://static1.pt-content.com/images/pt/2013/06/974826_607204079298090_1623772392_n1_zps-1.jpg (http://s1197.photobucket.com/user/robertjra/media/974826_607204079298090_1623772392_n1_zpse58781fe.j pg.html)
https://static1.pt-content.com/images/pt/2013/06/979653_607204019298096_1308028648_n2_zps-1.jpg (http://s1197.photobucket.com/user/robertjra/media/979653_607204019298096_1308028648_n2_zpsd218a614.j pg.html)
https://static1.pt-content.com/images/pt/2013/06/962028_607204579298040_842092277_n1_zps7-1.jpg (http://s1197.photobucket.com/user/robertjra/media/962028_607204579298040_842092277_n1_zps794a9714.jp g.html)
https://static1.pt-content.com/images/pt/2013/06/962065_607219869296511_526148301_n1_zpsa-1.jpg (http://s1197.photobucket.com/user/robertjra/media/962065_607219869296511_526148301_n1_zpsa18622ec.jp g.html)
My new fuel cell from Boyd Welding I would recommend them to any one!!!
https://static1.pt-content.com/images/pt/2013/06/973388_607863929232105_1561546157_n2_zps-1.jpg (http://s1197.photobucket.com/user/robertjra/media/973388_607863929232105_1561546157_n2_zps0f468fe5.j pg.html)
https://static1.pt-content.com/images/pt/2013/06/973030_607864175898747_2051662818_n2_zps-1.jpg (http://s1197.photobucket.com/user/robertjra/media/973030_607864175898747_2051662818_n2_zps43a34c26.j pg.html)
https://static1.pt-content.com/images/pt/2013/06/975067_607878952563936_568577466_n2_zps6-1.jpg (http://s1197.photobucket.com/user/robertjra/media/975067_607878952563936_568577466_n2_zps6a2d02b9.jp g.html)
https://static1.pt-content.com/images/pt/2013/06/975674_607878982563933_1802781941_n1_zps-1.jpg (http://s1197.photobucket.com/user/robertjra/media/975674_607878982563933_1802781941_n1_zps9b09bb04.j pg.html)
lots more room in the trunk that's all for now
robertjra
06-04-2013, 10:04 AM
It's time for the fuel lines what has every one used not looking for hard lines
robertjra
06-13-2013, 10:13 PM
Looking forward to the weekend going to do more work on the roll cage and trunk
robertjra
09-01-2013, 09:45 PM
My 2010 SS and my 1969 Camaro
https://static1.pt-content.com/images/pt/2013/09/913119_594967327188432_950534864_n2_zps1-1.jpg (http://s1197.photobucket.com/user/robertjra/media/913119_594967327188432_950534864_n2_zps1140a95e.jp g.html)
robertjra
09-01-2013, 09:51 PM
Most of the front window roll cage body supports are in still needs finish welds and clean up
https://static1.pt-content.com/images/pt/2013/09/1236822_651270364891461_1741769059_n1_zp-1.jpg (http://s1197.photobucket.com/user/robertjra/media/1236822_651270364891461_1741769059_n1_zpsacba842c. jpg.html)
https://static1.pt-content.com/images/pt/2013/09/1185034_651270344891463_1713695374_n2_zp-1.jpg (http://s1197.photobucket.com/user/robertjra/media/1185034_651270344891463_1713695374_n2_zpsd12aa448. jpg.html)
https://static1.pt-content.com/images/pt/2013/09/1185889_651270311558133_670366629_n1_zps-1.jpg (http://s1197.photobucket.com/user/robertjra/media/1185889_651270311558133_670366629_n1_zps374552b9.j pg.html)
https://static1.pt-content.com/images/pt/2013/09/1236895_651270408224790_2142381413_n1_zp-1.jpg (http://s1197.photobucket.com/user/robertjra/media/1236895_651270408224790_2142381413_n1_zps6b655052. jpg.html)
https://static1.pt-content.com/images/pt/2013/09/1231576_651270384891459_1402109000_n1_zp-1.jpg (http://s1197.photobucket.com/user/robertjra/media/1231576_651270384891459_1402109000_n1_zps4575dcfe. jpg.html)
Bryce
09-02-2013, 06:15 AM
nice progress. dimple dies are awesome!
robertjra
09-02-2013, 08:37 AM
Thanks I'm going to do the rear window the same way. I love my dimple dies kind of hard to come by got mine from SPC but for the price I expected some sort of case or box, they just sent them in plastic bags.
robertjra
09-15-2013, 07:42 PM
Dose any one know if an exhaust shop can bend roll cage tubing
Pete68
07-10-2016, 10:20 PM
Great build. Subscribed...
robertjra
01-26-2020, 08:06 PM
So life happens to us all bit I never gave up on this build work moved me to Montana (my home town) when I moved here my first goal was to buy land and build my own shop house, I wanted to build this with my own 2 hands so with some help from friends and lots of late nights.... took 3 and a half years to complete but I did it debt free no mortgage no loans!!! So the Camaro was on the back burner but now the shop house is complete and I'm happy to say the Camaro will soon pick right back where I left off so enjoy a few pictures and stay tuned because I'm stepping up my game on the Camaro!!!!
robertjra
01-26-2020, 08:36 PM
The newest fab work on the Camaro. Fifth gen Interior, R1 fuel full and locking cap, and cutting the quarter panel and winding the entire rear 22 inches to fit 20x15 American Racing wheels in the rear 18x10 front with Mickey Thompson 28x1800R20 26x10R18
