View Full Version : 64-66 Gm A-body rear coil pics needed
phasemaster1
10-03-2010, 04:54 PM
My 67 GTO has a 64 rear in it. Just need pictures how the coils are attached to the rear perches. Thank you.
Mingus
10-03-2010, 04:59 PM
They have a pigtail and bolt on with plates. It is a different spring end than a '67. I'm not at home right now but when I get there I'm pretty sure I have pics.
phasemaster1
10-03-2010, 05:13 PM
Greatly appreciated!
gearheads78
10-03-2010, 05:25 PM
I've got the correct hardware if you need it. $20.00 shipped to your door sound fair?
Mingus
10-03-2010, 05:54 PM
Still not home but I found a pic of the retainer
http://www.opgi.com/product.asp?catmainid=2&topcatid=62&chapterid=62&grpcode=13567&ProdCode=CH27358&yearrange=
And a pic of the '64-'66 rear spring with a pigtail only on the bottom
http://www.66ss396.com/rear-springs/images/IMG_4572.JPG
Do your '67 lower pigtails fit over the perches? If so you should be able to use them with the retainer.
Hope this helps.
Mike
phasemaster1
10-03-2010, 06:03 PM
Chucked the old coils a long time ago. The rear was hack job had tubing for spacers. So starting fresh.
phasemaster1
10-03-2010, 06:28 PM
Thanks for the retainer link.
gearheads78
10-03-2010, 07:00 PM
Your spring are still the same for a 64 and 67. The 67 had a cup that is self holding and 64-67 uses the retainer above.
wmhjr
10-04-2010, 07:44 AM
I think I even have a couple of the retainers laying on a shelf that I powder-coated. Not sure. '66 had the retainers in a Poncho A-Body. '67 did not.
phasemaster1
10-04-2010, 04:59 PM
Thanks for the offer wmhjr jumped on gearheads78 (https://www.pro-touring.com/forum/member.php?u=1622) offer.
